Re: SWT Layouts.. [message #460369 is a reply to message #460362] |
Wed, 24 August 2005 13:37 |
Olivier Chalouhi Messages: 10 Registered: July 2009 |
Matt,
The StackLayout is what your need.
Make sure you call shell.layout() after changing the topControl value of
the layout.
Olivier.
Matt wrote:
> I'm trying to fill a screen with a composite, then at somepoint this composite gets hidden, and a new one is created which also needs to fill the screen.. eventually this is disposed and the original composite is called back with setVisible(true).
> Now, before I used layout managers within these composites I was simply using setSize( screen width, height) to fill the screen with them. But this seems to no longer work (just a white screen appears).
> So I decided to try using fill layout on the shell; which works for the first screen, but no matter what I do (create new filllayout/call layout() etc.) I can't get the second to appear.. (once again it will just turn into a white screen).
> Argh, help? :)
> Coding this for a pocketpc, first time using SWT.
FUDForum. Page generated in 1.70565 seconds
