Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Importing images from MS Access
Importing images from MS Access [message #458908] Tue, 26 July 2005 07:37 Go to next message
Originally posted by: friederich.kupzog.de
Hi newsgroup,
currently I am trying to import data from a MS Access Database to a Java
SWT Application. I connected to the databse using the jdbc-odbc-bridge.
The database contains images. The only possibility to store images in
Access is to use the "OLE" field type. I can read the OLE data using
ResultSet.getBytes() but i cannot find a way to convert the data in such
a way that I can construct a swt Image using this data.
Unfortunately I have virtually no knowledge about OLE, so can anyone
give me a hint?
Thank you very much in advance,
Friederich
Friederich Kupzog
Elektronik & Software
Neusser Str. 5-7
50670 Köln
Tel 0241 160696-1
Fax 0221 726670
www.kupzog.de/fkmk
Re: Importing images from MS Access [message #458914 is a reply to message #458908] Tue, 26 July 2005 11:10 Go to previous messageGo to next message
Originally posted by: joerg.von.frantzius.artnology.nospam.com
Friederich Kupzog schrieb:
> Hi newsgroup,
> give me a hint?
> Friederich
Have you made sure that the bytes you get isn't just the image bytes?
Have you tried
InputStream inputStream = new
ByteArrayInputStream(rs.getImageBytes());
result = new ImageData(inputStream);
Re: Importing images from MS Access [message #458949 is a reply to message #458914] Wed, 27 July 2005 08:34 Go to previous messageGo to next message
>> Hi newsgroup,
>> give me a hint?
>> Friederich
> Have you tried
Sorry that should read
ByteArrayInputStream(rs.getBytes(colIndex));
But you probably have tried it. What kind of image are they, is it JPEG,
GIF or something else? Maybe it's just something exotic that SWT doesn't
support directly? The point being here that there might not be any OLE
programming necessary.
Re: Importing images from MS Access [message #458973 is a reply to message #458949] Wed, 27 July 2005 15:48 Go to previous message
Hi Joerg,
thanks for your reply. Unfortunately this does not work, I get a
Exception (unrecognised format).
The problem is that there can be any image format in these silly OLE
fields. Users simply cut&paste data from any source into the original
Access database. There might even be a Word document in it. I thought
there might be a way to retrieve information about the OLE content type
and then get the data somehow.
Anyone has any other idea?
Thanks a lot
Friederich
Friederich Kupzog
Neusser Str. 5-7
50670 Köln
Tel 0241 160696-1
Fax 0221 726670
www.kupzog.de/fkmk
Previous Topic:SWT exception kills VM
Next Topic:HIDE_SELECTION in Table
Current Time: Fri Nov 27 04:29:28 GMT 2020
Powered by FUDForum. Page generated in 0.02281 seconds
