Home » Archived » EPF » Unable to launch EPF Composer
Unable to launch EPF Composer [message #47171] Tue, 29 January 2008 08:00 Go to next message
Originally posted by: pushpa.krishnaswamy.kumaran.com
I am new to Eclipse. I downloaded the Eclipse Process Framework Composer
and extracted it. I ran the application epf.exe. Only the blue eclipse
starting page was shown with copyright details, but nothing else appeared.
The task manager shows the epf composer is running, but I am not able to
see the application. I have not installed Eclipse IDE.
I have the following:
Windows XP with SP 2
j2sdk1.4.2_06
IE 6.0
What am I missing? Why is the application (epf composer) not opening to
show me any menu, or anything else? Do I need to do anything else? Do I
need to have the Eclipse IDE also? Will the epf composer run
independently of the IDE?
Thanks.
Re: Unable to launch EPF Composer [message #47298 is a reply to message #47171] Tue, 29 January 2008 19:21 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
Which EPF did you download ? If you are using latest EPF build 1.2.0.1 you
need JRE 1.5.
Please follow the instructions given here
http://www.eclipse.org/epf/downloads/tool/tool_downloads.php
Shilpa
Re: Unable to launch EPF Composer [message #47355 is a reply to message #47298] Wed, 30 January 2008 07:20 Go to previous messageGo to next message
Roman Smirak is currently offline Roman SmirakFriend
I have changed my ant definition from a process execution:
<exec executable="${dir.epf.composer}/epf">
<arg line="-application org.eclipse.epf.publishing.cmdline.Publish" />
<arg line="-data ${dir.data}" />
<arg line="-nosplash" />
<arg line="-libraryPath ${dir.checkout}" />
<arg line="-publishPath ${dir.epf.publish}" />
<arg line="-config TE-RUP_Agile" />
<arg line="-feedback mailto:te.rup@tietoenator.com" />
<arg line="-glossary" />
<arg line="-index" />
<arg line="-publishUnverifiedDiagrams" />
<arg line="-title TE-RUP_Agile" />
<arg line="-vmargs -Xms64m -Xmx512m" />
</exec>
To java:
<java dir="${dir.epf.composer}"
jar=" ${dir.epf.composer}/plugins/org.eclipse.equinox.launcher_1.0 .0.v20070606.jar "
fork="true" maxmemory="512m" logError="true">
<arg line="-ws gtk" />
<classpath>
<pathelement
location=" ${dir.epf.composer}/plugins/org.eclipse.equinox.launcher_1.0 .0.v20070606.jar "
</classpath>
</java>
And now - big surprise - it works! All the pictures are in place. Actually,
the idea behind the change: I have noticed eclipse was refreshing workspace
every time it started; which sounded like problem with process; so I tried
to change it (bug in OS/Java?)...
Anyway, it works I have to move on...
However, I have found 2 picture issues (warning log + they are still missing
in the published config):
Warning: Guideline:req_gathering_techniques: missing resource file
'./../../../openup/guidances/guidelines/resources/Workshop.G IF'
Warning: RoleSet:openup_roles: missing resource file
'./../../openup/rolesets/./resources/OpenUp1_350.jpg'
Have you noticed same problem? I expect GIF or capital letters might be
problem (the references in source xmi?)
Roman
"Shilpa Toraskar" <storaskar@xx.xxx.xxx> wrote in message
news:a1c63d4302177a45eb589565681f1702$1@www.eclipse.org...
> need JRE 1.5.
> Shilpa
Re: Unable to launch EPF Composer [message #47385 is a reply to message #47355] Wed, 30 January 2008 07:54 Go to previous message
I'm sorry that's another thread:-)
Roman
"Roman Smirak" <roman.smirak@tietoenator.com> wrote in message
news:fnp8fe$u2n$1@build.eclipse.org...
> </exec>
> To java:
> <classpath>
> <pathelement
> </classpath>
> </java>
> Actually, the idea behind the change: I have noticed eclipse was
> refreshing workspace every time it started; which sounded like problem
> with process; so I tried to change it (bug in OS/Java?)...
> missing in the published config):
> Regards,
> Roman
>> you need JRE 1.5.
>> Shilpa
Re: Unable to launch EPF Composer [message #586321 is a reply to message #47171] Tue, 29 January 2008 19:21 Go to previous message
Shilpa Toraskar is currently offline Shilpa ToraskarFriend
need JRE 1.5.
Shilpa
Re: Unable to launch EPF Composer [message #586359 is a reply to message #47298] Wed, 30 January 2008 07:20 Go to previous message
</exec>
To java:
<classpath>
<pathelement
</classpath>
</java>
Roman
> need JRE 1.5.
> Shilpa
Re: Unable to launch EPF Composer [message #586366 is a reply to message #47355] Wed, 30 January 2008 07:54 Go to previous message
Roman
> </exec>
> To java:
> <classpath>
> <pathelement
> </classpath>
> </java>
> Regards,
> Roman
>> you need JRE 1.5.
>> Shilpa
Previous Topic:Equinox launcher failes on linux
Next Topic:Export to OpenProj
Current Time: Fri Dec 01 17:31:28 GMT 2023
Powered by FUDForum. Page generated in 0.03601 seconds
