Home » Eclipse Projects » Rich Client Platform (RCP) » TableViewer
TableViewer [message #463243] Wed, 07 February 2007 06:48 Go to next message
I'm trying to use a TableViewer in my RCP Applcation. Unfortunately I do
not how to use it correctly. Can someone here give me a description of
how the TableViewer works? Or maybe someone knows a tutorial on this
topic.
To explain a little more in detail. I'have with 6 coloumns and several
lines which I want to display in my application. Also the data to
display will change from time to time.
Thanks in advance for any help.
Christian Hager
Re: TableViewer [message #463244 is a reply to message #463243] Wed, 07 February 2007 06:54 Go to previous messageGo to next message
Christian Hager wrote:
> Hello,
> topic.
> Christian Hager
This page should get you started
http://www.java2s.com/Code/Java/SWT-JFace-Eclipse/Demonstrat esTableViewers.htm
Stefan
Re: TableViewer [message #463247 is a reply to message #463243] Wed, 07 February 2007 07:22 Go to previous messageGo to next message
Christian Hager schrieb:
> Hello,
> topic.
> Christian Hager
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/
Tom
Re: TableViewer [message #463746 is a reply to message #463247] Thu, 15 February 2007 05:04 Go to previous messageGo to next message
hey in ur discussion i have a point!
using content providers u will place the content by using its getelemnts
method.
if u create 10 model objects with 2 columns in the viewer,the 10 objects
gets laced in the first column and also in the second.
What do i need to do if i want something as if i want to place first 5
objects in first column and the second five in the next column.
Re: TableViewer [message #463752 is a reply to message #463746] Thu, 15 February 2007 05:18 Go to previous messageGo to next message
In this case you should do somthing like this in your labelprovider
class ViewLabelProvider extends LabelProvider implements ITableLabelProvider
public String getColumnText (Object obj, int index)
switch (index)
case 0:
return obj.someThing;
case 1:
return obj.someThingElse;
case 2:
return obj.someThingDifferent;
case 3:
return obj.someOtherThing;
case 4:
return obj.againSomeThingElse;
"George" <george@gmail.com> schrieb im Newsbeitrag
news:4328bd7761fa0be2f577b1b5f41a6736$1@www.eclipse.org...
> method.
Re: TableViewer [message #463759 is a reply to message #463752] Thu, 15 February 2007 06:36 Go to previous message
Thanks a lot but does it make model unique.
I mean u can visually see that contents in column one and column 2 are
different
but will the underlying model also differ.
Previous Topic:Problems contributing and using a Font Definition
Next Topic:Is there a Eclips RCP FAQ site?
Current Time: Thu Apr 24 07:17:18 EDT 2025
Powered by FUDForum. Page generated in 0.03558 seconds
