Simple table editor [message #458254] |
Tue, 12 July 2005 08:10 |
Originally posted by: prokopiev.stc.donpac.ru
What's wrong in this simple table editor?
public class TestAppTableViewer extends ApplicationWindow {
public TestAppTableViewer() {
super(null);
protected Control createContents(Composite parent) {
Composite container = new Composite(parent, SWT.NONE);
container.setLayout(new FillLayout());
TableViewer viewer = new TableViewer(container, SWT.BORDER |
SWT.V_SCROLL | SWT.H_SCROLL);
Table table = (Table)viewer.getControl();
table.setHeaderVisible(true);
TableColumn column = new TableColumn(table, SWT.LEFT);
column.setText("Name");
column.setWidth(180);
column.setText("Value");
column.setWidth(80);
viewer.setContentProvider(new ArrayContentProvider());
viewer.setLabelProvider(new MyLabelProvider());
viewer.setCellEditors(new CellEditor[] {
new TextCellEditor(),
new TextCellEditor()});
viewer.setCellModifier(new MyCellModifier(viewer));
viewer.setInput(new Data[] {
new Data("Name 1", "Value 1"),
new Data("Name 2", "Value 2"),
new Data("Name 3", "Value 3")
return parent;
public static void main(String[] args) throws IOException {
TestAppTableViewer w = new TestAppTableViewer();
w.setBlockOnOpen(true);
w.open();
private class MyLabelProvider extends LabelProvider implements
ITableLabelProvider {
public Image getColumnImage (Object element, int columnIndex) {
return null;
public String getColumnText (Object element, int columnIndex) {
Data item = (Data)element;
switch (columnIndex) {
case 0: return item.getName();
case 1: return item.getValue();
return "";
private class MyCellModifier implements ICellModifier {
private Viewer viewer;
public MyCellModifier(Viewer viewer) {
this.viewer = viewer;
public boolean canModify(Object element, String property) {
return true;
public Object getValue(Object element, String property) {
if (property.equals("Name"))
else if (property.equals("Value"))
else
return null;
public void modify(Object element, String property, Object changed) {
item.setName(changed.toString());
item.setValue(changed.toString());
viewer.refresh();
private class Data {
private String name;
private String value;
public Data(String name, String value) {
this.name = name;
this.value = value;
public String getValue() {
return value;
public void setValue(String value) {
this.value = value;
public String getName() {
return name;
public void setName(String name) {
this.name = name;
On cell click I got:
at
org.eclipse.jface.viewers.TableEditorImpl.activateCellEditor (TableEditorImpl.java:72)
at
org.eclipse.jface.viewers.TableEditorImpl.activateCellEditor (TableEditorImpl.java:145)
at
org.eclipse.jface.viewers.TableEditorImpl.handleMouseDown(Ta bleEditorImpl.java:271)
at org.eclipse.jface.viewers.TableViewer$2.mouseDown(TableViewe r.java:608)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:133)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at testapp.TestAppTableViewer.main(TestAppTableViewer.java:76)
Re: Simple table editor [message #458272 is a reply to message #458254] |
Tue, 12 July 2005 14:48 |
Originally posted by: raghu.unikensystems.com
One thing is that the CellEditors need to be explicitly created with a
composite parent reference
as in
// create the cell editors and assoc. with viewer
CellEditor[] ces = new CellEditor[] {
new TextCellEditor()};
for(int i=0;i<ces.length;i++) ces[i].create(parent);
viewer.setCellEditors(ces);
in this case however, the selection yields a TableItem to the
ICellModifier.modify()
where u'll need to do something like
Data item = (Data)((TableItem)element).getData();
hth,
Raghu
"Eugene Prokopiev" <prokopiev@stc.donpac.ru> wrote in message
news:davtvl$c4c$1@news.eclipse.org...
> super(null);
> TableViewer viewer = new TableViewer(container, SWT.BORDER | SWT.V_SCROLL
> | SWT.H_SCROLL);
> return parent;
> w.setBlockOnOpen(true); w.open();
> return null;
> return "";
> return true;
> else
> return null;
> viewer.refresh();
> this.name = name;
> this.value = value;
> return value;
> this.value = value;
> return name;
> this.name = name;
> at
> at
> at
> at
FUDForum. Page generated in 0.02744 seconds
