Home » Eclipse Projects » Rich Client Platform (RCP) » Running JasperViewer inside an Eclipse RCP plugin crashes client
Running JasperViewer inside an Eclipse RCP plugin crashes client [message #460826] Fri, 29 December 2006 18:00 Go to next message
Originally posted by: rdjohnson.kingwoodcable.com
From an Eclipse client I run a jasper report on a server via RMI, then bring the resulting 'jasperPrint' back to the client, for display using Jasper's 'JasperViewer' utility. The report displays in a separate window just fine, but when I close the Jasper window, the whole RCP client goes down. I tried running the viewer inside a separate thread (see below), but it still crashes. Does anyone have experience with this approach?
Code sample
// Prime command to generate report on server
startCommandAction = new StartCommandAction();
startCommandAction.setEditor(getEditor());
startCommandAction.setServiceClass("ReportRunner");
startCommandAction.setServiceMethod("executeReport");
startCommandAction.setParameters(parameters);
startCommandAction.run();
Map returnParms = startCommandAction.getReturnParms();
jasperPrint = (JasperPrint)returnParms.get("jasperPrint");
if (jasperPrint != null) {
Thread t = new Thread(new Runnable() {
public void run() {
JasperViewer.viewReport(jasperPrint); }
t.start();
Re: Running JasperViewer inside an Eclipse RCP plugin crashes client [message #460830 is a reply to message #460826] Fri, 29 December 2006 19:46 Go to previous messageGo to next message
Randy,
What's the exception and error stack? This could possibly be thread issue if
you're trying to wotk with SWT through non-UI thread. See
Display.(a)syncExec(...).
thanks,
Dima
"Randy Johnson" <rdjohnson@kingwoodcable.com> wrote in message
news:22168908.1167433260546.JavaMail.root@cp1.javalobby.org...
> Code sample
> public void run() {
> t.start();
Re: Running JasperViewer inside an Eclipse RCP plugin crashes client [message #460841 is a reply to message #460826] Sat, 30 December 2006 06:17 Go to previous messageGo to next message
I think you need to configure the viewer to not shutdown when the window
is closed did you try:
JasperViewer.viewReport(jasperPrint,false);
Tom
> Code sample
> public void run() {
> t.start();
Re: Running JasperViewer inside an Eclipse RCP plugin crashes client [message #460844 is a reply to message #460841] Sat, 30 December 2006 06:21 Go to previous message
By the way if you need to run this on Mac you might get into troubles.
You need a very recent version of MacOSX because of a bug with loading
of AWT-Classes in context of SWT.
Tom
Tom Schindl schrieb:
> Tom
>> Code sample
>> public void run() {
>> t.start();
Previous Topic:getting view??
Next Topic:help,problem with adding console viewer to my rcp
Current Time: Thu Apr 24 10:54:39 EDT 2025
Powered by FUDForum. Page generated in 0.03462 seconds
