Re: Thread safety of Display.syncExec() [message #460746 is a reply to message #460737] |
Tue, 06 September 2005 16:27 |
You should not need to check if the display is disposed WITHIN the
runnable. The runnable will not be executed if the display was disposed
because it is the display that does the execution of the runnable. If it
was disposed it wouldn't execute.
You can either check if disposed before, or just put your
display.syncExec() within a try/catch for SWTException.
However, what makes you think the display will ever be disposed by the
time your are finished? I've done many jobs and never ran into this
situation.
Rich Kulp
Re: Thread safety of Display.syncExec() [message #460753 is a reply to message #460746] |
Wed, 07 September 2005 00:28 |
Mark McLaren Messages: 45 Registered: July 2009 |
Member |
Yep you are right, I don't need to check within the runnable - my mistake.
Although the first option you mention is very common, I don't think it is
100% reliable - the display.syncExec() can on rare occasions still throw
an error because it may have been disposed by another thread. That is:
if (!display.isDisposed()) {
// display could now be disposed in another thread
display.syncExec(myRunnable);
Funnily enough, the syncExec() method itself has the same problem (at
least on windows). Here it is with my comment added:
public void syncExec (Runnable runnable) {
if (isDisposed ()) error (SWT.ERROR_DEVICE_DISPOSED);
// could now be disposed in another thread, which sets
// synchronizer to null, so we get a NullPointerException
synchronizer.syncExec (runnable);
I hadn't considered the "catch SWTException" approach - it would probably
be the best solution if it wasn't for the above bug in syncExec().
> situation.
Are you saying you always prevent the user from closing the main shell
while you run a long operation? Otherwise I can't see how you can be sure
the display still exists at the end of the operation.
In my application, I am creating a 'Print Preview' dialog, but still want
the user to be able to cancel the dialog before the preview has been
generated. Nothing stops her from closing the entire app, so I need to
check the display still exists once the print preview has been generated.
Re: Thread safety of Display.syncExec() [message #460767 is a reply to message #460753] |
Wed, 07 September 2005 01:07 |
Steve Northover Messages: 1636 Registered: July 2009 |
You need to shut down your threads before you dispose the display. Turns
out that while the display is being disposed, another thread can be
syncExec()'ing. In that case, what should happen? If the display is too
far gone, it may be unable to exec your runnable because it has given back
some needed operating system resources but if it doesn't run the runnable,
you wait forever. It's complicated.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=76182.
"Mark McLaren" <noone@nowhere.com> wrote in message
news:5cf10b519a21424fa317a2b99f32fa8f$1@www.eclipse.org...
> > situation.
Re: Thread safety of Display.syncExec() [message #460791 is a reply to message #460753] |
Wed, 07 September 2005 07:42 |
Stefan Langer Messages: 236 Registered: July 2009 |
As far as I understand you, your operation doesnot make sense once the
main app is closed. So if your method throws a SWTException the
application is allready closed meaning you can simply catch the
exception and ignore it (logging it as a warning might still be a good
idea so you can recap).
More problematic would be a case where your operation has to finish when
the application is closed down but then you don't have any gui to report
anything back to so your operation might as well use a asyncExec and
simply try to update the display as it sees fit.
In both cases I would say it is acceptable to simply catch the
SWTException and ignore the consequences.
Stefan
>> disposed because it is the display that does the execution of the
>> runnable. If it was disposed it wouldn't execute.
> is 100% reliable - the display.syncExec() can on rare occasions still
> throw an error because it may have been disposed by another thread.
> That is:
> probably be the best solution if it wasn't for the above bug in syncExec().
>> situation.
> sure the display still exists at the end of the operation.
> want the user to be able to cancel the dialog before the preview has
> been generated. Nothing stops her from closing the entire app, so I
> need to check the display still exists once the print preview has been
> generated.
Re: Thread safety of Display.syncExec() [message #460813 is a reply to message #460767] |
Wed, 07 September 2005 21:16 |
John Arthorne Messages: 176 Registered: July 2009 |
I think the correct bug reference is:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=106984
>>>situation.
FUDForum. Page generated in 0.03187 seconds
