Home » Eclipse Projects » Rich Client Platform (RCP) » Starting an RCP app invisibly
Starting an RCP app invisibly [message #463805] Thu, 15 February 2007 14:31 Go to next message
I'm trying to modify an RCP application such that when it launches, it
docks itself into the system tray and hides the main application window.
Double clicking the system tray icon will make the window open.
I've mostly been able to accomplish this effect by overriding the
behaviour of the WorkbenchWindowAdvisor (code below), however there is a
brief period where the window becomes visible before this code is executed.
Is there a way to prevent the window from becoming visible at all during
the workbench launching process, or is there a way to delay the
workbench window from opening?
Mark
public class MyWorkbenchWindowAdvisor extends WorkbenchWindowAdvisor
public boolean postWindowOpen ()
super.postWindowOpen ();
Shell shell = Display.getActiveShell ();
shell.setVisible (false);
// Create a system tray entry
Re: Starting an RCP app invisibly [message #463810 is a reply to message #463805] Thu, 15 February 2007 15:15 Go to previous messageGo to next message
Are you using the org.eclipse.core.runtime.applications extension to
launch your own IApplication? Most of the Application classes generated
by PDE just call PlatformUI.createAndRunWorkbench(). You could write
your own IApplication so that it create the tray item, and add a
listener to it to launch the workbench when appropriate. Then just run
the standard SWT event loop:
while (!display.isDisposed())
if (!display.readAndDispatch())
display.sleep();
Matthew
Mark Siegel wrote:
> Mark
Re: Starting an RCP app invisibly [message #463813 is a reply to message #463810] Thu, 15 February 2007 16:28 Go to previous message
Thanks Matt, I'll give this a shot. It sounds like this should work.
Mark
> display.sleep();
> Matthew
> Mark Siegel wrote:
>> Hi,
>> window. Double clicking the system tray icon will make the window open.
>> a brief period where the window becomes visible before this code is
>> executed.
>> during the workbench launching process, or is there a way to delay the
>> Thanks,
>> Mark
Previous Topic:How to shutdown RCP from within
Next Topic:n00b RCP deployment problem
Current Time: Thu Apr 17 11:28:46 EDT 2025
Powered by FUDForum. Page generated in 0.02803 seconds
