Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to get text contained in KTable's cell?
How to get text contained in KTable's cell? [message #463225] |
Tue, 01 November 2005 11:09 |
Hi all,
I use KTable's implementation of Table widget, I need to get text
contained in KTable's cell just like in Table's getItem(x). So far I've
come up with KTableModel's getContentAt(x,x) but sometimes in my case the
content of the model does not reflect the content in the cell.
Any ideas ?
Setya
Re: How to get text contained in KTable's cell? [message #463226 is a reply to message #463225] |
Tue, 01 November 2005 13:35 |
Originally posted by: friederich.kupzog.de
Hi Setya,
to use the method getContentAt(x,x) is absolutely right. This method is
also used by the table when drawing the data on screen, so there should
really not be any difference between cell content and getContentAt(x,x).
There are a couple of possible reasons though:
- maybe you have calculated the wrong row/column index, mixed up row and
column or have hidden (size 0) rows/columns?
- did you implement your own cell renderer or use s special one that
transformes the content in some way before it renders it?
This is all I can think of at the moment. I would need more information
or a snippet to give you more specific help. In what way does cell
content and getContentAt(x,x)-result differ?
Friederich Kupzog
Setya wrote:
> Hi all,
> the content of the model does not reflect the content in the cell.
> Any ideas ?
> Setya
Friederich Kupzog
Elektronik & Software
Neusser Str. 5-7
50670 Köln
Tel 0241 160696-1
Fax 0221 726670
www.kupzog.de/fkmk
Re: How to get text contained in KTable's cell? [message #463232 is a reply to message #463226] |
Wed, 02 November 2005 03:58 |
Frederich,
Thank for the response.
This is exactly what I'm trying to find out.
I'm performing GUI testing on which one of the components happens to be
KTable, in my testing I just want to make sure that what users see on the
KTable cells are the right values, so far I always check using KTable's
getContentAt(x,x) which always show the right values and my test will
always pass. But then I won't be able to determine if what users see are
not the same as what the model contains because I've no way to compare the
value in the model with the cells.
Not at all.
Actually the use case is, if I change the value of column x the value of
column y should also automatically change accordingly. This is what I want
to make sure through GUI testing.
I also came up with KTable's getCellRect(x,y), but I've no way to extract
the text out of Rectangles.
> Regards,
> Friederich Kupzog
PS: Your KTable is a great component. I can't thank you enough for it.
Setya
Re: How to get text contained in KTable's cell? [message #463271 is a reply to message #463232] |
Wed, 02 November 2005 08:54 |
Hi Setya,
now I see your problem, I think. If you change a value programatically,
you have to ensure the table is upated by calling table.redraw(). You
can also redraw specific cells using redraw(rectangle) or redraw(int,
int, int, int).
The table has no way to find out when the model changes, so the model
has to care about the refreshing.
There is no way to get the cell content shown on screen because this is
only rendered pixels.
Hope that helped,
Friederich
Friederich Kupzog
Neusser Str. 5-7
50670 Köln
Tel 0241 160696-1
Fax 0221 726670
www.kupzog.de/fkmk
Re: How to get text contained in KTable's cell? [message #463277 is a reply to message #463271] |
Wed, 02 November 2005 10:22 |
Friederich Kupzog wrote:
> Hi Setya,
> int, int, int).
What if I change the value through KTableDefaultModel ? Is there any way
to tell the KTable to refresh itself without having to save reference
directly to KTable in KTableDefaultModel ?
In Swing's JTable I can call fireXXX on JTable's model to achieve this.
Setya
Re: How to get text contained in KTable's cell? [message #463281 is a reply to message #463277] |
Wed, 02 November 2005 10:57 |
Lorenz Maierhofer Messages: 88 Registered: July 2009 |
Member |
>> Hi Setya,
>> programatically, you have to ensure the table is upated by calling
>> table.redraw(). You can also redraw specific cells using
>> redraw(rectangle) or redraw(int, int, int, int).
>> is only rendered pixels.
KTableDefaultModel currently does not support refreshing on model
changes. A generic implementation would always just call redraw() and
thus redraw the whole table. If you change only parts of the model, you
might be much more efficient by doing a selective redraw using
redraw(Rectangle).
There might be an example demonstrating changing models (and possibly
some generic code) some time in the future...
regards,
Lorenz
Current Time: Fri Apr 19 23:36:59 GMT 2024
Powered by FUDForum. Page generated in 0.03586 seconds
