Home » Eclipse Projects » Rich Client Platform (RCP) » java.lang.NullPointer
java.lang.NullPointer [message #460146] Fri, 15 December 2006 02:26 Go to next message
i'm doing birt report integrating with eclipse rcp.
in the action file below:
protected Action printAction = new Action(){
{ setText("Print");
setId("print");
public void run() {
String frmSql = "FROM SP_PO inner join SP_PO_ITEM on
SP_PO.ID=SP_PO_ITEM.PO_ID ";
String whrSql = "WHERE SP_PO.ID='07' ";
String sql = frmSql+whrSql;
String uri =
Global.BIRT_REPORT_PATH+"Sp_Req_print.rptdesign&stmt= "+sql+"";
WebBrowser wb = new WebBrowser();
try {
wb = (WebBrowser)site.getPage().showView(WebBrowser.ID_VIEW);
wb.setUrl(uri);
} catch (PartInitException e) {
e.printStackTrace();
i got this error:
Unhandled event loop exception
Reason:
can anyone tell me how to solve the null pointer error??
Re: java.lang.NullPointer [message #460149 is a reply to message #460146] Fri, 15 December 2006 03:38 Go to previous message
Originally posted by: remy.suen.gmail.com
yl wrote:
> i got this error:
> Reason:
Try rerunning your application with '-consoleLog' as a "Program
Argument". It should provide you with an actual stack trace to resolve
this issue.
Rem
Previous Topic:Switch workspace question
Next Topic:Reusing PropertySheetPage in dialogs and wizards
Current Time: Wed Apr 30 04:32:16 EDT 2025
Powered by FUDForum. Page generated in 0.06852 seconds
