Home » Eclipse Projects » Rich Client Platform (RCP) » Scrollbars won't appear
Scrollbars won't appear [message #463386] Fri, 09 February 2007 21:08 Go to next message
Jim Goodwin is currently offline Jim GoodwinFriend
Folks,
I have a SWT Group, which I create with SWT.V_SCROLL:
Group allocationGroup = new Group(taskComposite, SWT.V_SCROLL);
No scrollbar appears. What else does one have to do? Group inherits
from Scrollable, so I assume SWT.V_SCROLL is defined for it and should
work; is that an incorrect assumption?
Is this even the right newsgroup for SWT questions that don't concern RCP?
/jim
Re: Scrollbars won't appear [message #463388 is a reply to message #463386] Fri, 09 February 2007 21:48 Go to previous messageGo to next message
Paul E. Keyser is currently offline Paul E. KeyserFriend
Probably you'll get more traction over on eclipse.platform.swt ...
Paul
Re: Scrollbars won't appear [message #463392 is a reply to message #463388] Fri, 09 February 2007 22:45 Go to previous messageGo to next message
> Paul
Thanks. I looked for that and couldn't find it...
Re: Scrollbars won't appear [message #463394 is a reply to message #463392] Sat, 10 February 2007 09:14 Go to previous message
Stefan Zugal is currently offline Stefan ZugalFriend
Member
I'm not sure whether groups are scrollable.
Composite extends Scrollable too, but it is not scrollable, otherwise
there would be no need for the ScrolledComposite class, I guess.
Anyway you could try to put a ScrolledComposite inside your group.
HTH,
Stefan
Jim Goodwin schrieb:
>> Paul
Previous Topic:Views in stack
Next Topic:TreeColumn variable width
Current Time: Sat Oct 05 15:33:30 GMT 2024
Powered by FUDForum. Page generated in 0.04644 seconds
