Home » Eclipse Projects » Rich Client Platform (RCP) » missing bundle
missing bundle [message #464888] Sun, 18 March 2007 11:57 Go to next message
Originally posted by: hansm.science.uva.nlDELETE
Something strange happens in executing a RCP from "Launch an Eclipse
application" in the Overview tab (Eclipse 3.2.2). The plugin is just a newly
generated one, plus a statement that requires another plugin.
I have added the required plugins through the Preferences to the target.
The jar with the plugin has been added to the list of Required Plug-ins in the
Dependencies tab; that this has effect is demonstrated by the fact that after
the addition the calling code compiles.
But now I try the run the plugin and then I get an inhibited execution with
error "Missing required bundle xyz_0.0.0". Why does this bundle not load
although it occurs in the list of Plug-in Dependencies in the Package Explorer?
Please help.
Hans van der Meer
Re: missing bundle [message #464913 is a reply to message #464888] Tue, 20 March 2007 14:22 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
Member
When you 'run' an application or plugin, a different control environment
is used (vs. the target compilation dependency environment). Go to Run
| Run...
Then, build up a new Eclipse Application, select the Product Id or
Application to run. Then go to the Plug-ins [sic] tab and select the
appropriate plugin(s) to run. I usually deselect all, then select the
one (or few in my application), then Add Required Plugins, then,
Validate Plug-in Set, Apply the changes, then Run.
Hope this helps.
> Please help.
> Hans van der Meer
Re: missing bundle [message #465014 is a reply to message #464913] Wed, 21 March 2007 20:08 Go to previous message
In article <etoqms$n71$1@utils.eclipse.org>,
> | Run...
> Hope this helps.
Yes this is very helpful. Thanks
Hans van der Meer
> > newly
> > the
> > after
> > Explorer?
> > Please help.
Previous Topic:declaring standard work bench action
Next Topic:Text editors
Current Time: Sun Oct 13 21:06:58 GMT 2024
Powered by FUDForum. Page generated in 0.03427 seconds
