Home » Eclipse Projects » Rich Client Platform (RCP) » How to relaunch the RCP Application?
How to relaunch the RCP Application? [message #464429] Mon, 05 March 2007 00:27 Go to next message
Originally posted by: jayam.balasubramaniam.gmail.com
Hi all,
I want to relaunch my application to take the different command line
argument.I used IPlatform.EXIT_RELAUNCH but the application is not started
up again.
1.How to relaunch my application?
2.What are the steps i need to follow?
Jayam
Re: How to relaunch the RCP Application? [message #464440 is a reply to message #464429] Tue, 06 March 2007 05:10 Go to previous messageGo to next message
you can use IWorkbench.restart() to restart the workbench - I guess this
should work for your RCP application too.
HTH,
Stefan
Jayam wrote:
> Hi all,
> started up again.
> Jayam
Re: How to relaunch the RCP Application? [message #464445 is a reply to message #464440] Tue, 06 March 2007 08:00 Go to previous messageGo to next message
Thanks Stefan!
i don't want to restart the application,i want to relaunch the
application,because if i restart the application it will take same command
line argument but i want my application to take different commad line
argument.I think this is possible only if we relaunch the application.
How we can make the application restart or relaunch to take different
commandline arguments?
For example i don't want splashscreen while startup of the application(i
used -noSplash as command line argument) ,after some process i am
restarting the application now i want to show the splashscreen.So how i
can implement this?
Jayam
Re: How to relaunch the RCP Application? [message #464448 is a reply to message #464445] Tue, 06 March 2007 11:22 Go to previous messageGo to next message
> command line argument but i want my application to take different commad
> line argument.I think this is possible only if we relaunch the application.
I don't think that there's a restart/relaunch difference.
> can implement this?
You could change the corresponding lines in the config.ini and then
restart the workbench. Like you do with the locale change, you remember?
Carmen
Re: How to relaunch the RCP Application? [message #464610 is a reply to message #464429] Mon, 12 March 2007 11:42 Go to previous message
Javam,
See this message I posted back in February:
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg20658.html
The problem is probably that you are not setting the "eclipse.exitdata" property
with the new command line.
-Andrew
Jayam wrote:
> Hi all,
> started up again.
> Jayam
Previous Topic:Can FindReplaceAction use IFindReplaceTarget.isEditable?
Next Topic:How To Ensure Single Instance of J2ME Application on PocketPC
Current Time: Thu Apr 17 14:21:55 EDT 2025
Powered by FUDForum. Page generated in 0.04142 seconds
