Home » Eclipse Projects » Rich Client Platform (RCP) » TextEditor missing
TextEditor missing [message #462268] |
Thu, 25 January 2007 15:04 |
Originally posted by: peter_ossipov.mail.ru
I cannot figure out, why I cannot find TextEditor by "open type" action,
for example. In "Debug..." configuration for launching the application I
can see that I have a plug-in org.eclipse.ui.editors, but I cannot add a
dependency in my plug-in on it. Besides I can see
org.eclipse.ui.editors.AbstractTextEditor, because probably I have a
dependency on org.eclipse.ui.workbench.texteditor, but surprisingly I
do not see TextEditor.
I am just a bit lost...
Thanks very much in advance for your help.
Re: TextEditor missing [message #462270 is a reply to message #462268] |
Thu, 25 January 2007 15:13 |
The only information I was able to find is that org.eclipse.ui.editors
is not part of RCP and not available ot RCP application. What is it for
then?
Sounds like: it is so nice, but you won't get it! :-)
> action, for example. In "Debug..." configuration for launching the
> application I can see that I have a plug-in org.eclipse.ui.editors,
> but I cannot add a dependency in my plug-in on it. Besides I can see
Re: TextEditor missing [message #462301 is a reply to message #462281] |
Fri, 26 January 2007 08:00 |
Hello Daniel.
Thanks for your answer.
Well, OK, let it depend on whatever it wants to, but I am dying to use
it in my RCP application. Is there a possibility to use it anyway?
Daniel Megert wrote:
>> org.eclipse.ui.editors is not part of RCP and not available ot RCP
>> application. What is it for then?
> Yes, currently the default text editor isn't part of RCP since it
> depends on resources and some IDE stuff.
> Dani
>>> I do not see TextEditor.
Re: TextEditor missing [message #462305 is a reply to message #462301] |
Fri, 26 January 2007 09:51 |
Dani Megert Messages: 3802 Registered: July 2009 |
Peter Osipov wrote:
> Hello Daniel.
The problem is not the editor itself but the stuff you drag in with the
dependent plug-ins that you would probably not want (e.g. menu
structure, pref pages etc.). If you can live with that then simply add
org.eclipse.ui.editors and its dependent plug-ins to your stack.
Dani
>> Dani
>>>> see org.eclipse.ui.editors.AbstractTextEditor, because probably I
>>>> have a dependency on org.eclipse.ui.workbench.texteditor, but
>>>> surprisingly I do not see TextEditor.
Re: TextEditor missing [message #462306 is a reply to message #462305] |
Fri, 26 January 2007 10:12 |
Okay, Dani. I see what you mean. When I add dependence on resources I
get this toolbar items and etc., which I obviously do not want. Then let
me stick with a source viewer then.
> Peter Osipov wrote:
>> Hello Daniel.
>> use it in my RCP application. Is there a possibility to use it anyway?
> the dependent plug-ins that you would probably not want (e.g. menu
> Dani
>>> Dani
>>>>> org.eclipse.ui.editors, but I cannot add a dependency in my
Re: TextEditor missing [message #462308 is a reply to message #462306] |
Fri, 26 January 2007 10:37 |
> let me stick with a source viewer then.
Note that there is the StatusTextEditor which is in
org.eclipse.ui.workbench.texteditor. This is easier than starting from
scratch off a source viewer.
Dani
>> Peter Osipov wrote:
>>> Hello Daniel.
>> add org.eclipse.ui.editors and its dependent plug-ins to your stack.
>> Dani
>>>> Dani
>>>>>> the application I can see that I have a plug-in
Re: TextEditor missing [message #462309 is a reply to message #462308] |
Fri, 26 January 2007 11:25 |
Hello, Dani!
That is great news actually. :-D Thanks very much for the advice. There
is so much everywhere, so you never know where to start. I was using a
source viewer and thought it was cool enough, but it turns out there is
an editor using this source viewer! :-[
> Dani
>>> Peter Osipov wrote:
>>>> Hello Daniel.
>>> Dani
>>>>>> RCP application. What is it for then?
>>>>> Dani
Current Time: Mon Oct 07 02:17:13 GMT 2024
Powered by FUDForum. Page generated in 0.04930 seconds
