Real time updates in Virtual Table [message #458545] |
Fri, 15 July 2005 11:18 |
Bruce Skingle Messages: 7 Registered: July 2009 |
I am writing an application which displays potentially large amounts of data
in a virtual table. Some of the values may change asynchronously and when
this happens I need to update the display.
If I call Table.clear(int row) for each row when any column is updated then
everything works, but the display flickers as, if the row being updated is
on the screen it is blanked out before my SetData event handler gets called
which paints in the new values (via TableItem.setText()). (Since only some
of the columns change, this causes other columns to be blanked and then
redrawn with the same value, making the flickering more obvious).
As an alternative I can call TableItem.setText() each time a value changes.
This fixes the flickering and works fine for a 1000 row table, however, with
a 400,000 row table (which performs fine with the Table.clear() method
above), the machine grinds to a halt. Obviously I'm forcing the creation of
non-virtual TableItems via the update, which the SetData event handler has
never asked for.
The solution would seem to be to call TableItem.setText() if the item is
on-screen, or Table.clear() if it is not, but I cannot see any efficient way
to do this. (I have considered calling Table.getTopIndex() and
Table.getItemHeight() to work out which rows might be on the screen, but
this seems like a lot to be doing in a handler which currently can process
10,000 updates per second).
TableItem seems to have a (package private) field called cached, which might
be just what I need, but I can't access it.
I might be missing something (in which case any clues would be most
appreciated), but I think that either Table needs a method like clear(int
row) which invalidates the cached value and forces the SetData handler to be
called again if the row is visible, but without clearing the row, or;
TableItem needs a method to tell you if it's virtual, although the
usefulness of this depends on when a virtual table discards cached rows as
you scroll over a large data set.
If anyone has any suggestions I would be most grateful.
Bruce.
Re: Real time updates in Virtual Table [message #458742 is a reply to message #458545] |
Wed, 20 July 2005 13:47 |
Steve Northover Messages: 1636 Registered: July 2009 |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=92313
Fixed > 20050720
The flash should be gone. Try it now and let me know how you get on.
"Bruce Skingle" <Bruce.Skingle@jpmorgan.com> wrote in message
news:db863c$v8s$1@news.eclipse.org...
data
then
called
changes.
with
of
> never asked for.
way
might
be
> Bruce.
FUDForum. Page generated in 0.01702 seconds
