Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Potential bug in TableViewer with associated VIRTUAL table
Potential bug in TableViewer with associated VIRTUAL table [message #465369] Sun, 11 December 2005 16:29 Go to next message
Originally posted by: micasim.gmx.de
I'm using jdk1.5.0_03; Eclipse 3.1.1; SWT
org.eclipse.swt.motif.linux.x86_3.1.1.jar
I set up a trivial sample to evaluate TableViewer with a VIRTUAL table
associated.
The content provider is a ILazyContentProvider (see also below).
Running the sample I noticed the following weird behaviour:
When started the first N instances were displayed (as esxpected).
Then I wanted to display the last ones so I pressed the CTRL+END keys.
Now ALL instances not loaded yet were loaded.
Examining a bit more I detected the TableViewer loads all elements
whenever I pressed the CTRL-key.
I guess this is a bug of the TableViewer at least on the motif platform.
Can anyone try my sample on his box to verify this, please?
I will try it on my Windows NT2K box tomorrow.
Please let me know whether this is a known bug.
Kind regards,
Michael
Re: Potential bug in TableViewer with associated VIRTUAL table [message #465370 is a reply to message #465369] Sun, 11 December 2005 16:41 Go to previous messageGo to next message
Sorry,
I've forgotten to attach the source, so here we go:
package de.micasim.vt;
import java.util.ArrayList;
import org.eclipse.jface.action.Action;
import org.eclipse.jface.action.MenuManager;
import org.eclipse.jface.viewers.ILazyContentProvider;
import org.eclipse.jface.viewers.ITableLabelProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.jface.window.ApplicationWindow;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
* @author michael
public class Main extends ApplicationWindow {
private class Exit extends Action {
private ApplicationWindow parent;
public Exit (ApplicationWindow parent) {
super();
this.parent = parent;
setText ("E&xit@Ctrl+Q");
setToolTipText ("Quit the application.");
this.setAccelerator (SWT.CTRL|'Q');
//setImageDescriptor (ImageDescriptor.createFromFile (Main.class,
"exit.png"));
* @see org.eclipse.jface.action.Action#run()
public void run () {
parent.close();
private class Element {
private String oid;
private String descript;
public Element (String id, String description){
super();
oid = id;
descript = description;
public String id() {return oid;}
public String description() {return descript;}
private class MyLabelProvider extends LabelProvider implements
ITableLabelProvider {
public Image getColumnImage (Object arg0, int arg1) {
return null;
public String getColumnText (Object element, int columnIndex) {
switch (columnIndex) {
case 0:
return ((Element)element).id();
case 1:
return ((Element)element).description();
return element.toString();
private class MyContentProvider implements ILazyContentProvider {
public final String[] properties = {"id","description"};
private ArrayList<Element> data;
private TableViewer connectedViewer;
public MyContentProvider (TableViewer viewer) {
super();
connectedViewer = viewer;
data = new ArrayList<Element> (107);
for (int i = 0; i < 100000; i++)
data.add (new Element (Integer.toString(i), "Element #"+i));
public void dispose () {}
public void inputChanged (Viewer viewer, Object input, Object oldInput)
* Called when a previously-blank item becomes visible in the
TableViewer.
* @see org.eclipse.jface.viewers.ILazyContentProvider#updateElement (int)
public void updateElement (int index) {
System.out.println ("updateElement ("+index+")");
Element element = data.get (index);
if (element != null)
connectedViewer.replace (element, index);
public int contentSize() {
return data.size();
private Exit exit;
private TableViewer tableViewer;
private MyContentProvider contentProvider;
* @param shell
public Main (Shell shell) {
super (shell);
exit = new Exit (this);
this.addMenuBar();
* @see org.eclipse.jface.window.ApplicationWindow#createMenuManager ()
protected MenuManager createMenuManager () {
MenuManager menubar = new MenuManager();
MenuManager submenu = new MenuManager ("&File");
submenu.add (exit);
menubar.add (submenu);
return menubar;
* @see
org.eclipse.jface.window.Window#createContents(org.eclipse.s wt.widgets.Composite)
protected Control createContents (Composite parentComposite) {
Table table = new Table (parentComposite,
SWT.BORDER|SWT.H_SCROLL|SWT.V_SCROLL|SWT.MULTI|SWT.FULL_SELE CTION|SWT.VIRTUAL);
table.setHeaderVisible (true);
TableColumn column = new TableColumn (table, SWT.NONE);
column.setText ("Name");
column.setWidth (64);
column.setText ("Beschreibung");
column.setWidth (128);
tableViewer = new TableViewer (table);
tableViewer.setLabelProvider (new MyLabelProvider());
tableViewer.setContentProvider (contentProvider = new MyContentProvider
(tableViewer));
tableViewer.setColumnProperties (contentProvider.properties);
tableViewer.setItemCount (contentProvider.contentSize());
return table;
* @see
org.eclipse.jface.window.ApplicationWindow#configureShell(or g.eclipse.swt.widgets.Shell)
protected void configureShell (Shell shell) {
super.configureShell (shell);
shell.setSize (640, 480);
* @param args
public static void main (String[] args) {
try {
Main appWindow = new Main (null);
appWindow.setBlockOnOpen (true);
appWindow.open ();
} catch (Exception x) {
x.printStackTrace();
Seems to be a bug of Table itself [message #465371 is a reply to message #465369] Sun, 11 December 2005 17:05 Go to previous messageGo to next message
Hi again,
Now I tried Snippet144
( http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet144.java)
with the same result.
When I pressed the CTRL-Key the complete table is filled, so the Snippet
does the output in the SWT.SetData listener for _every_ instance.
I'm really wondering whether this behaviour is on every platform, if so we
won't be able to use VIRTUAL tables.
kind regards,
Michael
Re: Seems to be a bug of Table itself [message #465383 is a reply to message #465371] Mon, 12 December 2005 11:39 Go to previous messageGo to next message
Michael is currently offline MichaelFriend
Am Sun, 11 Dec 2005 18:05:30 +0100 schrieb Michael Simons <micasim@gmx.de>:
> Hi again,
> we won't be able to use VIRTUAL tables.
> kind regards,
> Michael
I've tried it here on my win box (Eclipse 3.1.0), now. The failure does
not occur, so it seems to be a problem of the Linux Motif Platform only.
Should I do a bug report on this?
Michael
Re: Seems to be a bug of Table itself [message #465393 is a reply to message #465383] Mon, 12 December 2005 15:36 Go to previous messageGo to next message
Charles Tuckey is currently offline Charles TuckeyFriend
I don't see this problem on Linux with GTK either.
> Regards,
> Michael
charlie
Re: Seems to be a bug of Table itself [message #465403 is a reply to message #465393] Mon, 12 December 2005 18:49 Go to previous messageGo to next message
Thanks Charlie,
so it seems to only be a problem of Motif. As Motif might not be used very
frequently it's a minor bug.
Michael
Am Mon, 12 Dec 2005 16:36:09 +0100 schrieb Charles Tuckey
<charlest@otii.com>:
>> <micasim@gmx.de>:
>> does not occur, so it seems to be a problem of the Linux Motif
>> Platform only.
>> Regards,
>> Michael
> charlie
Erstellt mit M2, Operas revolutionärem E-Mail-Modul:
http://www.opera.com/m2/
Re: Seems to be a bug of Table itself [message #465473 is a reply to message #465383] Wed, 14 December 2005 16:09 Go to previous message
Veronika Irvine is currently offline Veronika IrvineFriend
This was fixed in 3.2 on Motif (back around July 2005).
"michael" <michael.simons@optitool.de> wrote in message
news:op.s1n5b4wu27ug8i@news.eclipse.org...
> <micasim@gmx.de>:
>> Hi again,
>> kind regards,
>> Michael
> Regards,
> Michael
Previous Topic:How can i determine whether the UI thread has been created?
Next Topic:Calling a C library from a SWT app ?
Current Time: Sat Jan 18 05:22:12 GMT 2025
Powered by FUDForum. Page generated in 0.03317 seconds
