Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #464976] |
Fri, 02 December 2005 13:08 |
Originally posted by: preetamp.aftek.com
Hi All,
I have a tabletreeviewer with SWT.CHECK style
This tree looks good on win 2k but looks improper in fedora core 3
I means on fedora the nodes at verious levels of tree should get indented to
right. The tree hirarchy should get clear.
I m attaching the sample pic.
See that node1 has child node2 which has also a child node3
The relation between node1 and node2 does not get seen properly wheare as
the relation between node2 and node3 is clear deu to indentation !
Any clue ?
~Preetam
Attachment: tree.jpg
(Size: 7.90KB, Downloaded 173 times)
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #465069 is a reply to message #464992] |
Mon, 05 December 2005 11:45 |
But I am using TableTreeViewer to build tree
how can I get Tree from it ?
I can get only TableTree and TableTreeItem
Can somebody give me a sample code for the same ?
~Preetam
"Jeremy Dowdall" <dev@myriadfinancial.com> wrote in message
news:dmppo1$pjp$1@news.eclipse.org...
> tabletree is apparently deprecated for issues such as this (lots of
> discussions earlier in this newsgroup on it)
> your best bet is to switch to a Tree with TreeColumns - the good news is
> that it's "almost" a drop-in replacement :)
> Preetam wrote:
> > Hi All,
indented to
as
> > Any clue ?
> > Thanks
> > ~Preetam
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #465075 is a reply to message #465069] |
Mon, 05 December 2005 14:49 |
Thanks !
I managed that with treeviewer !
Thanks again !
~Preetam
"Preetam" <preetamp@aftek.com> wrote in message
news:dn1997$rm1$1@news.eclipse.org...
> Thanks
> ~Preetam
> > Preetam wrote:
> > > Hi All,
> indented to
> as
> > > Any clue ?
> > > Thanks
> > > ~Preetam
FUDForum. Page generated in 0.03470 seconds
