Re: open combobox' dropdown programmatically? [message #462903 is a reply to message #462702] |
Thu, 20 October 2005 17:57 |
Boris Munivrana Messages: 23 Registered: July 2009 |
Hi Arne,
if Win32-only is an option for you, you might try out this little snippet.
Boris
import org.eclipse.swt.*;
import org.eclipse.swt.graphics.*;
import org.eclipse.swt.internal.win32.OS;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.layout.*;
public class CComboDemo {
* Open a Combo programatically (Win32 only)
* @param combo
* Combo
* @param show
* (boolean) popped up or not?
private static void showPopup(Combo combo, boolean show) {
if (!combo.isDisposed()) {
OS.SendMessage(combo.handle, OS.CB_SHOWDROPDOWN, show ? 1 : 0, 0);
* Has the Combo already popped up? (Win32 only)
* @param combo
* Combo
* @return (boolean) popped up or not?
private static boolean isPopupShowing(Combo combo) {
boolean result = false;
result = (OS.SendMessage(combo.handle, OS.CB_GETDROPPEDSTATE, 0, 0) !=
0);
return result;
Display display = new Display();
Shell shell = new Shell(display);
shell.setText("Demonstrates drop down on focus in");
GridLayout gridLayout = new GridLayout();
gridLayout.numColumns = 1;
shell.setLayout(gridLayout);
Text text = new Text(shell, SWT.BORDER);
GridData gridData = new GridData(GridData.FILL_HORIZONTAL);
text.setLayoutData(gridData);
final Combo combo = new Combo(shell, SWT.READ_ONLY);
for(int i = 0; i < 10; i++){
combo.add("ComboItem " + i);
combo.select(0);
combo.setLayoutData(gridData);
combo.addListener(SWT.FocusIn, new Listener(){
public void handleEvent(Event e){
showPopup(combo, !isPopupShowing(combo));
Button button = new Button(shell, SWT.PUSH);
button.setText("Push Me");
button.setLayoutData(gridData);
shell.setSize(330, 100);
Monitor primary = Display.getDefault().getPrimaryMonitor();
Rectangle bounds = primary.getBounds();
Rectangle rect = shell.getBounds();
Point pt = new Point(bounds.x + (bounds.width - rect.width) / 2,
bounds.y + (bounds.height - rect.height) / 2);
shell.setLocation(pt);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
FUDForum. Page generated in 0.03513 seconds
