Re: Want to show Tree selection when tree does not have focus [message #458716 is a reply to message #458714] |
Wed, 20 July 2005 00:30 |
Agnes Freese Messages: 14 Registered: July 2009 |
Hi Veronika,
Thanks for your response.
It appears that my problem is one of color selection. The Tree control in
3.1 with columns shows white grid lines. I got another response from
someone else saying that this was something that I cannot change. If you
can also verify this I would appreciate it.
Because of the white grid lines (TableTree used to have black or gray grid
lines), I had to set a color for the background of the Tree so I could see
the white lines. Unfortunately, the color I chose is the same as the
highlight color for the selected item when the tree is out of focus. When I
set the background back to white, I can see the selection.
It is rather disappointing that the grid lines are white in 3.1. This makes
it necessary to select colors for the background. Is there any chance of
some default color being selected for the background that is not white like
the lines so that the initial implementation will show the lines?
Agnes
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:dbjovd$nlh$1@news.eclipse.org...
> On Windows XP with Service Pack 2, I see selection even when the tree does
> not have focus.
> The selection is blue when the tree has focus and gray when the tree does
> not have focus but it is definitely visible.
> Please enter a bug report against Platform SWT and we will try to figure
out
> what is the problem for you.
> "Agnes Freese" <afreese@siebel.com> wrote in message
> news:dbj6jf$vng$1@news.eclipse.org...
> > OS Name Microsoft Windows XP Professional
> > Version 5.1.2600 Service Pack 2 Build 2600
> > news:dbj54n$th5$1@news.eclipse.org...
> >> What platform are you running on? This sounds like a bug.
> >> news:dbgvrq$g3k$1@news.eclipse.org...
> >> > Hi,
> >> > I have a composite control that contains two Tree controls. The
> > selected
> >> > item in each tree is shown only when the particular tree has focus.
I
> >> > would
> >> > like to be able to highlight or show the selected items in both trees
> >> > regardless of which has focus. Is there any way to do this?
> >> > I have tried doing things like changing the background color of the
> >> > selected
> >> > item in the tree that has lost focus, but I do not seem to be able to
> > get
> >> > the tree to refresh/repaint until it is back in focus again.
> >> > Any ideas on how to do this?
> >> > Thanks,
> >> > Agnes
Re: Want to show Tree selection when tree does not have focus [message #458740 is a reply to message #458716] |
Wed, 20 July 2005 13:35 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
For me the grid-lines are not white but a light gray colour. I have tried
with and without a manifest on Windows XP and in both cases I can see the
lines against the white background. I have tried with the Windows XP Style
with sub-design Blue(standard) and Silver - all work for me. Do you have a
windows skin applied to your desktop?
news:dbk5v3$3l3$1@news.eclipse.org...
> Hi Veronika,
> I
> makes
> like
> Agnes
>> does
>> not have focus.
> out
>> >> > Hi,
>> > selected
> I
>> >> > would
>> >> > trees
>> >> > selected
>> >> > to
>> > get
>> >> > Thanks,
>> >> > Agnes
Re: Want to show Tree selection when tree does not have focus [message #458897 is a reply to message #458740] |
Mon, 25 July 2005 19:05 |
Grant Gayed Messages: 2150 Registered: July 2009 |
Hi Agnes,
Just to eliminate the obvious, you're NOT creating your Trees with style
SWT.HIDE_SELECTION or SWT.PRIMARY_MODAL, right?
Grant
news:dbljuk$jts$1@news.eclipse.org...
Style
a
> > Hi Veronika,
in
you
grid
see
When
> > I
> > makes
of
> > like
> > Thanks,
> > Agnes
> >> does
> >> not have focus.
does
figure
> > out
> >> >> > Hi,
> >> > selected
focus.
> > I
> >> >> > would
> >> >> > trees
the
> >> >> > selected
> >> >> > to
> >> > get
> >> >> > Thanks,
> >> >> > Agnes
FUDForum. Page generated in 0.03447 seconds
