Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Column content disappears on collapse and expand of TableTreeViewer
Column content disappears on collapse and expand of TableTreeViewer [message #458390] Tue, 12 July 2005 19:56 Go to next message
Agnes Freese is currently offline Agnes FreeseFriend
I am having a problem with data disappearing after collapse and expand of a
TableTreeViewer. I have searched the eclipse website and eclipse bugs for
some sign of this issue and haven't found anything as yet. Hoping someone
here might know what the issue is.
I have a TableTreeViewer with two columns. I have a ContentProvider based
on ITreeContentProvider and a LabelProvider based on ITableLabelProvider.
When I expand top level nodes the getColumnText is correctly called in the
label provider to set the values in the second column of the table. I then
do a drag and drop of data from another widget to the second column and in
the drop listener I set the value of the second column TableItem to a new
value.
When I now collapse the tree and re-expand it to see my data again, the data
in the second column is empty. The LabelProvider is not called during the
re-expansion. This is called only the first time the nodes are expanded to
be visible.
How do I keep the data in my second column? I updated it on the TableItem,
but perhaps this is removed during collapse and recreated?? Perhaps I have
to reset this everytime the table is collapsed or expanded??
I would appreciate if anyone has any ideas on this.
Re: Column content disappears on collapse and expand of TableTreeViewer [message #458403 is a reply to message #458390] Tue, 12 July 2005 22:05 Go to previous message
I appear to have solved this. It needs to be set on the TableTreeItem for
the corresponding TableItem.
"Agnes Freese" <afreese@siebel.com> wrote in message
news:db1794$986$1@news.eclipse.org...
a
then
> value.
data
to
> be visible.
TableItem,
have
> Thanks
Previous Topic:draw something on the Browser widget
Next Topic:Dialog using run in ApplicationWindow loses focus
Current Time: Sat Dec 05 18:36:08 GMT 2020
Powered by FUDForum. Page generated in 0.01274 seconds
