Home » Eclipse Projects » Rich Client Platform (RCP) » Editor loses focus - disable save as
Editor loses focus - disable save as [message #462780] Thu, 01 February 2007 05:27 Go to next message
Stefan Beskow is currently offline Stefan BeskowFriend
How can you detect if an EditorPart is in focus? When a user switches
between an editor and a view I would like to disable the Save As option for
the editor. I tried adding the editor as a part listener to detects it's
corresponding IPartListener2.partDeactivated(..) method, but the problem is
that the EditorPart.isSaveAsAllowed() method is invoked before the
IPartListener2.partDeactivated(..) is invoked, so it's not possible to use
the deactivate event to change the Save As allowed status. Is there
something else I could try?
Thanks.
Stefan
Re: Editor loses focus - disable save as [message #462880 is a reply to message #462780] Thu, 01 February 2007 21:03 Go to previous messageGo to next message
Snjezana Peco is currently offline Snjezana PecoFriend
You can add a focus listener to some control of your editor.
For instance, if you use a text editor, you can catch focus using:
textEditor.getTextViewer().getTextWidget().addFocusListener( new
FocusListener(){
Snjeza
> Thanks.
> Stefan
Re: Editor loses focus - disable save as [message #462887 is a reply to message #462880] Fri, 02 February 2007 02:06 Go to previous message
Great that works.
Thanks for your help.
Stefan
"Snjezana Peco" <snjeza.peco@gmail.com> wrote in message
news:eptkjj$avd$1@utils.eclipse.org...
> FocusListener(){
> Snjeza
>> for the editor. I tried adding the editor as a part listener to detects
>> it's corresponding IPartListener2.partDeactivated(..) method, but the
>> problem is that the EditorPart.isSaveAsAllowed() method is invoked before
>> the IPartListener2.partDeactivated(..) is invoked, so it's not possible
>> to use the deactivate event to change the Save As allowed status. Is
>> there something else I could try?
>> Thanks.
>> Stefan
Previous Topic:RCP, JDT, and WTP
Next Topic:How can we get a notification when the workbench window is about to close
Current Time: Thu Oct 03 23:40:55 GMT 2024
Powered by FUDForum. Page generated in 0.03321 seconds
