Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Finding name of image of a selected treeItem
Finding name of image of a selected treeItem [message #466172] Wed, 04 January 2006 13:41 Go to next message
mp is currently offline mpFriend
How can I get the name of an Image of a certain treeItem in a tree.
For an item that gets selected I want to verify if a centain image with a
specific name was set?
Re: Finding name of image of a selected treeItem [message #466176 is a reply to message #466172] Wed, 04 January 2006 14:48 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika IrvineFriend
You could use TreeItem.setData(key, value) to store the image name when
setting the image so that you can compare later on using
TreeItem.getData(key).
"mp" <pijnmar@home.nl> wrote in message
news:f54b94814d2efaadaf5443a90fa92278$1@www.eclipse.org...
Re: Finding name of image of a selected treeItem [message #466180 is a reply to message #466176] Wed, 04 January 2006 17:09 Go to previous messageGo to next message
Perfect.
As I never used this. What is the normal usage for this function? Must I
see it as an enhanced option to "tag" an item with objects...
Re: Finding name of image of a selected treeItem [message #466244 is a reply to message #466180] Thu, 05 January 2006 13:51 Go to previous message
It is just a simple mechanism to associate data with a widget. For example,
if I have a Tree representing files and directories in the file system I
might associate a Java File object with each item in the Tree. The Tree
displays the name and icon for the file but if I want access to more
information about the file, I get the associated File object.
news:a4967a5731c5b75b73479b910b71e46a$1@www.eclipse.org...
> Perfect.
Previous Topic:Problem making a view scrollable
Next Topic:How to combine different images to one image?
Current Time: Mon Feb 24 12:38:46 GMT 2020
Powered by FUDForum. Page generated in 0.02002 seconds
