Re: Missing images [message #47281 is a reply to message #47223] |
Tue, 29 January 2008 19:16 |
Originally posted by: storaskar.xx.xxx.xxx
Looks like all images/icons are getting published and copied to correct
folder for you. I would start by taking a look source html on published
pages and see whether the path to images are correct or not, whether those
images exist or not.
If path is wrong or if image is missing then i can start going into EPF
source code to see.
Also, give it a try for Windows/Jazz & Linux/Eclipse combo and try to nail
down whether it's Jazz or Linux or something else :)
Shilpa
Re: Missing images [message #47472 is a reply to message #47411] |
Wed, 30 January 2008 18:07 |
For linux, file names are case-sensitive. So we would have to change
references in data files correctly.
I didn't quite get whether you are using our OpenUp from CVS or your own
process. If it's openup, please file a bug against "content" component
for those 2 image references.
Shilpa
FUDForum. Page generated in 0.04898 seconds
