Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Widget Transparency
Widget Transparency [message #457995] Fri, 08 July 2005 21:50 Go to next message
Lucine is currently offline LucineFriend
Hi, I'm working on the Maestro team at JPL...
I have a widget that contains and controls two other custom widgets. One
of these widgets is "hand-drawn" with rectangles, the other is a polygonal
gif image.
The parent widget initializes one instance of the rectangle child widget
and two instances of the polygonal image child widget. How can the
backgrounds for the two instances of the image widget be transparent for
overlapping purposes?
Thank you.
Re: Widget Transparency [message #458263 is a reply to message #457995] Tue, 12 July 2005 13:58 Go to previous message
Steve Northover is currently offline Steve NorthoverFriend
Not really. Widget transparency is not currently supported in the toolkit.
It turns out that this is hard to do and remain portable.
"Lucy Abramyan" <labramyan@hmc.edu> wrote in message
news:88e213560e3c862a7248ec7d7ad2873a$1@www.eclipse.org...
> gif image.
> Thank you.
Previous Topic:TableEditor
Next Topic:Label with FocusListener
Current Time: Sat Nov 28 23:37:41 GMT 2020
Powered by FUDForum. Page generated in 0.06344 seconds
