Re: Swing vs SWT issues [message #462789 is a reply to message #462777] |
Wed, 19 October 2005 13:42 |
Peter wrote:
> Not even that,
> it gives the following error message in the console
> Unhandled event loop exception
> Reason:
> com/xx/xxxx/xxxxx
> Also in the .log file it gives the following error
> java.lang.NoClassDefFoundError: com/xx/xxxx/xxxxx
> The parent application is a plugin, but the application which gonna
> popup is a seperate standolone application.
> The compilation and everything is successful
> Thanks
Compilation is controlled by the project build path properties. Runtime
is controlled by the manifest (jars have to belong to a plugin). How
have you included your stand alone jars in a plugin, so they can be used
by a plugin?
There are a number of steps for using 3rd party (an external) jars with
plugins ... the easiest is of course creating a New plugin from existin
jar archives. The other steps are available in a couple of other
threads on the news group.
Later,
PW
Paul Webster
FUDForum. Page generated in 0.03701 seconds
