Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT.DOUBLE_BUFFERED and SWT.NO_BACKGROUND
Re: SWT.DOUBLE_BUFFERED and SWT.NO_BACKGROUND [message #461325 is a reply to message #461311] |
Tue, 20 September 2005 20:07 |
Bob Marinier Messages: 3 Registered: July 2009 |
I don't know the actual answer to your question, but in my lab we were
just experimenting with these two flags (alone and in combination) to
see what effect they had on our application on Windows, OS X, and Linux.
Our findings were that on Windows and OS X, there didn't seem to be
any difference between using either of these flags separately or
together (except maybe it's a little slower if you use both). However,
on Linux (Motif; we haven't tried GTK), SWT.NO_BACKGROUND caused a huge
slowdown (by itself and in combination), and also there was a noticeable
tearing effect when used by itself. SWT.DOUBLE_BUFFERED did not seem to
suffer from tearing or performance problems. So in the end we decided
to use SWT.DOUBLE_BUFFERED for all platforms.
Bob
Chris Gross wrote:
> Thanks, I am aware of how things work. I'm asking for a little deeper
> knowledge, if SWT.NO_BACKGROUND is still useful and if
> SWT.DOUBLE_BUFFERED has a cost associated with it.
> -Chris
> Joe Smith wrote:
>> Although I didn't tried SWT.DOUBLE_BUFFERED, two are different.
>> SWT.NO_BACKGROUND does not draw background and thus reduce
>> flickering. Double buffering is useful when you have complex drawing that
>> may take significant time to draw. In this situation, you can notice
>> that things
>> being drawn. Double buffering removes this effect. Draw on invisible
>> images
>> slowly and draw the images on the screen as images very quickly so you
>> don't notice things are being drawn.
>> Cheers.
>> "Chris Gross" <schtoo@schtoo.com> wrote in message
>> news:dgea4p$686$1@news.eclipse.org...
>>> Does SWT.DOUBLE_BUFFERED essentially obsolete SWT.NO_BACKGROUND? The
>>> benefit of SWT.NO_BACKGROUND was to reduce flicker. If
>>> SWT.DOUBLE_BUFFERED handles that, then is there no reason to continue
>>> to use SWT.NO_BACKGROUND?
>>> Also, is there any reason why I wouldn't want to use
>>> SWT.DOUBLE_BUFFERED on pretty much any custom widget/canvas? It
>>> works great and seems like its 'free-of-charge' but I want to verify
>>> that.
>>> -Chris
Re: SWT.DOUBLE_BUFFERED and SWT.NO_BACKGROUND [message #461343 is a reply to message #461339] |
Wed, 21 September 2005 04:50 |
No real name Messages: 97 Registered: July 2009 |
Member |
PS
Generally, SWT.NO_BACKGROUND alone will eliminate most
flickering problem! Consider double buffering only if you have to
draw things that may involve lots of computation or take time
to fetech required information, etc. That is , if it takes time
to draw contents, then consider to use double buffering.
In addition, if your canvas large, then also consider,
cliping techniques as well.
Regards.
"Joe Smith" <ohcho@tpg.com.au> wrote in message
news:dgqnfq$3f6$1@news.eclipse.org...
> Generally speaking, you need to use both of them to
> eliminate flickering. If SWT supports double buffered
> write, it will be great. But I have not tried yet. Note
> that there should be extra APIs. You can do it manually by;
> (1) Create an image of the same canvas size.
> (2) Draw everything on it.
> (3) Draw that image to canvas with a single drawImage().
> Hope this will help.
> news:dgpij3$let$1@news.eclipse.org...
>> -Chris
>>> that
>>> that things
>>> images
>>> Cheers.
>>>> SWT.DOUBLE_BUFFERED on pretty much any custom widget/canvas? It works
>>>> great and seems like its 'free-of-charge' but I want to verify that.
>>>> -Chris
Re: SWT.DOUBLE_BUFFERED and SWT.NO_BACKGROUND [message #461727 is a reply to message #461111] |
Wed, 28 September 2005 15:36 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
SWT.DOUBLE_BUFFERED is not supported on all platforms. After you create a
widget with style SWT.DOUBLE_BUFFERED, you can query the style back with
getStyle(). If double buffering is not supported on the platform, the style
will have been removed. In these cases, you may wish to create the widget
with both SWT.NO_BACKGROUND and SWT.DOUBLE_BUFFERED and use the
NO_BACKGROUND approach for platforms without double buffering.
Another thing to note is that some OSs (e.g. Mac OS X) always double buffer
and this can not be turned off. In these cases, doing your own double
buffering is a performance hit.
If you wish to have a widget that displays the default background
texture/gradient, then you should not use SWT.NO_BACKGROUND. For example,
the mac has a pin stripe default background. Currently the only way to draw
this is to let the OS draw it by default. SWT.DOUBLE_BUFFERED will draw the
default background.
When developing your widget, you may wish to turn off SWT.DOUBLE_BUFFERED
because as Joe said, double buffering hides the fact that you are doing
unnecessary work . Damaging only the affected area and drawing only what
the clipRect indicates makes complex widgets perform faster. On some
systems copying an image to the display is not very fast and the bigger the
image, the slower it is.
Veronika
> SWT.DOUBLE_BUFFERED handles that, then is there no reason to continue to
> Also, is there any reason why I wouldn't want to use SWT.DOUBLE_BUFFERED
> on pretty much any custom widget/canvas? It works great and seems like
> -Chris
Current Time: Tue Apr 23 14:48:52 GMT 2024
Powered by FUDForum. Page generated in 0.04073 seconds
