Re: Internationalization [message #463422 is a reply to message #463299] |
Mon, 12 February 2007 08:43 |
Originally posted by: 11235813.despammed.com
Aravind schrieb:
[Internationalization]
> so, how we can internationalize the perspective names and the
> pre-defined menus dynamically.
Perspectives:
You know you can define strings used in the plugin.xml in the
plugin.properties file? E.g. "%perspective1.name" in the plugin.xml and
"perspective1.name = Perspective example name 1" in the
plugin.properties file. Then you can deliver a plugin.properties for
each language, e.g. plugin_fr.properties.
Pre-defined menus:
The predefined menus are not shown in your chosen language if you forgot
to deliver the corresponding language plugins for the Eclipse platform,
e.g. org.eclipse.core.runtime.nl1, org.eclipse.swt.nl1... (for each
package/feature you're using).
Carmen
Re: Internationalization [message #463504 is a reply to message #463422] |
Mon, 12 February 2007 21:45 |
I'm sorry, I made a mistake. At the moment I couldn't find a possibility
to change the locale for the Eclipse part of a RCP application at
runtime without restarting the application. Maybe someone else knows a
solution.
Carmen
Re: Internationalization [message #463514 is a reply to message #463504] |
Tue, 13 February 2007 06:49 |
Originally posted by: jayam.balasubramaniam.gmail.com
Is it possible to set the locale when we restart the application? if yes,
then where we should made the (locale)entry?
i tried this in my application
1) i made entry in config.ini file as
osgi.nl=fr
but my application is not getting changed. if i do the same in eclipse
config.ini file then the eclipse locale is getting changed.
so how we can change the locale?
Jayam
Re: Internationalization [message #463520 is a reply to message #463514] |
Tue, 13 February 2007 08:44 |
> yes, then where we should made the (locale)entry?
I've implemented it in my application with the config.ini in the sub
folder "configuration" of my RCP product and it is doing well.
> osgi.nl=fr
Did you try it in debug mode? Then maybe the config.ini is overwritten
every time you start a debug session (seems to be the default in the
xxx.product file). Try it with the exported product. Or you should enter
a more qualified value like fr_FR (language/country). I tried it with
de_DE and en_US and it was ok.
Carmen
Re: Internationalization [message #463521 is a reply to message #463520] |
Tue, 13 February 2007 09:21 |
> xxx.product file).
I should have written 'did you try it from within the Eclipse IDE or as
a standalone application'...
Carmen
Re: Internationalization [message #463647 is a reply to message #463521] |
Wed, 14 February 2007 04:21 |
Thanks Carmen! its working ,if i specify the locale in config.ini file the
product is getting changed to the corresponding language.
My another query... i want to set the locale dynamically ie i am having a
dialog displays the language in combo box,when user selete the language
the application should start in that language, how could we implement this?
And if we use IPlatformRunnable.EXIT_RESTART to restart the application it
is not restarting properly,so how we can restart the application?
Jayam
Re: Internationalization [message #463669 is a reply to message #463647] |
Wed, 14 February 2007 10:21 |
> a dialog displays the language in combo box,when user selete the
> language the application should start in that language, how could we
> implement this?
The only way I know is to change the osgi.nl entry in the config.ini via
code and then restart the application.
> it is not restarting properly,so how we can restart the application?
What do you mean by 'not restarting properly'? I have a preference page
on which the users can change the current locale. After changing the
entry in the config.ini and the value of the locale in the application
preference store (which I use for Locale.setDefault(...)), I do a
workbench.restart() at the end of the performOk() method of my
preference page class:
public class MyPreferencePage extends FieldEditorPreferencePage {
public boolean performOk() {
setLocaleInConfig();
setPropertyInPreferenceStore();
boolean result = super.performOk();
if (localeChanged)
workbench.restart();
return result;
The restart is performed by the class Application:
public class Application implements IPlatformRunnable {
public Object run(Object args) throws Exception {
Display display = PlatformUI.createDisplay();
try {
int returnCode = PlatformUI.createAndRunWorkbench(display,
new ApplicationWorkbenchAdvisor());
if (returnCode == PlatformUI.RETURN_RESTART) {
return IPlatformRunnable.EXIT_RESTART;
Platform.endSplash();
return IPlatformRunnable.EXIT_OK;
finally {
display.dispose();
Maybe this helps.
Carmen
Re: Internationalization [message #463868 is a reply to message #463669] |
Mon, 19 February 2007 06:18 |
Jayam wrote:
When i try to access the config.ini file i am getting the following error:
D:\WorkSpace_Jayam\minttest\.metadata\.plugins\org.eclipse.p de.core\MYPRODUCT.product
(Access is denied)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
at java.io.FileWriter.<init>(Unknown Source)
at com.unisys.mint.Application.run(Application.java:59)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!SESSION 2007-02-17 15:34:32.466
How i can access my config.ini file and entry the osgi.nl?
jayam
Re: Internationalization [message #463923 is a reply to message #463868] |
Tue, 20 February 2007 14:38 |
> (Access is denied)
In an exported product you'll find the file in the sub folder
'configuration' of your application folder. From within the IDE your
path above seems to be correct, but aren't you missing the file name? I
would have expected something like that:
D:\WorkSpace_Jayam\minttest\.metadata\.plugins\org.eclipse.p de.core\MYPRODUCT.product\config.ini
You find the correct folder with
System.getProperty("osgi.configuration.area")
Carmen
Re: Internationalization [message #467049 is a reply to message #463669] |
Fri, 27 April 2007 15:20 |
Originally posted by: maurice.rosenfeld.tuhh.de
Hi Carmen,
I'm facing the same problem as Jayam. Is it possible to get your full MyPreferencePage class? I think this would help me a lot...
Thanks in advance
Junior
FUDForum. Page generated in 0.04168 seconds
