Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Disabled icon palettes
Disabled icon palettes [message #466785] Tue, 17 January 2006 17:30 Go to next message
Nicolas Jouanin is currently offline Nicolas JouaninFriend
Member
I'd like to create disabled icons based on normal enabled icons.
Therefore, when looking at this doc.
( http://www.eclipse.org/articles/Article-UI-Guidelines/Index. html) , hi
created new images using a 2-color greyscale palette. The result is
good, but when looking at eclipse standard icons (for example the toggle
mark lamp) i see that disabled icons use a 8-color greyscale palette.
Is the documentation mentioned out of date (is was for eclipse 2.1) ?
what's the recommendation now for disabled icon color palette ?
Nicolas.
Re: Disabled icon palettes [message #466794 is a reply to message #466785] Tue, 17 January 2006 18:33 Go to previous messageGo to next message
Member
more generally, how can i know which processes (photoshop
transformation, settings, ...) are used to create disabled icons used in
eclipse ?
Nicolas Jouanin a écrit :
> Regards,
> Nicolas.
Re: Disabled icon palettes [message #466812 is a reply to message #466794] Tue, 17 January 2006 20:49 Go to previous messageGo to next message
Member
I found some answers here :
http://dev.eclipse.org/mhonarc/lists/platform-ui-dev/msg0204 8.html
is there something more recent ?
> eclipse ?
>> Hi,
>> hi created new images using a 2-color greyscale palette. The result is
>> toggle mark lamp) i see that disabled icons use a 8-color greyscale
>> palette.
>> Regards,
>> Nicolas.
Re: Disabled icon palettes [message #466815 is a reply to message #466812] Tue, 17 January 2006 21:06 Go to previous message
Veronika Irvine is currently offline Veronika IrvineFriend
You will probably get a better response to the question - what processes are
used to create the disabled images in Eclipse - on the eclipse.platform
newsgroup.
"Nicolas Jouanin" <nicolas.jouanin@gmail.com> wrote in message
news:dqjl92$h8v$1@utils.eclipse.org...
> Nicolas Jouanin a
Previous Topic:StackLayout problem
Next Topic:Trouble with margins when printing
Current Time: Wed Jun 03 04:16:11 GMT 2020
Powered by FUDForum. Page generated in 0.01797 seconds
