Home » Eclipse Projects » Standard Widget Toolkit (SWT) » questions about laying out widgets
questions about laying out widgets [message #466323] Fri, 06 January 2006 15:34 Go to next message
Aleksandr Kravets is currently offline Aleksandr KravetsFriend
Member
I'm writing SWT application, here is a screenshot:
http://public.fotki.com/akravets/life/random_stuff/clientsql .html
The problems I am having are marked in red. The widget are not starting
at 0,0 of the tab, I don't want to have gray space around my widgets (if
possible). Below the tab folder there is no blue border, however if I
start resizing the right sash, then the border appears. Here is a
screenshot of when border is visible:
http://public.fotki.com/akravets/life/random_stuff/clientsql 2.html
I appreciate any help. Here is the layout code:
Label resultLabel = new Label(this, SWT.LEFT | SWT.BORDER);
table = new Table(this, SWT.BORDER | SWT.MULTI |
SWT.FULL_SELECTION | SWT.VIRTUAL);
final GridData gd = new GridData(GridData.FILL_BOTH);
table.setLayoutData(gd);
table.setHeaderVisible(true);
table.setLinesVisible(true);
setLayout(new GridLayout(1,true));
GridData labelData = new GridData(GridData.FILL_HORIZONTAL);
resultLabel.setLayoutData(labelData);
GridData resultData = new GridData(GridData.FILL_BOTH);
table.setLayoutData(resultData);
Re: questions about laying out widgets [message #466334 is a reply to message #466323] Fri, 06 January 2006 16:52 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika IrvineFriend
GridLayout has a defualt margin all around of 5 pixels. You can override
this as follows:
GridLayout layout= new GridLayout(1,true);
layout.marginWidth = layout.marginHeight = 0;
setLayout(layout);
"Aleksandr Kravets" <akravets@klgerweiss.com> wrote in message
news:dpm2p1$pre$1@utils.eclipse.org...
> The problems I am having are marked in red. The widget are not starting at
Re: questions about laying out widgets [message #466336 is a reply to message #466323] Fri, 06 January 2006 16:57 Go to previous messageGo to next message
Not quite sure how you are missing part of the blue border - is "this" a
child of CTabFolder?
Re: questions about laying out widgets [message #466338 is a reply to message #466334] Fri, 06 January 2006 17:33 Go to previous messageGo to next message
Member
thanks a lot!
> this as follows:
> setLayout(layout);
>>Hi,
Re: questions about laying out widgets [message #466339 is a reply to message #466336] Fri, 06 January 2006 17:36 Go to previous messageGo to next message
Member
I am not sure what do you mean by child of CTabFolder. It's a CTabItem,
and the top border is there, only it's visible when I make my sash
wider. If you look at first screenshot, you'll see what I mean.
>>Hi,
Re: questions about laying out widgets [message #466341 is a reply to message #466339] Fri, 06 January 2006 20:17 Go to previous messageGo to next message
When you create a widget to be displayed inside a CTabItem, it is created
as a child of the CTabFolder and then associated with the CTabItem using
CTabItem.setControl(). For example :
CTabFolder folder = new CTabFolder(shell, SWT.BORDER);
CTabItem item = new CTabItem(folder, SWT.CLOSE);
item.setText("Item "+i);
item.setImage(image);
Text text = new Text(folder, SWT.MULTI | SWT.V_SCROLL | SWT.H_SCROLL);
text.setText("Text for item "+i+"\n\none, two, three\n\nabcdefghijklmnop");
item.setControl(text);
In your code snippet below, is "this" a subclass of Composite and do you
call setControl() on the CTabItem with "this"?
news:dpm9ss$6rs$1@utils.eclipse.org...
>I am not sure what do you mean by child of CTabFolder. It's a CTabItem, and
>the top border is there, only it's visible when I make my sash wider. If
>>>Hi,
Re: questions about laying out widgets [message #466346 is a reply to message #466341] Fri, 06 January 2006 21:11 Go to previous message
Member
Yes, "this" is a Class that extends Composite, and in the calling class
I setControl thru this Class.
>>>>Hi,
Previous Topic:How to start a TableCellEditor with doubleclick?
Next Topic:Bests SWT/JFace Books for Beginners
Current Time: Fri Aug 14 09:52:45 GMT 2020
Powered by FUDForum. Page generated in 0.02998 seconds
