Home » Eclipse Projects » Rich Client Platform (RCP) » VM arguments in RCP Product?
VM arguments in RCP Product? [message #461546] Thu, 11 January 2007 16:10 Go to next message
Where can I find documentation on passing VM arguments to an RCP product?
Are arguments in the launch configuration preserved during export?
Are variables (for example workspace_loc) preserved during export?
Charlie
Re: VM arguments in RCP Product? [message #461548 is a reply to message #461546] Thu, 11 January 2007 17:17 Go to previous messageGo to next message
I can help answer you first question. Passing arguments to an rcp is
just like passing them to a full SDK. In windows, I create a shortcut to
the .exe and add the arguments to the end of the target. To find a list
of valid arguments look in the eclipse 3.2.1 help under the topic
"Workbench User Guide->Task->Running Eclipse". Java VM args are passed
by using the argument -vmargs. You can then put whatever Java VM args
you want after the vmargs argument. Hope this helps.
> Thanks
> Charlie
Re: VM arguments in RCP Product? [message #461549 is a reply to message #461548] Thu, 11 January 2007 18:55 Go to previous messageGo to next message
Hi Scott,
Thanks for the information.
I'm trying to avoid writing batch files and shell scripts.
I'm hoping to find a method to include the VM arguments within the
artifacts (Eclipse application, startup.jar, configuration files)
created by Eclipse when it exports a product for an RCP.
Charlie
>> Thanks
>> Charlie
Re: VM arguments in RCP Product? [message #461559 is a reply to message #461549] Fri, 12 January 2007 01:29 Go to previous messageGo to next message
You can also edit the file 'eclipse.ini', or, if your code is called by a different name, 'product.ini'. There is one-line-per-argument, and often looks like:
-vmargs
-Xmx1024m
etc. -- just see your 'eclipse.ini' for examples.
NB the VM args need to come *after* the -vmargs line -- anything before that is treated as arguments to the Java process e.g.
-a
-b
-vmargs
-c
-d
would be effectively
java -c -d TheClass -a -b
Alex.
Re: VM arguments in RCP Product? [message #461603 is a reply to message #461549] Sat, 13 January 2007 03:26 Go to previous messageGo to next message
Hi Charlie,
if you're using a *.product file, then open it in the Product
Configuration Editor, change to the "Launcher" tab and on the right hand
side there is a "Launching Arguments" section where you can specify "VM
Arguments".
hope that's what you're after ;-)
Diego
Charle Kelly wrote:
> Hi Scott,
> Thanks
> Charlie
>> to the .exe and add the arguments to the end of the target. To find a
>> list of valid arguments look in the eclipse 3.2.1 help under the topic
>>> product?
>>> Thanks
>>> Charlie
Re: VM arguments in RCP Product? [message #461651 is a reply to message #461559] Mon, 15 January 2007 11:50 Go to previous messageGo to next message
Hi Alex,
Thanks, this worked perfectly.
Also, when I added the arguments to the product editor, an "eclipse.ini"
file which contains the VM arguments was created automatically.
Charlie
> -vmargs
> -Xmx1024m
> -a
> -b
> -vmargs
> -c
> -d
> Alex.
Re: VM arguments in RCP Product? [message #461665 is a reply to message #461651] Mon, 15 January 2007 23:52 Go to previous message
Sounds reasonable. Eclipse reads eclipse.ini and configuration/config.ini when starting up to determine command line arguments/properties respectively. (If you've called your product something other than 'eclipse', like 'myapp', then it will read myapp.ini (defaulting to eclipse.ini if it can't be found), then configuration/config.ini).
The .product mechanism is an easier way of encapsulating product properties in one place; it's then used to generate things like the eclipse.ini and other key features. So if you're doing .product development, edit the .product file and let it generate the eclipse.ini for you -- if you're not, then just edit the eclipse.ini.
Glad it worked out,
Alex.
Previous Topic:Eclipse Buddy Concept - Property File
Next Topic:my feature can't be disable
Current Time: Thu Apr 24 04:13:31 EDT 2025
Powered by FUDForum. Page generated in 0.03407 seconds
