Home » Eclipse Projects » Rich Client Platform (RCP) » IPlatformRunnable versus IApplication in 3.3's RCP?
IPlatformRunnable versus IApplication in 3.3's RCP? [message #461977] Fri, 19 January 2007 08:53 Go to next message
R3.2.1 (but looking ahead)
I see by checking out 3.3M4 for a trial run that IPlatformRunnable will be deprecated in favor of
IApplication. OK, but how to migrate? It looks, based on a quick glance at the two interfaces, like
the migration could be as simple as "in your RCP's 'Application' class, and everywhere else that you
use IPlatformRunnable, textually replace references to IPlatformRunnable with references
IApplication" -- but I worry that I am being too simple-minded. What is the correct procedure? (I
suppose this will be in the "3.2 to 3.3 migration guide", presumably not yet written?)
thanks,
Paul
Re: IPlatformRunnable versus IApplication in 3.3's RCP? [message #461978 is a reply to message #461977] Fri, 19 January 2007 09:25 Go to previous message
> be deprecated in favor of IApplication. OK, but how to migrate? It
> looks, based on a quick glance at the two interfaces, like the migration
> else that you use IPlatformRunnable, textually replace references to
> IPlatformRunnable with references IApplication" -- but I worry that I am
> being too simple-minded. What is the correct procedure? (I suppose this
AFAIK you replace IPlatformRunnable -> IApplication and put your
internals of IPlatformRunnable.run(Object) into the new
IApplication.start(IApplicationContext), thereby exchanging
IPlatformRunnable.EXIT_RESTART -> IApplication.EXIT_RESTART
IPlatformRunnable.EXIT_OK -> IApplication.EXIT_OK
Greetings from Bremen,
Daniel Krügler
Previous Topic:Error: MESSAGE Could not create action delegate for id:
Next Topic:to remove icons coming with package explorer
Current Time: Tue Jul 15 10:43:27 EDT 2025
Powered by FUDForum. Page generated in 0.29335 seconds
