Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Isnt this supported
Isnt this supported [message #462568] Fri, 14 October 2005 01:22 Go to next message
Originally posted by: harison.hotmail.com
Hi All,
What is the corresponding Widget in SWT for JEditorPane in Swing.
If there is allready a built application(HTML editor app in) in
JEditorPane in Swing, how can we accomodate it to SWT.
Re: Isnt this supported [message #462603 is a reply to message #462568] Fri, 14 October 2005 15:21 Go to previous messageGo to next message
Jeff Myers is currently offline Jeff MyersFriend
No, there currently is no SWT control that is directly equivalent to
JEditorPane. You'll have to do something more complicated like a GEF
editor if you want to create an HTML editor, or handle the painting of
your editor yourself onto an SWT canvas.
- Jeff
Harison wrote:
> Hi All,
> Thanks
Re: Isnt this supported [message #462604 is a reply to message #462568] Fri, 14 October 2005 17:16 Go to previous messageGo to next message
Daniel Spiewak is currently offline Daniel SpiewakFriend
If all you need is stylized text editing, then you can use org.eclipse.swt.custom.StyledText (don't hold me to the class name, it's something like that). I saw an HTML editor for SWT somewhere, you'll have to Google it. I do remember that it's commercial though. And, obviously if all you need is HTML displaying, then you should use the Browser widget.
Re: Isnt this supported [message #462652 is a reply to message #462604] Sun, 16 October 2005 23:49 Go to previous messageGo to next message
Peter is currently offline PeterFriend
Member
Hi All,
Thanks for the answers, I got the point that there is no JeditorPane kind
of widget in SWT, but my second question is, If there is allready a
application built in JEditorPane in Swing, how can we incooperate into a
SWT application.
for e.g How can we set that application as one page of the SWT Multipage
Editor without popping up seperately.
Peter
Re: Isnt this supported [message #462656 is a reply to message #462652] Mon, 17 October 2005 02:14 Go to previous messageGo to next message
You can add Swing components to SWT composites using the org.eclipse.swt.awt.SWT_AWT class and calling the getFrame(Composite) method.
Re: Isnt this supported [message #462658 is a reply to message #462656] Mon, 17 October 2005 05:44 Go to previous messageGo to next message
Member
There is no method called getFrame() in the SWT_AWT class.
Are you refering to the new_Frame( ) method.?
Re: Isnt this supported [message #462662 is a reply to message #462658] Mon, 17 October 2005 08:11 Go to previous messageGo to next message
Stefan Langer is currently offline Stefan LangerFriend
Look at (URL may wrap)
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet135.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
for an example how to use SWT_AWT. Be aware of threading issues.
Hope that helps
Stefan
P.S.: If you don't need to change font in the editor you could use
StyledText component.
Peter wrote:
Re: Isnt this supported [message #462705 is a reply to message #462658] Mon, 17 October 2005 14:59 Go to previous messageGo to next message
My mistake. :-) I didn't have the API open at the time and was working from memory. There're only two methods in the class so I assumed that it wouldn't be hard to figure out what I was saying (as you demonstrated).
Re: Isnt this supported [message #462722 is a reply to message #462705] Tue, 18 October 2005 08:09 Go to previous message
Member
If I allready have a application(which extends JFrame as follows
public class ExistingAPP extends JFrame implements WindowListener
and then when I try to use the java.awt.Frame xxx=
SWT_AWT.new_Frame(xxxxx);
it gives the following error
Exception in thread "main" java.lang.IllegalArgumentException: adding a
window to a container
at java.awt.Container.addImpl(Unknown Source)
at java.awt.Container.add(Unknown Source)
at com.hexidec.ekit.CoolClass.main(CoolClass.java:61)
How to overcome this problem without changing the JFrame class.
waiting for a quick reply.
Previous Topic:Disable automatic search in Tables
Next Topic:Treeviewer and Editing Objects (Newbie)
Current Time: Tue Oct 27 15:39:47 GMT 2020
Powered by FUDForum. Page generated in 0.01701 seconds
