Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED!
Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #464976] Fri, 02 December 2005 13:08 Go to next message
Originally posted by: preetamp.aftek.com
Hi All,
I have a tabletreeviewer with SWT.CHECK style
This tree looks good on win 2k but looks improper in fedora core 3
I means on fedora the nodes at verious levels of tree should get indented to
right. The tree hirarchy should get clear.
I m attaching the sample pic.
See that node1 has child node2 which has also a child node3
The relation between node1 and node2 does not get seen properly wheare as
the relation between node2 and node3 is clear deu to indentation !
Any clue ?
~Preetam
  • Attachment: tree.jpg
    (Size: 7.90KB, Downloaded 181 times)
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #464992 is a reply to message #464976] Fri, 02 December 2005 15:37 Go to previous messageGo to next message
Jeremy Dowdall is currently offline Jeremy DowdallFriend
Member
tabletree is apparently deprecated for issues such as this (lots of
discussions earlier in this newsgroup on it)
your best bet is to switch to a Tree with TreeColumns - the good news is
that it's "almost" a drop-in replacement :)
Preetam wrote:
> Hi All,
> Any clue ?
> Thanks
> ~Preetam
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #465069 is a reply to message #464992] Mon, 05 December 2005 11:45 Go to previous messageGo to next message
But I am using TableTreeViewer to build tree
how can I get Tree from it ?
I can get only TableTree and TableTreeItem
Can somebody give me a sample code for the same ?
~Preetam
"Jeremy Dowdall" <dev@myriadfinancial.com> wrote in message
news:dmppo1$pjp$1@news.eclipse.org...
> Preetam wrote:
> > Hi All,
indented to
as
> > Any clue ?
> > Thanks
> > ~Preetam
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #465075 is a reply to message #465069] Mon, 05 December 2005 14:49 Go to previous messageGo to next message
Thanks !
I managed that with treeviewer !
Thanks again !
~Preetam
"Preetam" <preetamp@aftek.com> wrote in message
news:dn1997$rm1$1@news.eclipse.org...
> Thanks
> ~Preetam
> > Preetam wrote:
> > > Hi All,
> indented to
> as
> > > Any clue ?
> > > Thanks
> > > ~Preetam
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #465077 is a reply to message #465069] Mon, 05 December 2005 14:55 Go to previous messageGo to next message
Member
my bad, you'd need to use the TreeViewer rather than the TableTreeViewer:
TreeViewer viewer = new TreeViewer(parent, style);
Tree tree = viewer.getTree();
TreeColumn column0 = new TreeColumn(tree, SWT.LEFT);
column0.setText("col 0");
column0.setMoveable(true);
column0.pack();
TreeColumn column1 = new TreeColumn(tree, SWT.RIGHT);
column1.setText("col 1");
column1.setMoveable(true);
column1.pack();
your content providers shouldn't need to change:
viewer.setContentProvider( ITreeContentProvider );
viewer.setLabelProvider( ITableLabelProvider );
> Thanks
> ~Preetam
>>Preetam wrote:
>>>Hi All,
> indented to
> as
>>>Any clue ?
>>>Thanks
>>>~Preetam
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #465079 is a reply to message #465075] Mon, 05 December 2005 14:56 Go to previous message
Member
oops - should've refreshed before sending... oh well, glad you got it!
Preetam wrote:
> Thanks !
> Thanks again !
> ~Preetam
>>Thanks
>>~Preetam
>>>Preetam wrote:
>>>>Hi All,
>>indented to
>>as
>>>>Any clue ?
>>>>Thanks
>>>>~Preetam
Previous Topic:Centering a Dialog on Screen
Next Topic:Problem with StatusLineManager
Current Time: Tue Jan 21 12:05:37 GMT 2025
Powered by FUDForum. Page generated in 0.03905 seconds
