Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Shell problem while shell is Iconified
Shell problem while shell is Iconified [message #465671] Sun, 18 December 2005 06:00
Originally posted by: sojoner.gmx.de
Hello everybody, first thank you all for this great mailinglist. I have
found the best answers to my questions here. But now it seems that I have
a bigger problem.
Enviroment: WinXP, Eclipse 3.2, SWT 3.138
Problem: When I minimize my Shell object using the frame bar button,
everything is fine, the shell is in the Windows Taskbar. But when try to
maximize the Shell i need two mouseclicks. So the Shell is would be
deInconified after the second Mousedown event.
I tried to find an example wich has the same bug, but i could not find one.
My dispatch loop is called via a function and the hole GUI Object with the
shell is started by a Core Object that also implemts the main method.
So if there is anybody who knows what might be the source of the error is.
Please give a hint.
Thank you Sojoner
Previous Topic:JFace Document Class Missing
Next Topic:Size of Popup
Current Time: Fri Jul 19 02:04:24 GMT 2019
Powered by FUDForum. Page generated in 0.01859 seconds
