Home » Eclipse Projects » Standard Widget Toolkit (SWT) » ViewForm Troubles
ViewForm Troubles [message #464912] Thu, 01 December 2005 06:35 Go to next message
Jeff Yuan is currently offline Jeff YuanFriend
Member
I'm trying to use a ViewForm, and set its content to a table. But nothing
appears when I do it.
ViewForm vf = new ViewForm(parent, SWT.BORDER);
Composite c1 = new Composite(vf, SWT.NONE);
Tree tree = new TreeViewer(c1, SWT.SINGLE);
vf.setContent(c1);
But nothing appears in the ViewForm. If I don't use a viewform, the tree
displays fine, any ideas why the problem?
Thanks.
Re: ViewForm Troubles [message #464922 is a reply to message #464912] Thu, 01 December 2005 15:10 Go to previous message
Originally posted by: friederich.kupzog.de
Hi, did you try to set a layout for your composite?
zinc wrote:
> nothing appears when I do it.
> vf.setContent(c1);
> tree displays fine, any ideas why the problem?
> Thanks.
Friederich Kupzog
Elektronik & Software
Neusser Str. 5-7
50670 Köln
Tel +49 241 9979356
Fax +49 221 726670
www.kupzog.de/fkmk
Previous Topic:How to connect model to GUI using JFace?
Next Topic:SWT Table display
Current Time: Thu Jan 23 21:51:13 GMT 2025
Powered by FUDForum. Page generated in 0.03686 seconds
