Home » Eclipse Projects » Rich Client Platform (RCP) » ClassLoader Problem (ClassCastException)?
ClassLoader Problem (ClassCastException)? [message #461543] Thu, 11 January 2007 12:45 Go to next message
I'm having some difficulties with osgi classloading and I'm hoping
someone here can help me.
I have one class ResultEntry and a class FactorialResult which extends
ResultEntry. Now in one of my bundles I get an resultEntry object which
really is a FactorialTask from another bundle an then I want to
FactorialTask using the following code
FactorialResult fact = (FactorialResult) resultEntry;
Now when I try to do so I get a the following exception.
java.lang.ClassCastException:
org.ac.computegrid.jobs.fibfact.FactorialResult
at
org.ac.computegrid.jobs.fibfact.FibFactJob.addResultEntry(Fi bFactJob.java
:79)
at
org.ac.computegrid.master.GenericMaster$2.run(GenericMaster. java:167)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Following this I have also displayed the ClassLoaderTrees as I get them
with this code
ClassLoaderUtil.displayContextClassLoaderTree ();
ClassLoaderUtil.displayClassLoaderTree(FactorialResult.class
..getClassLoader ());
ClassLoaderUtil.displayClassLoaderTree (resultEntry.getClass
().getClassLoader ());
ClassLoaderUtil.displayClassLoaderTree (ResultEntry.class.getClassLoader
and here the output
ClassLoader Tree has 3 levels
cl0 -- Boot ClassLoader
cl1 -- ClassLoader
org.eclipse.osgi.baseadaptor.BaseAdaptor$ParentClassLoader@1b06041: is
unknown ClassLoader type
cl2 -- ClassLoader
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@19422d2: is
cl1 -- ClassLoader
cl2 -- ClassLoader
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@467991: is
ClassLoader Tree has 4 levels
cl1 -- ClassLoader
cl2 -- ClassLoader
cl3 -- ClassLoader
sun.rmi.server.LoaderHandler$Loader@1174ec5["ahttp://computegrid:computeg
rid@192.168.0.200/codebase/computegrid_jobs.jar"]:
ahttp://computegrid:computegrid@192.168.0.200/codebase/compu tegrid_jobs.j
ar
cl1 -- ClassLoader
cl2 -- ClassLoader
Can anyone tell me how to solve this? Ah if it helps the ResultEntry
object comes from a JavaSpace
Thanks for any help
Christian Hager
Re: ClassLoader Problem (ClassCastException)? [message #461553 is a reply to message #461543] Thu, 11 January 2007 19:11 Go to previous messageGo to next message
Christian Hager wrote:
I know this sounds odd, but is FactorialTask a subclass of
FactorialResult (since you only mentioned FactorialResult is a subclass
of ResultEntry).
If it is, then something to be careful about is that each class is only
contributed once. i.e. if plugin A has ResultEntry and FactorialResult
and plugin B had FactorialResult and FactorialTask, you can get into
trouble.
Later,
PW
Re: ClassLoader Problem (ClassCastException)? [message #461561 is a reply to message #461553] Fri, 12 January 2007 03:06 Go to previous messageGo to next message
In article <eo6jnd$iie$1@utils.eclipse.org>,
> > Hi,
> of ResultEntry).
> trouble.
> Later,
> PW
Sorry FactorialTask has nothing to do with the Problem. It was just a
typing mistake. I meant FactorialResult is a subclass of ResultEntry and
resultEntry is an instance of FactorialResult which I receive as an
ResultEntry and then want to cast to FactorialResult.
Sorry for the mistake.
Any ideas?
Re: ClassLoader Problem (ClassCastException)? [message #461564 is a reply to message #461553] Fri, 12 January 2007 05:41 Go to previous messageGo to next message
> > Hi,
> of ResultEntry).
> trouble.
> Later,
> PW
Sorry, here a little correction. FactorialTask has nothing to do with
Any ideas?
Re: ClassLoader Problem (ClassCastException)? [message #461595 is a reply to message #461543] Fri, 12 January 2007 18:33 Go to previous messageGo to next message
OK, sorry about that. Let me try a different tact.
Plugins can see classes in their Bundle-ClassPath (PDE Editor>Runtime
tab>Classpath) ... which means they can see classes in that plugin + any
jars included in the plugin.
Plugins can see classes from their required plugins, if the required
plugin exports the appropriate package.
So if plugin A has ResultEntry and FactorialResult and exports the
correct packages, plugin B can cast a ResultEntry to a FactorialResult.
If Plugin A exports ResultEntry and plugin B exports FactorialResult and
plugin C gets a ResultEntry from A (which happens to be a
FactorialResult), plugin C cannot cast the ResultEntry to a
FactorialResult because it cannot see plugin B (unless it requires both
plugin A and plugin B).
In your setup, which plugin defines ResultEntry and FactorialResult?
Which plugin returns a ResultEntry that is a FactorialResult? Which
plugin requests the ResultEntry that is a FactorialResult?
What are the plugin dependencies?
Later,
PW
Re: ClassLoader Problem (ClassCastException)? [message #461611 is a reply to message #461595] Sat, 13 January 2007 11:05 Go to previous messageGo to next message
Ok let me try to explain more in detail. First we have Plugin A which
contains ResultEntry, second Plugin B which contains the
FactorialResult. Now I've Plugin C which requires A and takes the
ResultEntry from the JavaSpace and hands it over to Plugin B. Plugin B
requires Plugin A and itsself contains FactorialResult as told above. So
if I get your description right I should be able to cast, right?
Unfortunately I can't.
Also if there were any problems with the required plugins I think I
would get a ClassNotFoundException or Eclipse would mark red, or not?
I thought about it and was wondering if the problem could be in the
following code.
ClassLoader cl=Thread.currentThread ().getContextClassLoader ();
Thread.currentThread().setContextClassLoader(ResultEntry.cla ss.getClassLo
ader ());
ResultEntry result = (ResultEntry) space.take (template, null,
Long.MAX_VALUE);
Thread.currentThread ().setContextClassLoader (cl);
This is the code in Plugin C where I take the ResultEntry from the
JavaSpace. I have to set the ContextClassloader there because if I don't
I get a ClassCastException at this point.
Ok any more ideas?
Thanks again.
Re: ClassLoader Problem (ClassCastException)? [message #461614 is a reply to message #461611] Sat, 13 January 2007 12:42 Go to previous messageGo to next message
Who is doing the cast? Plugin B, after Plugin C hands it the resultEntry?
If plugin A creates the object, it will only be a ResultEntry, right?
That cannot be cast to a FactorialResult, since it isn't one.
If I've misinterpreted your description, please post again :-)
Later,
PW
Re: ClassLoader Problem (ClassCastException)? [message #461616 is a reply to message #461614] Sat, 13 January 2007 14:07 Go to previous messageGo to next message
In article <eob5n1$49b$1@utils.eclipse.org>,
> Later,
> PW
Plugin B is doing the cast. The object really is a FactorialResult which
I can see from the eclipse debugger. It is created remotely by my worker
application and stored in the javaspace. Plugin C takes it from the
JavaSpace with the code from my post before.
Re: ClassLoader Problem (ClassCastException)? [message #461621 is a reply to message #461616] Sat, 13 January 2007 19:02 Go to previous messageGo to next message
JavaSpace is obviously doing it's own thing ... where is JavaSpace
loading FactorialResult from (since in theory you gave it plugin A's
classloader as its context class loader). How can it see FactorialResult?
It sounds like JavaSpace is doing its own serialization/deserialization
of classes, and that is interfering with the OSGi classloading management.
I would post your question and problem description to
news://news.eclipse.org/eclipse.technology.equinox
Equinox is the eclipse implementation of OSGi and they understand its
classloading (and might be able to help understand the OSGi + JavaSpace
interaction).
Maybe you need to pass it plugin C's classloader?
Later,
PW
Re: ClassLoader Problem (ClassCastException)? [message #461622 is a reply to message #461621] Sat, 13 January 2007 19:04 Go to previous messageGo to next message
After I posted this, I think this might not work either (although it's
worth a try). I think the OSGi classloaders don't use parent
classloading ... or do they? :-)
Later,
PW
Re: ClassLoader Problem (ClassCastException)? [message #461643 is a reply to message #461622] Mon, 15 January 2007 05:41 Go to previous message
Thanks you're great. Setting the classloader of plugin B before taking from
the space actually did the job.
"Paul Webster" <pwebster@ca.ibm.com> schrieb im Newsbeitrag
news:eobs2c$i89$2@utils.eclipse.org...
> worth a try). I think the OSGi classloaders don't use parent classloading
> ... or do they? :-)
> Later,
> PW
Previous Topic:Deploying to different platforms
Next Topic:How to set a view non-moveable programmatically
Current Time: Thu Apr 17 18:38:46 EDT 2025
Powered by FUDForum. Page generated in 0.04170 seconds
