Home » Eclipse Projects » Standard Widget Toolkit (SWT) » swt 64bit keeps crashing in SuSE 64
swt 64bit keeps crashing in SuSE 64 [message #460433] |
Fri, 26 August 2005 09:53 |
stoil Messages: 46 Registered: July 2009 |
Member |
I'm with AMD64 system. Eclipse keeps crashing from time to time. 3.2M1
crashes too. I've check out from cvs latest sources, compiled them and
the problem persist.
I may post other crash logs if needed. These are with compiled on my
system swt.
Here is the log:
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0x00002aaaaf43fa90, pid=11484, tid=1092401504
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.5.0_04-b05 mixed mode)
# Problematic frame:
# J org.eclipse.jdt.internal.compiler.parser.Parser.consumeToken (I)V
--------------- T H R E A D ---------------
Current thread (0x00002aab0cc1caa0): JavaThread "Java indexing" daemon
[_thread_in_Java, id=11509]
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0xffffd556f04219e0
Registers:
RAX=0x000000000000001a, RBX=0x0000000000000006, RCX=0x000000000000198c,
RDX=0x000000000000001a
RSP=0x00000000411ca5e0, RBP=0x0000000000001850, RSI=0x00002aaaf0424ca8,
RDI=0x0000000000000001
R8 =0x0000000000000063, R9 =0x0000000000000002, R10=0xffffd556f04219d0,
R11=0x0000000000000065
R12=0x0000000000000002, R13=0x000000000000184f, R14=0x0000000000000078,
R15=0x00002aab0cc1caa0
RIP=0x00002aaaaf43fa90, EFL=0x0000000000010206,
CSGSFS=0x000000000000caa0, ERR=0x0000000000000005
TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00000000411ca5e0)
0x00000000411ca5e0: 00002aaaf0424d70 00002aaaf04201f0
0x00000000411ca5f0: 000018c700000002 00002aaaf041cb48
0x00000000411ca600: 00002aab0cc1caa0 00002aaaf0466ac0
0x00000000411ca610: 000018510000184d 00002aaaf0469b72
0x00000000411ca620: ffffd556f04219d0 00002aaaf041f028
0x00000000411ca630: 0000000000000002 00002aaaf041cc00
0x00000000411ca640: 00000000000000e3 00000000000000ff
0x00000000411ca650: 00002aaa00000001 0000000000000042
0x00000000411ca660: 00002aaaf041cb48 00002aaaaf1261b0
0x00000000411ca670: 0000000000000044 00000000000000ff
0x00000000411ca680: 00002aab01a85d70 00002aab00000846
0x00000000411ca690: 0000000000000000 00000000411ca740
0x00000000411ca6a0: 00002aab018e81b0 00002aab02dd8650
0x00000000411ca6b0: 00002aaaf041cb48 000008ff0000314b
0x00000000411ca6c0: 00000000411ca740 00002aaaaf010ade
0x00000000411ca6d0: 00000000411ca740 00000000411ca6e8
0x00000000411ca6e0: 00000000411ca740 00000000411ca6f8
0x00000000411ca6f0: 000000000000188e 00002aaaaef92efe
0x00000000411ca700: 00002aaaf041cb48 00000000411ca708
0x00000000411ca710: 00002aab018e81b0 00000000411ca770
0x00000000411ca720: 00002aab01a85d70 00002aab02dd8650
0x00000000411ca730: 00002aab018e82b8 00000000411ca760
0x00000000411ca740: 00000000411ca7b0 00002aaaaef92efe
0x00000000411ca750: 0000000000000000 0000000000000000
0x00000000411ca760: 00002aaaf046a088 00002aaaf046d7b8
0x00000000411ca770: 00002aaaf041cb48 00000000411ca778
0x00000000411ca780: 00002aab01a3b7fb 00000000411ca7d0
0x00000000411ca790: 00002aab01b5a488 00002aab02dd3990
0x00000000411ca7a0: 00002aab01a3b830 00000000411ca7c0
0x00000000411ca7b0: 00000000411ca810 00002aaaaef92efe
0x00000000411ca7c0: 00002aaaf046a088 00002aaaf041cb48
0x00000000411ca7d0: 00002aaaf046d7b8 00000000411ca7d8
Instructions: (pc=0x00002aaaaf43fa90)
0x00002aaaaf43fa80: 03 d7 41 ff c2 41 8b da 45 8b e1 4c 8b 54 24 40
0x00002aaaaf43fa90: 45 8b 4a 10 45 3b e1 0f 83 fc 2a 00 00 4d 63 d4
Stack: [0x00000000410cb000,0x00000000411cc000), sp=0x00000000411ca5e0,
free space=1021k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code,
C=native code)
[error occurred during error reporting, step 120, id 0xb]
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00002aab0c268980 JavaThread "Thread-10" daemon [_thread_blocked,
id=11531]
0x00002aab0c45bfc0 JavaThread "Worker-7" daemon [_thread_blocked,
id=11526]
0x00002aab053c3fb0 JavaThread "Worker-6" [_thread_in_vm, id=11525]
0x00002aab11299800 JavaThread "Worker-5" [_thread_blocked, id=11524]
0x00002aab0c916c80 JavaThread
"org.eclipse.jdt.internal.ui.text.JavaReconciler" daemon
[_thread_blocked, id=11522]
0x00002aab0b195ce0 JavaThread "Worker-4" [_thread_blocked, id=11517]
0x00002aab0c6028c0 JavaThread "Worker-3" [_thread_blocked, id=11516]
0x00002aab054fcb20 JavaThread "Worker-2" [_thread_blocked, id=11515]
0x00002aab054dc9f0 JavaThread "Worker-1" [_thread_blocked, id=11514]
=>0x00002aab0cc1caa0 JavaThread "Java indexing" daemon [_thread_in_Java,
id=11509]
0x00002aab056ea580 JavaThread "Worker-0" [_thread_blocked, id=11506]
0x00002aab0536ff20 JavaThread "Start Level Event Dispatcher" daemon
[_thread_blocked, id=11500]
0x00002aab0536f9f0 JavaThread "Framework Event Dispatcher" daemon
[_thread_blocked, id=11499]
0x00002aab05564790 JavaThread "State Data Manager" daemon
[_thread_blocked, id=11498]
0x00002aab052ed590 JavaThread "Low Memory Detector" daemon
[_thread_blocked, id=11492]
0x00002aab052eba20 JavaThread "CompilerThread1" daemon
[_thread_in_native, id=11491]
0x00002aab052ea530 JavaThread "CompilerThread0" daemon
[_thread_in_native, id=11490]
0x00002aab052e8e90 JavaThread "AdapterThread" daemon
[_thread_blocked, id=11489]
0x00002aab052e7df0 JavaThread "Signal Dispatcher" daemon
[_thread_blocked, id=11488]
0x00000000401ad430 JavaThread "Finalizer" daemon [_thread_blocked,
id=11487]
0x00000000401acc00 JavaThread "Reference Handler" daemon
[_thread_blocked, id=11486]
0x0000000040115d90 JavaThread "main" [_thread_in_native, id=11484]
Other Threads:
0x00000000401a8910 VMThread [id=11485]
0x00002aab052ef120 WatcherThread [id=11493]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x0000000040114af0/0x0000000040114b40] Threads_lock - owner thread:
0x00002aab053c3fb0
Heap
def new generation total 43264K, used 9991K [0x00002aaaeff90000,
0x00002aaaf2e80000, 0x00002aaaf54e0000)
eden space 38464K, 13% used [0x00002aaaeff90000, 0x00002aaaf04a1d98,
0x00002aaaf2520000)
from space 4800K, 99% used [0x00002aaaf29d0000, 0x00002aaaf2e7fff0,
0x00002aaaf2e80000)
to space 4800K, 0% used [0x00002aaaf2520000, 0x00002aaaf2520000,
0x00002aaaf29d0000)
tenured generation total 96008K, used 59294K [0x00002aaaf54e0000,
0x00002aaafb2a2000, 0x00002aaafff90000)
the space 96008K, 61% used [0x00002aaaf54e0000, 0x00002aaaf8ec78f0,
0x00002aaaf8ec7a00, 0x00002aaafb2a2000)
compacting perm gen total 47488K, used 47416K [0x00002aaafff90000,
0x00002aab02df0000, 0x00002aab05190000)
the space 47488K, 99% used [0x00002aaafff90000, 0x00002aab02dde1a0,
0x00002aab02dde200, 0x00002aab02df0000)
No shared spaces configured.
Dynamic libraries:
40000000-4000d000 r-xp 00000000 08:06 406560
/usr/java/jdk1.5.0_04/bin/java
4010c000-40110000 rwxp 0000c000 08:06 406560
40110000-401bc000 rwxp 40110000 00:00 0
401bc000-401bd000 ---p 401bc000 00:00 0
401bd000-402bd000 rwxp 401bd000 00:00 0
402bd000-402c0000 ---p 402bd000 00:00 0
402c0000-403be000 rwxp 402c0000 00:00 0
403be000-403c1000 ---p 403be000 00:00 0
403c1000-404bf000 rwxp 403c1000 00:00 0
404bf000-404c2000 ---p 404bf000 00:00 0
404c2000-405c0000 rwxp 404c2000 00:00 0
405c0000-405c3000 ---p 405c0000 00:00 0
405c3000-406c1000 rwxp 405c3000 00:00 0
406c1000-406c4000 ---p 406c1000 00:00 0
406c4000-407c2000 rwxp 406c4000 00:00 0
407c2000-407c5000 ---p 407c2000 00:00 0
407c5000-408c3000 rwxp 407c5000 00:00 0
408c3000-408c6000 ---p 408c3000 00:00 0
408c6000-409c4000 rwxp 408c6000 00:00 0
409c4000-409c5000 ---p 409c4000 00:00 0
409c5000-40ac5000 rwxp 409c5000 00:00 0
40ac5000-40ac8000 ---p 40ac5000 00:00 0
40ac8000-40bc6000 rwxp 40ac8000 00:00 0
40bc6000-40bc9000 ---p 40bc6000 00:00 0
40bc9000-40cc7000 rwxp 40bc9000 00:00 0
40cc7000-40cca000 ---p 40cc7000 00:00 0
40cca000-40dc8000 rwxp 40cca000 00:00 0
40dc8000-40dcb000 ---p 40dc8000 00:00 0
40dcb000-40ec9000 rwxp 40dcb000 00:00 0
40ec9000-40ecc000 ---p 40ec9000 00:00 0
40ecc000-40fca000 rwxp 40ecc000 00:00 0
40fca000-40fcd000 ---p 40fca000 00:00 0
40fcd000-410cb000 rwxp 40fcd000 00:00 0
410cb000-410ce000 ---p 410cb000 00:00 0
410ce000-411cc000 rwxp 410ce000 00:00 0
411cc000-411cf000 ---p 411cc000 00:00 0
411cf000-412cd000 rwxp 411cf000 00:00 0
412cd000-412d0000 ---p 412cd000 00:00 0
412d0000-413ce000 rwxp 412d0000 00:00 0
413ce000-413d1000 ---p 413ce000 00:00 0
413d1000-414cf000 rwxp 413d1000 00:00 0
414cf000-414d2000 ---p 414cf000 00:00 0
414d2000-415d0000 rwxp 414d2000 00:00 0
415d0000-415d3000 ---p 415d0000 00:00 0
415d3000-416d1000 rwxp 415d3000 00:00 0
416d1000-416d4000 ---p 416d1000 00:00 0
416d4000-417d2000 rwxp 416d4000 00:00 0
417d2000-417d5000 ---p 417d2000 00:00 0
417d5000-419d4000 rwxp 417d5000 00:00 0
2aaaaaaab000-2aaaaaac1000 r-xp 00000000 08:06 24644
/lib64/ld-2.3.4.so
2aaaaaac1000-2aaaaaac2000 rwxp 2aaaaaac1000 00:00 0
2aaaaaac2000-2aaaaaaf5000 r-xp 00000000 08:06 27935
/usr/lib/locale/en_US.utf8/LC_CTYPE
2aaaaaaf5000-2aaaaaafb000 r-xs 00000000 08:06 105907
/usr/lib64/gconv/gconv-modules.cache
2aaaaaafb000-2aaaaab03000 r-xs 00000000 08:06 517004
/opt/eclipse64/startup.jar
2aaaaab03000-2aaaaab05000 r-xs 00000000 08:06 461331
/usr/java/jdk1.5.0_04/jre/lib/ext/dnsns.jar
2aaaaab05000-2aaaaab2b000 r-xs 00000000 08:06 461333
/usr/java/jdk1.5.0_04/jre/lib/ext/sunjce_provider.jar
2aaaaab2b000-2aaaaab9a000 r-xs 00000000 08:06 515651
/opt/eclipse64/plugins/org.eclipse.core.runtime_3.1.0.jar
2aaaaab9a000-2aaaaabaf000 r-xs 00000000 08:06 516732
/opt/eclipse64/plugins/org.eclipse.core.runtime.compatibilit y_3.1.0.jar
2aaaaabaf000-2aaaaabc0000 r-xs 00000000 08:06 516022
/opt/eclipse64/plugins/org.eclipse.help_3.1.0.jar
2aaaaabc0000-2aaaaabc2000 rwxp 00015000 08:06 24644
/lib64/ld-2.3.4.so
2aaaaabc2000-2aaaaabd1000 r-xp 00000000 08:06 429744
/lib64/tls/libpthread.so.0
2aaaaabd1000-2aaaaacd1000 ---p 0000f000 08:06 429744
2aaaaacd1000-2aaaaacd3000 rwxp 0000f000 08:06 429744
2aaaaacd3000-2aaaaacd8000 rwxp 2aaaaacd3000 00:00 0
2aaaaacd8000-2aaaaacda000 r-xp 00000000 08:06 429723
/lib64/libdl.so.2
2aaaaacda000-2aaaaadd9000 ---p 00002000 08:06 429723
/lib64/libdl.so.2
2aaaaadd9000-2aaaaaddb000 rwxp 00001000 08:06 429723
/lib64/libdl.so.2
2aaaaaddb000-2aaaaaef8000 r-xp 00000000 08:06 429731
/lib64/tls/libc.so.6
2aaaaaef8000-2aaaaaff7000 ---p 0011d000 08:06 429731
2aaaaaff7000-2aaaaaffa000 r-xp 0011c000 08:06 429731
2aaaaaffa000-2aaaaaffd000 rwxp 0011f000 08:06 429731
2aaaaaffd000-2aaaab003000 rwxp 2aaaaaffd000 00:00 0
2aaaab003000-2aaaab66b000 r-xp 00000000 08:06 461315
/usr/java/jdk1.5.0_04/jre/lib/amd64/server/libjvm.so
2aaaab66b000-2aaaab76b000 ---p 00668000 08:06 461315
2aaaab76b000-2aaaab8da000 rwxp 00668000 08:06 461315
2aaaab8da000-2aaaab909000 rwxp 2aaaab8da000 00:00 0
2aaaab909000-2aaaab90a000 r-xp 2aaaab909000 00:00 0
2aaaab90a000-2aaaab90b000 rwxp 2aaaab90a000 00:00 0
2aaaab90b000-2aaaab922000 r-xs 00000000 08:06 516733
/opt/eclipse64/plugins/org.eclipse.update.configurator_3.1.0 .jar
2aaaab922000-2aaaab928000 r-xs 00000000 08:06 516019
/opt/eclipse64/plugins/org.eclipse.update.scheduler_3.1.0.ja r
2aaaab928000-2aaaab938000 r-xs 00000000 08:06 515787
/opt/eclipse64/plugins/org.eclipse.team.cvs.ssh2_3.1.0/cvsss h2.jar
2aaaab938000-2aaaab98e000 r-xp 00000000 08:06 429732
/lib64/tls/libm.so.6
2aaaab98e000-2aaaaba8d000 ---p 00056000 08:06 429732
2aaaaba8d000-2aaaaba8f000 rwxp 00055000 08:06 429732
2aaaaba8f000-2aaaaba98000 r-xp 00000000 08:06 461311
/usr/java/jdk1.5.0_04/jre/lib/amd64/native_threads/libhpi.so
2aaaaba98000-2aaaabb97000 ---p 00009000 08:06 461311
2aaaabb97000-2aaaabb9b000 rwxp 00008000 08:06 461311
2aaaabbca000-2aaaabbdd000 r-xp 00000000 08:06 24656
/lib64/libnsl.so.1
2aaaabbdd000-2aaaabcdc000 ---p 00013000 08:06 24656
/lib64/libnsl.so.1
2aaaabcdc000-2aaaabcde000 rwxp 00012000 08:06 24656
/lib64/libnsl.so.1
2aaaabcde000-2aaaabce0000 rwxp 2aaaabcde000 00:00 0
2aaaabce0000-2aaaabd15000 r-xs 00000000 08:06 115241
/var/run/nscd/passwd
2aaaabd15000-2aaaabd1d000 rwxs 00000000 08:06 511036
/tmp/hsperfdata_stoil/11484
2aaaabd1d000-2aaaabd2a000 r-xp 00000000 08:06 461306
/usr/java/jdk1.5.0_04/jre/lib/amd64/libverify.so
2aaaabd2a000-2aaaabe29000 ---p 0000d000 08:06 461306
2aaaabe29000-2aaaabe2c000 rwxp 0000c000 08:06 461306
2aaaabe2c000-2aaaabe51000 r-xp 00000000 08:06 461290
/usr/java/jdk1.5.0_04/jre/lib/amd64/libjava.so
2aaaabe51000-2aaaabf50000 ---p 00025000 08:06 461290
2aaaabf50000-2aaaabf56000 rwxp 00024000 08:06 461290
2aaaabf56000-2aaaabf6c000 r-xp 00000000 08:06 461307
/usr/java/jdk1.5.0_04/jre/lib/amd64/libzip.so
2aaaabf6c000-2aaaac06e000 ---p 00016000 08:06 461307
2aaaac06e000-2aaaac071000 rwxp 00018000 08:06 461307
2aaaac071000-2aaaae651000 r-xs 00000000 08:06 463429
/usr/java/jdk1.5.0_04/jre/lib/rt.jar
2aaaae651000-2aaaae6ba000 rwxp 2aaaae651000 00:00 0
2aaaae6ba000-2aaaae741000 r-xs 00000000 08:06 461396
/usr/java/jdk1.5.0_04/jre/lib/jsse.jar
2aaaae741000-2aaaae755000 r-xs 00000000 08:06 461378
/usr/java/jdk1.5.0_04/jre/lib/jce.jar
2aaaae755000-2aaaaef90000 r-xs 00000000 08:06 461379
/usr/java/jdk1.5.0_04/jre/lib/charsets.jar
2aaaaef90000-2aaaaf510000 rwxp 2aaaaef90000 00:00 0
2aaaaf510000-2aaaeef90000 rwxp 2aaaaf510000 00:00 0
2aaaeef90000-2aaaeefa6000 rwxp 2aaaeef90000 00:00 0
2aaaeefa6000-2aaaeff90000 rwxp 2aaaeefa6000 00:00 0
2aaaeff90000-2aaaf2e80000 rwxp 2aaaeff90000 00:00 0
2aaaf2e80000-2aaaf54e0000 rwxp 2aaaf2e80000 00:00 0
2aaaf54e0000-2aaafb2a2000 rwxp 2aaaf54e0000 00:00 0
2aaafb2a2000-2aaafff90000 rwxp 2aaafb2a2000 00:00 0
2aaafff90000-2aab02df0000 rwxp 2aaafff90000 00:00 0
2aab02df0000-2aab05190000 rwxp 2aab02df0000 00:00 0
2aab05190000-2aab051a8000 rwxp 2aab05190000 00:00 0
2aab051a8000-2aab051ba000 rwxp 2aab051a8000 00:00 0
2aab051ba000-2aab051ea000 rwxp 2aab051ba000 00:00 0
2aab051ea000-2aab05210000 rwxp 2aab051ea000 00:00 0
2aab05210000-2aab05228000 rwxp 2aab05210000 00:00 0
2aab05228000-2aab05239000 rwxp 2aab05228000 00:00 0
2aab05239000-2aab05269000 rwxp 2aab05239000 00:00 0
2aab05269000-2aab05290000 rwxp 2aab05269000 00:00 0
2aab05290000-2aab052a8000 rwxp 2aab05290000 00:00 0
2aab052a8000-2aab052ba000 rwxp 2aab052a8000 00:00 0
2aab052ba000-2aab053e2000 rwxp 2aab052ba000 00:00 0
2aab053e2000-2aab054a6000 r-xs 00000000 08:06 461321
/usr/java/jdk1.5.0_04/jre/lib/ext/localedata.jar
2aab054a6000-2aab057a6000 rwxp 2aab054a6000 00:00 0
2aab057a6000-2aab05806000 rwxs 00000000 00:07 5996557
/SYSV00000000 (deleted)
2aab0580a000-2aab05a0a000 rwxp 2aab0580a000 00:00 0
2aab05a0a000-2aab05ac1000 r-xs 00000000 08:06 516412
/opt/eclipse64/plugins/org.eclipse.osgi_3.1.0.jar
2aab05ac1000-2aab05ad6000 r-xp 00000000 08:06 461301
/usr/java/jdk1.5.0_04/jre/lib/amd64/libnet.so
2aab05ad6000-2aab05bd5000 ---p 00015000 08:06 461301
2aab05bd5000-2aab05bd8000 rwxp 00014000 08:06 461301
2aab05bd8000-2aab05bdf000 r-xp 00000000 08:06 461302
/usr/java/jdk1.5.0_04/jre/lib/amd64/libnio.so
2aab05bdf000-2aab05cde000 ---p 00007000 08:06 461302
2aab05cde000-2aab05ce0000 rwxp 00006000 08:06 461302
2aab05ce0000-2aab05e58000 r-xs 00000000 08:06 516032
/opt/eclipse64/plugins/org.eclipse.ui.ide_3.2.0.jar
2aab05e58000-2aab06129000 r-xs 00000000 08:06 516058
/opt/eclipse64/plugins/org.eclipse.ui.workbench_3.2.0.jar
2aab06129000-2aab0612a000 r-xs 00000000 08:06 516648
/opt/eclipse64/plugins/org.eclipse.ui.workbench.compatibilit y_3.2.0/compatibility.jar
2aab0612a000-2aab061ce000 r-xs 00000000 08:06 516608
/opt/eclipse64/plugins/org.eclipse.jface_3.2.0.jar
2aab061ce000-2aab061cf000 r-xs 00000000 08:06 516592
/opt/eclipse64/plugins/org.eclipse.swt_3.1.0.jar
2aab061cf000-2aab0632d000 r-xs 00000000 08:06 516929
/opt/eclipse64/plugins/org.eclipse.swt.gtk.linux.x86_64_3.1. 0.jar
2aab0632d000-2aab0634b000 r-xs 00000000 08:06 515965
/opt/eclipse64/plugins/org.eclipse.ui_3.2.0.jar
2aab0634b000-2aab063a0000 r-xp 00000000 08:06 115405
/home/stoil/EclipseWorkspaces/EclipseEclipse/org.eclipse.swt .gtk.linux.x86_64/libswt-pi-gtk-3202.so
2aab063a0000-2aab0649f000 ---p 00055000 08:06 115405
2aab0649f000-2aab064a2000 rwxp 00054000 08:06 115405
2aab064a2000-2aab064a3000 rwxp 2aab064a2000 00:00 0
2aab064a3000-2aab064a4000 r-xp 00000000 08:06 25792
/usr/lib/locale/en_US.utf8/LC_IDENTIFICATION
2aab064a4000-2aab064a5000 r-xp 00000000 08:06 27711
/usr/lib/locale/en_US.utf8/LC_MEASUREMENT
2aab064a5000-2aab064a6000 r-xp 00000000 08:06 25796
/usr/lib/locale/en_US.utf8/LC_TELEPHONE
2aab064a6000-2aab064a7000 r-xp 00000000 08:06 25791
/usr/lib/locale/en_US.utf8/LC_ADDRESS
2aab064a7000-2aab064a8000 r-xp 00000000 08:06 25795
/usr/lib/locale/en_US.utf8/LC_NAME
2aab064a8000-2aab064a9000 r-xp 00000000 08:06 27745
/usr/lib/locale/en_US.utf8/LC_PAPER
2aab064a9000-2aab064aa000 r-xp 00000000 08:06 27901
/usr/lib/locale/en_US.utf8/LC_MESSAGES/SYS_LC_MESSAGES
2aab064aa000-2aab064ab000 r-xp 00000000 08:06 25794
/usr/lib/locale/en_US.utf8/LC_MONETARY
2aab064ab000-2aab064c1000 r-xs 00000000 08:06 516925
/opt/eclipse64/plugins/org.eclipse.core.filebuffers_3.1.0.ja r
2aab064c1000-2aab064d1000 r-xs 00000000 08:06 516061
/opt/eclipse64/plugins/org.eclipse.ui.views_3.2.0.jar
2aab064d2000-2aab067b3000 r-xp 00000000 08:06 91515
/opt/gnome/lib64/libgtk-x11-2.0.so.0.600.4
2aab067b3000-2aab068b3000 ---p 002e1000 08:06 91515
2aab068b3000-2aab068c0000 rwxp 002e1000 08:06 91515
2aab068c0000-2aab068c4000 rwxp 2aab068c0000 00:00 0
2aab068c4000-2aab068c8000 r-xp 00000000 08:06 30876
/opt/gnome/lib64/libgthread-2.0.so.0.600.3
2aab068c8000-2aab069c7000 ---p 00004000 08:06 30876
2aab069c7000-2aab069c8000 rwxp 00003000 08:06 30876
2aab069c8000-2aab069cd000 r-xp 00000000 08:06 31456
/usr/X11R6/lib64/libXtst.so.6.1
2aab069cd000-2aab06acd000 ---p 00005000 08:06 31456
2aab06acd000-2aab06ace000 rwxp 00005000 08:06 31456
2aab06ace000-2aab06ae3000 r-xp 00000000 08:06 91511
/opt/gnome/lib64/libgdk_pixbuf-2.0.so.0.600.4
2aab06ae3000-2aab06be2000 ---p 00015000 08:06 91511
2aab06be2000-2aab06be3000 rwxp 00014000 08:06 91511
2aab06be3000-2aab06c69000 r-xp 00000000 08:06 91509
/opt/gnome/lib64/libgdk-x11-2.0.so.0.600.4
2aab06c69000-2aab06d68000 ---p 00086000 08:06 91509
2aab06d68000-2aab06d6d000 rwxp 00085000 08:06 91509
2aab06d6d000-2aab06d6e000 rwxp 2aab06d6d000 00:00 0
2aab06d6e000-2aab06e78000 r-xp 00000000 08:06 31414
/usr/X11R6/lib64/libX11.so.6.2
2aab06e78000-2aab06f77000 ---p 0010a000 08:06 31414
2aab06f77000-2aab06f7d000 rwxp 00109000 08:06 31414
2aab06f7d000-2aab06f84000 r-xp 00000000 08:06 80581
/opt/gnome/lib64/libpangoxft-1.0.so.0.800.1
2aab06f84000-2aab07083000 ---p 00007000 08:06 80581
2aab07083000-2aab07084000 rwxp 00006000 08:06 80581
2aab07084000-2aab0708f000 r-xp 00000000 08:06 80579
/opt/gnome/lib64/libpangox-1.0.so.0.800.1
2aab0708f000-2aab0718f000 ---p 0000b000 08:06 80579
2aab0718f000-2aab07190000 rwxp 0000b000 08:06 80579
2aab07190000-2aab071cb000 r-xp 00000000 08:06 80575
/opt/gnome/lib64/libpango-1.0.so.0.800.1
2aab071cb000-2aab072cb000 ---p 0003b000 08:06 80575
2aab072cb000-2aab072d2000 rwxp 0003b000 08:06 80575
2aab072d2000-2aab072ed000 r-xp 00000000 08:06 31690
/opt/gnome/lib64/libatk-1.0.so.0.901.0
2aab072ed000-2aab073ed000 ---p 0001b000 08:06 31690
2aab073ed000-2aab073f0000 rwxp 0001b000 08:06 31690
2aab073f0000-2aab07428000 r-xp 00000000 08:06 30874
/opt/gnome/lib64/libgobject-2.0.so.0.600.3
2aab07428000-2aab07527000 ---p 00038000 08:06 30874
2aab07527000-2aab07529000 rwxp 00037000 08:06 30874
2aab07529000-2aab0752c000 r-xp 00000000 08:06 30872
/opt/gnome/lib64/libgmodule-2.0.so.0.600.3
2aab0752c000-2aab0762b000 ---p 00003000 08:06 30872
2aab0762b000-2aab0762c000 rwxp 00002000 08:06 30872
2aab0762c000-2aab076b2000 r-xp 00000000 08:06 30870
/opt/gnome/lib64/libglib-2.0.so.0.600.3
2aab076b2000-2aab077b1000 ---p 00086000 08:06 30870
2aab077b1000-2aab077b3000 rwxp 00085000 08:06 30870
2aab077b3000-2aab077c3000 r-xp 00000000 08:06 31429
/usr/X11R6/lib64/libXext.so.6.4
2aab077c3000-2aab078c3000 ---p 00010000 08:06 31429
2aab078c3000-2aab078c4000 rwxp 00010000 08:06 31429
2aab078c4000-2aab078c7000 r-xp 00000000 08:06 31449
/usr/X11R6/lib64/libXrandr.so.2.0
2aab078c7000-2aab079c6000 ---p 00003000 08:06 31449
2aab079c6000-2aab079c7000 rwxp 00002000 08:06 31449
2aab079c7000-2aab079cf000 r-xp 00000000 08:06 31438
/usr/X11R6/lib64/libXi.so.6.0
2aab079cf000-2aab07ace000 ---p 00008000 08:06 31438
2aab07ace000-2aab07acf000 rwxp 00007000 08:06 31438
2aab07acf000-2aab07ad1000 r-xp 00000000 08:06 31439
/usr/X11R6/lib64/libXinerama.so.1.0
2aab07ad1000-2aab07bd0000 ---p 00002000 08:06 31439
2aab07bd0000-2aab07bd1000 rwxp 00001000 08:06 31439
2aab07bd1000-2aab07be5000 r-xp 00000000 08:06 31436
/usr/X11R6/lib64/libXft.so.2.1.2
2aab07be5000-2aab07ce4000 ---p 00014000 08:06 31436
2aab07ce4000-2aab07ce5000 rwxp 00013000 08:06 31436
2aab07ce5000-2aab07d67000 r-xp 00000000 08:06 24840
/usr/lib64/libfreetype.so.6.3.7
2aab07d67000-2aab07e67000 ---p 00082000 08:06 24840
2aab07e67000-2aab07e74000 rwxp 00082000 08:06 24840
2aab07e74000-2aab07ea9000 r-xp 00000000 08:06 29167
/usr/lib64/libfontconfig.so.1.0.4
2aab07ea9000-2aab07fa8000 ---p 00035000 08:06 29167
2aab07fa8000-2aab07fb0000 rwxp 00034000 08:06 29167
2aab07fb0000-2aab07fb2000 rwxp 2aab07fb0000 00:00 0
2aab07fb2000-2aab07fb7000 r-xp 00000000 08:06 31430
/usr/X11R6/lib64/libXfixes.so.3.0
2aab07fb7000-2aab080b6000 ---p 00005000 08:06 31430
2aab080b6000-2aab080b7000 rwxp 00004000 08:06 31430
2aab080b7000-2aab080c0000 r-xp 00000000 08:06 31425
/usr/X11R6/lib64/libXcursor.so.1.0.2
2aab080c0000-2aab081c0000 ---p 00009000 08:06 31425
2aab081c0000-2aab081c1000 rwxp 00009000 08:06 31425
2aab081c1000-2aab081c9000 r-xp 00000000 08:06 31451
/usr/X11R6/lib64/libXrender.so.1.2.2
2aab081c9000-2aab082c9000 ---p 00008000 08:06 31451
2aab082c9000-2aab082ca000 rwxp 00008000 08:06 31451
2aab082ca000-2aab082f2000 r-xp 00000000 08:06 80577
/opt/gnome/lib64/libpangoft2-1.0.so.0.800.1
2aab082f2000-2aab083f1000 ---p 00028000 08:06 80577
2aab083f1000-2aab083f3000 rwxp 00027000 08:06 80577
2aab083f3000-2aab08414000 r-xp 00000000 08:06 24815
/usr/lib64/libexpat.so.0.5.0
2aab08414000-2aab08513000 ---p 00021000 08:06 24815
2aab08513000-2aab08516000 rwxp 00020000 08:06 24815
2aab08516000-2aab085ee000 r-xp 00000000 08:06 27936
/usr/lib/locale/en_US.utf8/LC_COLLATE
2aab085ee000-2aab085ef000 r-xp 00000000 08:06 25797
/usr/lib/locale/en_US.utf8/LC_TIME
2aab085ef000-2aab085f0000 r-xp 00000000 08:06 27912
/usr/lib/locale/en_US.utf8/LC_NUMERIC
2aab085f0000-2aab085f1000 r-xp 00000000 08:06 31318
/usr/X11R6/lib/X11/locale/lib64/common/xlcUTF8Load.so.2
2aab085f1000-2aab086f0000 ---p 00001000 08:06 31318
2aab086f0000-2aab086f1000 rwxp 00000000 08:06 31318
2aab086f1000-2aab086f3000 r-xp 00000000 08:06 27435
/usr/lib64/gconv/ISO8859-1.so
2aab086f3000-2aab087f2000 ---p 00002000 08:06 27435
2aab087f2000-2aab087f4000 rwxp 00001000 08:06 27435
2aab087f4000-2aab08832000 r-xp 00000000 08:06 405863
/home/stoil/EclipseWorkspaces/EclipseEclipse/org.eclipse.swt .gtk.linux.x86_64/libswt-gtk-3202.so
2aab08832000-2aab08932000 ---p 0003e000 08:06 405863
2aab08932000-2aab08936000 rwxp 0003e000 08:06 405863
2aab08936000-2aab08937000 rwxp 2aab08936000 00:00 0
2aab08937000-2aab08956000 r-xp 00000000 08:06 179951
/opt/gnome/lib64/gtk-2.0/2.4.0/engines/libqtengine.so
2aab08956000-2aab08a55000 ---p 0001f000 08:06 179951
2aab08a55000-2aab08a57000 rwxp 0001e000 08:06 179951
2aab08a57000-2aab09204000 r-xp 00000000 08:06 84250
/usr/lib/qt3/lib64/libqt-mt.so.3.3.4
2aab09204000-2aab09303000 ---p 007ad000 08:06 84250
2aab09303000-2aab09381000 rwxp 007ac000 08:06 84250
2aab09381000-2aab09386000 rwxp 2aab09381000 00:00 0
2aab09386000-2aab093a5000 r-xp 00000000 08:06 24329
/usr/X11R6/lib/X11/fonts/Type1/cour.pfa
2aab093a5000-2aab093b2000 r-xs 00000000 08:06 515975
/opt/eclipse64/plugins/org.eclipse.jdt.debug_3.1.0/jdi.jar
2aab093b5000-2aab093e0000 r-xp 00000000 08:06 29847
/usr/lib64/libpng.so.3.1.2.8
2aab093e0000-2aab094e0000 ---p 0002b000 08:06 29847
2aab094e0000-2aab094e1000 rwxp 0002b000 08:06 29847
2aab094e1000-2aab094f4000 r-xp 00000000 08:06 299720
/lib64/libz.so.1.2.2
2aab094f4000-2aab095f3000 ---p 00013000 08:06 299720
2aab095f3000-2aab095f4000 rwxp 00012000 08:06 299720
2aab095f4000-2aab095fd000 r-xp 00000000 08:06 31411
/usr/X11R6/lib64/libSM.so.6.0
2aab095fd000-2aab096fd000 ---p 00009000 08:06 31411
2aab096fd000-2aab096fe000 rwxp 00009000 08:06 31411
2aab096fe000-2aab09714000 r-xp 00000000 08:06 31409
/usr/X11R6/lib64/libICE.so.6.3
2aab09714000-2aab09814000 ---p 00016000 08:06 31409
2aab09814000-2aab09815000 rwxp 00016000 08:06 31409
2aab09815000-2aab09819000 rwxp 2aab09815000 00:00 0
2aab09819000-2aab098dc000 r-xp 00000000 08:06 31103
/usr/lib64/libstdc++.so.5.0.7
2aab098dc000-2aab099db000 ---p 000c3000 08:06 31103
2aab099db000-2aab099e3000 rwxp 000c2000 08:06 31103
2aab099e3000-2aab099f5000 rwxp 2aab099e3000 00:00 0
2aab099f5000-2aab099ff000 r-xp 00000000 08:06 29824
/lib64/libgcc_s.so.1
2aab099ff000-2aab09aff000 ---p 0000a000 08:06 29824
2aab09aff000-2aab09b00000 rwxp 0000a000 08:06 29824
2aab09b00000-2aab09c00000 rwxp 2aab09b00000 00:00 0
2aab09c00000-2aab09c15000 r-xp 00000000 08:06 245066
/opt/kde3/lib64/kde3/plugins/styles/dotnet.so
2aab09c15000-2aab09d14000 ---p 00015000 08:06 245066
2aab09d14000-2aab09d16000 rwxp 00014000 08:06 245066
2aab09d16000-2aab09d3c000 r-xp 00000000 08:06 377464
/usr/X11R6/lib/X11/fonts/truetype/verdanai.ttf
2aab09d45000-2aab09d71000 r-xp 00000000 08:06 159483
/opt/kde3/lib64/libkdefx.so.4.2.0
2aab09d71000-2aab09e70000 ---p 0002c000 08:06 159483
2aab09e70000-2aab09e73000 rwxp 0002b000 08:06 159483
2aab09e73000-2aab09ea9000 r-xp 00000000 08:06 159432
/opt/kde3/lib64/kde3/plugins/styles/keramik.so
2aab09ea9000-2aab09fa8000 ---p 00036000 08:06 159432
2aab09fa8000-2aab09fab000 rwxp 00035000 08:06 159432
2aab09fab000-2aab09fc2000 r-xp 00000000 08:06 245068
/opt/kde3/lib64/kde3/plugins/styles/phasestyle.so
2aab09fc2000-2aab0a0c2000 ---p 00017000 08:06 245068
2aab0a0c2000-2aab0a0c4000 rwxp 00017000 08:06 245068
2aab0a0c4000-2aab0a0e4000 r-xs 00000000 08:06 515963
/opt/eclipse64/plugins/org.eclipse.ltk.core.refactoring_3.1. 0.jar
2aab0a0f3000-2aab0a371000 r-xp 00000000 08:06 159474
/opt/kde3/lib64/libkdecore.so.4.2.0
2aab0a371000-2aab0a471000 ---p 0027e000 08:06 159474
2aab0a471000-2aab0a491000 rwxp 0027e000 08:06 159474
2aab0a491000-2aab0a494000 rwxp 2aab0a491000 00:00 0
2aab0a494000-2aab0a4cb000 r-xp 00000000 08:06 159442
/opt/kde3/lib64/libDCOP.so.4.2.0
2aab0a4cb000-2aab0a5cb000 ---p 00037000 08:06 159442
2aab0a5cb000-2aab0a5cd000 rwxp 00037000 08:06 159442
2aab0a5cd000-2aab0a5d1000 rwxp 2aab0a5cd000 00:00 0
2aab0a5d1000-2aab0a5e2000 r-xp 00000000 08:06 24665
/lib64/libresolv.so.2
2aab0a5e2000-2aab0a6e1000 ---p 00011000 08:06 24665
2aab0a6e1000-2aab0a6e3000 rwxp 00110000 08:06 24665
2aab0a6e3000-2aab0a6e5000 rwxp 2aab0a6e3000 00:00 0
2aab0a6e5000-2aab0a6e7000 r-xp 00000000 08:06 24668
/lib64/libutil.so.1
2aab0a6e7000-2aab0a7e6000 ---p 00002000 08:06 24668
/lib64/libutil.so.1
2aab0a7e6000-2aab0a7e8000 rwxp 00001000 08:06 24668
/lib64/libutil.so.1
2aab0a7e8000-2aab0a7fe000 r-xp 00000000 08:06 28071
/usr/lib64/libart_lgpl_2.so.2.3.17
2aab0a7fe000-2aab0a8fe000 ---p 00016000 08:06 28071
2aab0a8fe000-2aab0a8ff000 rwxp 00016000 08:06 28071
2aab0a8ff000-2aab0a92e000 r-xp 00000000 08:06 33899
/usr/lib64/libidn.so.11.5.2
2aab0a92e000-2aab0aa2e000 ---p 0002f000 08:06 33899
2aab0aa2e000-2aab0aa30000 rwxp 0002f000 08:06 33899
2aab0aa30000-2aab0aa4f000 r-xp 00000000 08:06 159438
/opt/kde3/lib64/kde3/plugins/styles/plastik.so
2aab0aa4f000-2aab0ab4e000 ---p 0001f000 08:06 159438
2aab0ab4e000-2aab0ab50000 rwxp 0001e000 08:06 159438
2aab0ab50000-2aab0ab63000 r-xp 00000000 08:06 159427
/opt/kde3/lib64/kde3/plugins/styles/highcolor.so
2aab0ab63000-2aab0ac62000 ---p 00013000 08:06 159427
2aab0ac62000-2aab0ac64000 rwxp 00012000 08:06 159427
2aab0ac64000-2aab0ac72000 r-xp 00000000 08:06 159430
/opt/kde3/lib64/kde3/plugins/styles/highcontrast.so
2aab0ac72000-2aab0ad72000 ---p 0000e000 08:06 159430
2aab0ad72000-2aab0ad73000 rwxp 0000e000 08:06 159430
2aab0ad73000-2aab0ad9d000 r-xp 00000000 08:06 159434
/opt/kde3/lib64/kde3/plugins/styles/kthemestyle.so
2aab0ad9d000-2aab0ae9c000 ---p 0002a000 08:06 159434
2aab0ae9c000-2aab0ae9e000 rwxp 00029000 08:06 159434
2aab0ae9e000-2aab0aea5000 r-xp 00000000 08:06 84254
/usr/lib/qt3/plugins/imageformats/libqjpeg.lib64.so
2aab0aea5000-2aab0afa4000 ---p 00007000 08:06 84254
2aab0afa4000-2aab0afa5000 rwxp 00006000 08:06 84254
2aab0afa5000-2aab0afc4000 r-xp 00000000 08:06 24333
/usr/X11R6/lib/X11/fonts/Type1/courbi.pfa
2aab0afd4000-2aab0aff4000 r-xp 00000000 08:06 28209
/usr/lib64/libjpeg.so.62.0.0
2aab0aff4000-2aab0b0f4000 ---p 00020000 08:06 28209
2aab0b0f4000-2aab0b0f5000 rwxp 00020000 08:06 28209
2aab0b0f5000-2aab0b1f5000 rwxp 2aab0b0f5000 00:00 0
2aab0b1f5000-2aab0b1fa000 r-xp 00000000 08:06 85769
/usr/lib/qt3/plugins/imageformats/libqmng.lib64.so
2aab0b1fa000-2aab0b2fa000 ---p 00005000 08:06 85769
2aab0b2fa000-2aab0b2fb000 rwxp 00005000 08:06 85769
2aab0b2fb000-2aab0b30c000 r-xs 00000000 08:06 516931
/opt/eclipse64/plugins/org.eclipse.core.commands_3.2.0.jar
2aab0b30c000-2aab0b319000 r-xs 00000000 08:06 515865
/opt/eclipse64/plugins/org.eclipse.core.expressions_3.1.0.ja r
2aab0b32a000-2aab0b397000 r-xp 00000000 08:06 45088
/usr/lib64/libmng.so.1.1.0.9
2aab0b397000-2aab0b496000 ---p 0006d000 08:06 45088
2aab0b496000-2aab0b49b000 rwxp 0006c000 08:06 45088
2aab0b49b000-2aab0b4c9000 r-xp 00000000 08:06 40020
/usr/lib64/liblcms.so.1.0.14
2aab0b4c9000-2aab0b5c9000 ---p 0002e000 08:06 40020
2aab0b5c9000-2aab0b5cb000 rwxp 0002e000 08:06 40020
2aab0b5cb000-2aab0b5cd000 rwxp 2aab0b5cb000 00:00 0
2aab0b5cd000-2aab0b663000 r-xs 00000000 08:06 515964
/opt/eclipse64/plugins/org.eclipse.core.resources_3.1.0.jar
2aab0b663000-2aab0b67f000 r-xs 00000000 08:06 516734
/opt/eclipse64/plugins/org.eclipse.core.resources.compatibil ity_3.1.0.jar
2aab0b67f000-2aab0b686000 r-xs 00000000 08:06 516926
/opt/eclipse64/plugins/org.eclipse.core.resources.linux_3.1. 0.jar
2aab0b686000-2aab0b886000 rwxp 2aab0b686000 00:00 0
2aab0b886000-2aab0b888000 r-xp 00000000 08:06 437531
/opt/eclipse64/configuration/org.eclipse.osgi/bundles/69/1/. cp/os/linux/x86_64/libcore_3_1_0.so
2aab0b888000-2aab0b987000 ---p 00002000 08:06 437531
2aab0b987000-2aab0b988000 rwxp 00001000 08:06 437531
2aab0b988000-2aab0b9be000 r-xs 00000000 08:06 515863
/opt/eclipse64/plugins/org.eclipse.team.core_3.1.0.jar
2aab0b9be000-2aab0b9dd000 r-xp 00000000 08:06 24331
/usr/X11R6/lib/X11/fonts/Type1/courb.pfa
2aab0b9dd000-2aab0b9fb000 r-xp 00000000 08:06 24335
/usr/X11R6/lib/X11/fonts/Type1/couri.pfa
2aab0b9ff000-2aab0baff000 rwxp 2aab0b9ff000 00:00 0
2aab0baff000-2aab0bb22000 r-xs 00000000 08:06 516924
/opt/eclipse64/plugins/org.eclipse.ltk.ui.refactoring_3.1.0. jar
2aab0bb31000-2aab0bc31000 rwxp 2aab0bb31000 00:00 0
2aab0bc31000-2aab0bc33000 r-xp 00000000 08:06 80586
/opt/gnome/lib64/pango/1.4.0/modules/pango-basic-fc.so
2aab0bc33000-2aab0bd32000 ---p 00002000 08:06 80586
2aab0bd32000-2aab0bd33000 rwxp 00001000 08:06 80586
2aab0bd33000-2aab0bd56000 r-xp 00000000 08:06 377466
/usr/X11R6/lib/X11/fonts/truetype/verdana.ttf
2aab0bd56000-2aab0bdfa000 r-xs 00000000 08:06 516855
/opt/eclipse64/plugins/org.eclipse.jface.text_3.1.0.jar
2aab0be16000-2aab0c116000 rwxp 2aab0be16000 00:00 0
2aab0c116000-2aab0c17d000 r-xs 00000000 08:06 516922
/opt/eclipse64/plugins/org.eclipse.ui.editors_3.1.0.jar
2aab0c17f000-2aab0c27f000 rwxp 2aab0c17f000 00:00 0
2aab0c27f000-2aab0c2a0000 r-xs 00000000 08:06 516852
/opt/eclipse64/plugins/org.eclipse.ui.console_3.1.0.jar
2aab0c2a8000-2aab0c3a8000 rwxp 2aab0c2a8000 00:00 0
2aab0c3a8000-2aab0c3d5000 r-xs 00000000 08:06 516376
/opt/eclipse64/plugins/org.eclipse.text_3.1.0.jar
2aab0c3d5000-2aab0c406000 r-xs 00000000 08:06 516645
/opt/eclipse64/plugins/org.eclipse.jdt.launching_3.1.0.jar
2aab0c43a000-2aab0c73a000 rwxp 2aab0c43a000 00:00 0
2aab0c73a000-2aab0c7a6000 r-xs 00000000 08:06 516059
/opt/eclipse64/plugins/org.eclipse.ui.workbench.texteditor_3 .1.0.jar
2aab0c7a6000-2aab0c7e0000 r-xs 00000000 08:06 516934
/opt/eclipse64/plugins/org.eclipse.debug.core_3.1.0.jar
2aab0c7e0000-2aab0c87e000 r-xs 00000000 08:06 516907
/opt/eclipse64/plugins/org.eclipse.team.ui_3.1.0.jar
2aab0c88f000-2aab0c98f000 rwxp 2aab0c88f000 00:00 0
2aab0c98f000-2aab0ca43000 r-xs 00000000 08:06 515976
/opt/eclipse64/plugins/org.eclipse.jdt.debug_3.1.0/jdimodel. jar
2aab0ca65000-2aab0cd65000 rwxp 2aab0ca65000 00:00 0
2aab0cd65000-2aab0ceac000 r-xs 00000000 08:06 516930
/opt/eclipse64/plugins/org.eclipse.debug.ui_3.1.0.jar
2aab0cf00000-2aab0d000000 rwxp 2aab0cf00000 00:00 0
2aab0d000000-2aab0d05e000 r-xs 00000000 08:06 516021
/opt/eclipse64/plugins/org.eclipse.search_3.1.0.jar
2aab0d100000-2aab0d1fd000 rwxp 2aab0d100000 00:00 0
2aab0d1fd000-2aab0d200000 ---p 2aab0d1fd000 00:00 0
2aab0d200000-2aab0d2f9000 rwxp 2aab0d200000 00:00 0
2aab0d2f9000-2aab0d300000 ---p 2aab0d2f9000 00:00 0
2aab0d300000-2aab0d4fe000 rwxp 2aab0d300000 00:00 0
2aab0d4fe000-2aab0d500000 ---p 2aab0d4fe000 00:00 0
2aab0d500000-2aab0db98000 r-xs 00000000 08:06 515794
/opt/eclipse64/plugins/org.eclipse.jdt.ui_3.1.0.jar
2aab0db98000-2aab0db9b000 rwxs 00000000 00:07 6029326
2aab0db9b000-2aab0dbfb000 rwxs 00000000 00:07 6062096
2aab0dc00000-2aab0dcff000 rwxp 2aab0dc00000 00:00 0
2aab0dcff000-2aab0dd00000 ---p 2aab0dcff000 00:00 0
2aab0dd00000-2aab0e067000 r-xs 00000000 08:06 516923
/opt/eclipse64/plugins/org.eclipse.jdt.core_3.1.0.jar
2aab0e067000-2aab0e16f000 r-xs 00000000 08:06 516853
/opt/eclipse64/plugins/org.eclipse.jdt.debug.ui_3.1.0.jar
2aab0e16f000-2aab0e296000 r-xs 00000000 08:06 516609
/opt/eclipse64/plugins/org.eclipse.team.cvs.ui_3.1.0.jar
2aab0e296000-2aab0e38c000 r-xs 00000000 08:06 515973
/opt/eclipse64/plugins/org.eclipse.ant.ui_3.1.0.jar
2aab0e38c000-2aab0e401000 r-xs 00000000 08:06 515983
/opt/eclipse64/plugins/org.eclipse.pde.core_3.1.0.jar
2aab0e45d000-2aab0e471000 r-xp 00000000 08:06 255369
/opt/gnome/lib64/libgnome-2.so.0.1000.0
2aab0e471000-2aab0e571000 ---p 00014000 08:06 255369
2aab0e571000-2aab0e573000 rwxp 00014000 08:06 255369
2aab0e573000-2aab0e673000 rwxp 2aab0e573000 00:00 0
2aab0e67a000-2aab0e67d000 r-xp 00000000 08:06 115388
/home/stoil/EclipseWorkspaces/EclipseEclipse/org.eclipse.swt .gtk.linux.x86_64/libswt-gnome-gtk-3202.so
2aab0e67d000-2aab0e77d000 ---p 00003000 08:06 115388
2aab0e77d000-2aab0e77e000 rwxp 00003000 08:06 115388
2aab0e7ad000-2aab0e813000 r-xp 00000000 08:06 211719
/opt/gnome/lib64/libgnomevfs-2.so.0.1000.0
2aab0e813000-2aab0e913000 ---p 00066000 08:06 211719
2aab0e913000-2aab0e91b000 rwxp 00066000 08:06 211719
2aab0e91b000-2aab0e91c000 rwxp 2aab0e91b000 00:00 0
2aab0e91c000-2aab0e9ac000 r-xp 00000000 08:06 262044
/opt/gnome/lib64/libgnomeui-2.so.0.1000.0
2aab0e9ac000-2aab0eaab000 ---p 00090000 08:06 262044
2aab0eaab000-2aab0eab1000 rwxp 0008f000 08:06 262044
2aab0eab1000-2aab0eae7000 r-xp 00000000 08:06 107038
/opt/gnome/lib64/libgconf-2.so.4.1.0
2aab0eae7000-2aab0ebe6000 ---p 00036000 08:06 107038
2aab0ebe6000-2aab0ebeb000 rwxp 00035000 08:06 107038
2aab0ebeb000-2aab0ec4c000 r-xp 00000000 08:06 93221
/opt/gnome/lib64/libbonobo-2.so.0.0.0
2aab0ec4c000-2aab0ed4b000 ---p 00061000 08:06 93221
2aab0ed4b000-2aab0ed5c000 rwxp 00060000 08:06 93221
2aab0ed5c000-2aab0ed72000 r-xp 00000000 08:06 93223
/opt/gnome/lib64/libbonobo-activation.so.4.0.0
2aab0ed72000-2aab0ee72000 ---p 00016000 08:06 93223
2aab0ee72000-2aab0ee76000 rwxp 00016000 08:06 93223
2aab0ee76000-2aab0eecf000 r-xp 00000000 08:06 80557
/opt/gnome/lib64/libORBit-2.so.0.0.0
2aab0eecf000-2aab0efcf000 ---p 00059000 08:06 80557
2aab0efcf000-2aab0efe1000 rwxp 00059000 08:06 80557
2aab0efe1000-2aab0f0eb000 r-xp 00000000 08:06 78630
/usr/lib64/libxml2.so.2.6.17
2aab0f0eb000-2aab0f1eb000 ---p 0010a000 08:06 78630
2aab0f1eb000-2aab0f1f7000 rwxp 0010a000 08:06 78630
2aab0f1f7000-2aab0f200000 rwxp 2aab0f1f7000 00:00 0
2aab0f200000-2aab0f230000 r-xp 00000000 08:06 95580
/usr/lib64/libssl.so.0.9.7
2aab0f230000-2aab0f330000 ---p 00030000 08:06 95580
2aab0f330000-2aab0f335000 rwxp 00030000 08:06 95580
2aab0f335000-2aab0f446000 r-xp 00000000 08:06 95578
/usr/lib64/libcrypto.so.0.9.7
2aab0f446000-2aab0f545000 ---p 00111000 08:06 95578
2aab0f545000-2aab0f564000 rwxp 00110000 08:06 95578
2aab0f564000-2aab0f568000 rwxp 2aab0f564000 00:00 0
2aab0f568000-2aab0f56f000 r-xp 00000000 08:06 429801
/lib64/tls/librt.so.1
2aab0f56f000-2aab0f66e000 ---p 00007000 08:06 429801
2aab0f66e000-2aab0f670000 rwxp 00006000 08:06 429801
2aab0f670000-2aab0f679000 r-xp 00000000 08:06 118510
/usr/lib64/libesd.so.0.2.35
2aab0f679000-2aab0f779000 ---p 00009000 08:06 118510
2aab0f779000-2aab0f77a000 rwxp 00009000 08:06 118510
2aab0f77a000-2aab0f79d000 r-xp 00000000 08:06 31783
/usr/lib64/libaudiofile.so.0.0.2
2aab0f79d000-2aab0f89d000 ---p 00023000 08:06 31783
2aab0f89d000-2aab0f8a1000 rwxp 00023000 08:06 31783
2aab0f8a1000-2aab0f8a8000 r-xp 00000000 08:06 28659
/usr/lib64/libpopt.so.0.0.0
2aab0f8a8000-2aab0f9a7000 ---p 00007000 08:06 28659
2aab0f9a7000-2aab0f9a8000 rwxp 00006000 08:06 28659
2aab0f9a8000-2aab0fa0f000 r-xp 00000000 08:06 264548
/opt/gnome/lib64/libbonoboui-2.so.0.0.0
2aab0fa0f000-2aab0fb0f000 ---p 00067000 08:06 264548
2aab0fb0f000-2aab0fb14000 rwxp 00067000 08:06 264548
2aab0fb14000-2aab0fb40000 r-xp 00000000 08:06 119927
/opt/gnome/lib64/libgnomecanvas-2.so.0.1000.0
2aab0fb40000-2aab0fc40000 ---p 0002c000 08:06 119927
2aab0fc40000-2aab0fc42000 rwxp 0002c000 08:06 119927
2aab0fc42000-2aab0fc4d000 r-xp 00000000 08:06 107207
/opt/gnome/lib64/libgnome-keyring.so.0.0.1
2aab0fc4d000-2aab0fd4c000 ---p 0000b000 08:06 107207
2aab0fd4c000-2aab0fd4d000 rwxp 0000a000 08:06 107207
2aab0fd4d000-2aab0fd52000 r-xp 00000000 08:06 80561
/opt/gnome/lib64/libORBitCosNaming-2.so.0.0.0
2aab0fd52000-2aab0fe51000 ---p 00005000 08:06 80561
2aab0fe51000-2aab0fe53000 rwxp 00004000 08:06 80561
2aab0fe53000-2aab0ff16000 r-xp 00000000 08:06 105791
/usr/lib64/libasound.so.2.0.0
2aab0ff16000-2aab10016000 ---p 000c3000 08:06 105791
2aab10016000-2aab1001e000 rwxp 000c3000 08:06 105791
2aab1001e000-2aab10021000 r-xp 00000000 08:06 96600
/lib64/libresmgr.so.0.9.8
2aab10021000-2aab10121000 ---p 00003000 08:06 96600
2aab10121000-2aab10122000 rwxp 00003000 08:06 96600
2aab10200000-2aab103ee000 rwxp 2aab10200000 00:00 0
2aab103ee000-2aab10400000 ---p 2aab103ee000 00:00 0
2aab10400000-2aab104fa000 rwxp 2aab10400000 00:00 0
2aab104fa000-2aab10500000 ---p 2aab104fa000 00:00 0
2aab10500000-2aab10700000 rwxp 2aab10500000 00:00 0
2aab10700000-2aab10800000 rwxp 2aab10700000 00:00 0
2aab10800000-2aab10807000 r-xp 00000000 08:06 211705
/opt/gnome/lib64/gnome-vfs-2.0/modules/libfile.so
2aab10807000-2aab10907000 ---p 00007000 08:06 211705
2aab10907000-2aab10908000 rwxp 00007000 08:06 211705
2aab10937000-2aab1093f000 r-xp 00000000 08:06 43249
/usr/lib64/libfam.so.0.0.0
2aab1093f000-2aab10a3e000 ---p 00008000 08:06 43249
2aab10a3e000-2aab10a3f000 rwxp 00007000 08:06 43249
2aab10a6e000-2aab10a78000 r-xp 00000000 08:06 429728
/lib64/libnss_files.so.2
2aab10a78000-2aab10b77000 ---p 0000a000 08:06 429728
2aab10b77000-2aab10b79000 rwxp 00009000 08:06 429728
2aab10b79000-2aab10e05000 r-xs 00000000 08:06 516593
/opt/eclipse64/plugins/org.eclipse.pde.ui_3.1.0.jar
2aab10f00000-2aab110f7000 rwxp 2aab10f00000 00:00 0
2aab110f7000-2aab11100000 ---p 2aab110f7000 00:00 0
2aab11100000-2aab112fa000 rwxp 2aab11100000 00:00 0
2aab112fa000-2aab11300000 ---p 2aab112fa000 00:00 0
2aab11300000-2aab115f1000 rwxp 2aab11300000 00:00 0
2aab115f1000-2aab11600000 ---p 2aab115f1000 00:00 0
2aab11600000-2aab117f1000 rwxp 2aab11600000 00:00 0
2aab117f1000-2aab11800000 ---p 2aab117f1000 00:00 0
2aab11821000-2aab11921000 rwxp 2aab11821000 00:00 0
2aab11967000-2aab11a67000 rwxp 2aab11967000 00:00 0
2aab11b00000-2aab12421000 rwxp 2aab11b00000 00:00 0
2aab12421000-2aab12500000 ---p 2aab12421000 00:00 0
2aab12627000-2aab12727000 rwxp 2aab12627000 00:00 0
2aab12748000-2aab12848000 rwxp 2aab12748000 00:00 0
2aab12c00000-2aab12f00000 rwxp 2aab12c00000 00:00 0
2aab135e3000-2aab13601000 r-xs 00000000 08:06 516933
/opt/eclipse64/plugins/org.eclipse.ui.externaltools_3.1.0.ja r
2aab13601000-2aab13676000 r-xs 00000000 08:06 515650
/opt/eclipse64/plugins/org.eclipse.team.cvs.core_3.1.0.jar
2aab13a00000-2aab13af9000 rwxp 2aab13a00000 00:00 0
2aab13af9000-2aab13b00000 ---p 2aab13af9000 00:00 0
2aab13b00000-2aab13bf1000 rwxp 2aab13b00000 00:00 0
2aab13bf1000-2aab13c00000 ---p 2aab13bf1000 00:00 0
2aab13c00000-2aab13cf9000 rwxp 2aab13c00000 00:00 0
2aab13cf9000-2aab13d00000 ---p 2aab13cf9000 00:00 0
2aab13d00000-2aab13df1000 rwxp 2aab13d00000 00:00 0
2aab13df1000-2aab13e00000 ---p 2aab13df1000 00:00 0
2aab13e00000-2aab13ef9000 rwxp 2aab13e00000 00:00 0
2aab13ef9000-2aab13f00000 ---p 2aab13ef9000 00:00 0
2aab13f00000-2aab13ff9000 rwxp 2aab13f00000 00:00 0
2aab13ff9000-2aab14000000 ---p 2aab13ff9000 00:00 0
2aab14000000-2aab140f1000 rwxp 2aab14000000 00:00 0
2aab140f1000-2aab14100000 ---p 2aab140f1000 00:00 0
2aab14100000-2aab141f9000 rwxp 2aab14100000 00:00 0
2aab141f9000-2aab14200000 ---p 2aab141f9000 00:00 0
2aab14200000-2aab142f9000 rwxp 2aab14200000 00:00 0
2aab142f9000-2aab14300000 ---p 2aab142f9000 00:00 0
2aab14300000-2aab143f9000 rwxp 2aab14300000 00:00 0
2aab143f9000-2aab14400000 ---p 2aab143f9000 00:00 0
2aab14400000-2aab144f9000 rwxp 2aab14400000 00:00 0
2aab144f9000-2aab14500000 ---p 2aab144f9000 00:00 0
2aab14500000-2aab145f9000 rwxp 2aab14500000 00:00 0
2aab145f9000-2aab14600000 ---p 2aab145f9000 00:00 0
2aab14600000-2aab146f1000 rwxp 2aab14600000 00:00 0
2aab146f1000-2aab14700000 ---p 2aab146f1000 00:00 0
2aab14700000-2aab147f9000 rwxp 2aab14700000 00:00 0
2aab147f9000-2aab14800000 ---p 2aab147f9000 00:00 0
2aab14800000-2aab148f1000 rwxp 2aab14800000 00:00 0
2aab148f1000-2aab14900000 ---p 2aab148f1000 00:00 0
2aab14900000-2aab149f9000 rwxp 2aab14900000 00:00 0
2aab149f9000-2aab14a00000 ---p 2aab149f9000 00:00 0
2aab14a00000-2aab14af9000 rwxp 2aab14a00000 00:00 0
2aab14af9000-2aab14b00000 ---p 2aab14af9000 00:00 0
2aab14b00000-2aab14bf1000 rwxp 2aab14b00000 00:00 0
2aab14bf1000-2aab14c00000 ---p 2aab14bf1000 00:00 0
2aab14c00000-2aab14cf9000 rwxp 2aab14c00000 00:00 0
2aab14cf9000-2aab14d00000 ---p 2aab14cf9000 00:00 0
2aab14d00000-2aab14dfd000 rwxp 2aab14d00000 00:00 0
2aab14dfd000-2aab14e00000 ---p 2aab14dfd000 00:00 0
2aab14e00000-2aab14f00000 rwxp 2aab14e00000 00:00 0
Here comes my classpath. It is not interesting I suppose.
VM Arguments:
jvm_args: -Xmx256M
-Djava.library.path=/home/stoil/EclipseWorkspaces/EclipseEcl ipse/org.eclipse.swt.gtk.linux.x86_64
-Dswt.version=3202
java_command: /opt/eclipse64/startup.jar -os linux -ws gtk -arch x86_64
-launcher /opt/eclipse64/eclipse -name Eclipse -showsplash 600 -exitdata
5a8008 -data /home/stoil/EclipseWorkspaces/EclipseWorkspace_HEAD -vm
/usr/java/jdk1.5.0_04/bin/java -vmargs -server -Xmx256M
-Dswt.version=3202 -jar /opt/eclipse64/startup.jar
Environment Variables:
JAVA_HOME=/usr/java/jdk1.5.0_04
JRE_HOME=/usr/java/jdk1.5.0_04/jre
PATH=/usr/java/jdk1.5.0_04/bin:/usr/java/jdk1.5.0_04/jre/jav aws:/usr/java/jdk1.5.0_04/bin:/usr/java/jdk1.5.0_04/jre/java ws:/home/stoil/bin:/usr/local/bin:/usr/bin:/usr/X11R6/bin:/b in:/usr/games:/opt/gnome/bin:/opt/kde3/bin
LD_LIBRARY_PATH=/usr/java/jdk1.5.0_04/jre/lib/amd64/server:/ usr/java/jdk1.5.0_04/jre/lib/amd64:/usr/java/jdk1.5.0_04/jre /../lib/amd64:/usr/X11R6/lib64:/usr/X11R6/lib:/opt/mozilla/l ib64
SHELL=/bin/bash
DISPLAY=:0.0
HOSTTYPE=x86_64
OSTYPE=linux
MACHTYPE=x86_64-suse-linux
Signal Handlers:
SIGSEGV: [libjvm.so+0x5f6fc0], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGBUS: [libjvm.so+0x5f6fc0], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGFPE: [libjvm.so+0x517300], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGPIPE: SIG_IGN, sa_mask[0]=0x00001000, sa_flags=0x14000000
SIGILL: [libjvm.so+0x517300], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x5190e0], sa_mask[0]=0x00000000, sa_flags=0x14000004
SIGHUP: [libjvm.so+0x518bb0], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGINT: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGQUIT: [libjvm.so+0x518bb0], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGTERM: [libjvm.so+0x518bb0], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
--------------- S Y S T E M ---------------
OS:SuSE Linux 9.3 (x86-64)
VERSION = 9.3
uname:Linux 2.6.11.4-21.8-default #1 Tue Jul 19 12:42:37 UTC 2005 x86_64
libc:glibc 2.3.4 NPTL 2.3.4
rlimit: STACK infinity, CORE 0k, NPROC 7671, NOFILE 1024, AS infinity
load average:5.85 3.57 2.17
CPU:total 1 amd64 3dnow
Memory: 4k page, physical 960260k(9096k free), swap 4096532k(3724856k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (1.5.0_04-b05) for
linux-amd64, built on Jun 3 2005 01:50:28 by java_re with gcc 3.2.2
(SuSE Linux)
Re: swt 64bit keeps crashing in SuSE 64 [message #460437 is a reply to message #460433] |
Fri, 26 August 2005 13:13 |
> system swt.
This is a known bug in the JIT.
Please report to the VM vendor.
Olivier
Current Time: Fri Mar 29 01:16:09 GMT 2024
Powered by FUDForum. Page generated in 0.05358 seconds
