Home » Eclipse Projects » Rich Client Platform (RCP) » Problem with refreshing an OutlinePage
Problem with refreshing an OutlinePage [message #459722] Wed, 06 December 2006 18:50 Go to next message
Hi there,
i want to completely refresh an outlinepage and the only way that i have
found so far, is to dispose the object and readd it. So i dispose the
object, remove all listeners (the outline part becomes gray) and then
re-add it. But the part of the window, where the new outline should be
displayed, stays gray. If i now click in this gray area, i get the
message "An error has occurred when activating this view".
My code for removal and re-adding looks like this:
Method, that initiates the whole procedure:
getActionRegistry().removeAction(outlinePageAction);
removeContentOutlinePage();
outlinePageAction = new ShowActivityAction(this, getContentOutlinePage());
getActionRegistry().registerAction(outlinePageAction);
removeContentOutlinePage():
if (outlinePage != null)
((ModelContentOutlinePage)
outlinePage).getContextMenuManager().removeMenuListener(getC ontextMenuProvider());
getSelectionSynchronizer().removeSelectionProvider(outlinePa ge);
outlinePage.dispose();
outlinePage = null;
getContentOutlinePage():
if (outlinePage == null)
outlinePage = new ModelContentOutlinePage(this);
getSelectionSynchronizer().addSelectionProvider(outlinePage) ;
((ModelContentOutlinePage) outlinePage).getContextMenuManager()
.addMenuListener(getContextMenuProvider());
return outlinePage;
Thanks for help!
Wolf
Re: Problem with refreshing an OutlinePage [message #459826 is a reply to message #459722] Thu, 07 December 2006 07:51 Go to previous messageGo to next message
When you created your outline page, you were handed a Composite parent
in createControl(*).
Normally it's:
Composite myComposite = new Composite(parent, SWT.NONE);
myComposite.setLayout(new FillLayout()); // set appropriate layout
// add controls.
When your information changes and you add or dispose child Controls, or
update child labels, you would call myComposite.layout();
If you really want to clean it out, you can save parent in your outline
page, and the dispose and re-create myComposite.
Or is this not the behaviour you want.
Later,
PW
Re: Problem with refreshing an OutlinePage [message #459868 is a reply to message #459826] Thu, 07 December 2006 20:50 Go to previous message
Hi Paul,
that helped :)
Wolf
> Normally it's:
> // add controls.
> Later,
> PW
Previous Topic:Decorations on filtered items in a tree
Next Topic:What happens with my Problem View ?
Current Time: Sat Apr 26 11:43:31 EDT 2025
Powered by FUDForum. Page generated in 0.03660 seconds
