Home » Eclipse Projects » Rich Client Platform (RCP) » Open editor tooltip not null
Open editor tooltip not null [message #461182] Fri, 05 January 2007 22:40 Go to next message
Originally posted by: jelgolfnut.gmail.com
I'm trying to open an editor and I'm getting the following error....
Unable to create this part due to an internal error. Reason for the
failure: null argument:A part's title tool tip must be non-null
I have the setTitleToolTip("tooltip"); method call in the init for the
editor. Any tips/tricks?
Re: Open editor tooltip not null [message #461186 is a reply to message #461182] Fri, 05 January 2007 23:29 Go to previous messageGo to next message
Check your implementation of IEditorInput for the editor. The
getToolTipText() method of the input must return a non-null entity, but
the default implementation if you use an Eclipse wizard to create the
class will implement a method that returns null.
Brandon
> Thanks
Re: Open editor tooltip not null [message #461214 is a reply to message #461186] Sat, 06 January 2007 21:26 Go to previous message
Thanks....that was it!
Previous Topic:ViewPart containing openoffice
Next Topic:views are not initialized on startup
Current Time: Sun Apr 20 09:13:16 EDT 2025
Powered by FUDForum. Page generated in 0.03157 seconds
