Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Fancy: Emulation of ghosted drag image in SWT
Fancy: Emulation of ghosted drag image in SWT [message #456825] Thu, 09 June 2005 20:29 Go to next message
Boris Munivrana is currently offline Boris MunivranaFriend
Hi there,
something I haven't come across yet: Is there any reasonable way to
emulate the typical (windows platform) ghosted drag image of a component
dragged within a DND operation, since its win32-API-implementation will
never find it's way into SWT.
Maybe anybody here has accomplished this already, since I didn't find a
SINGLE HINT on the www, or maybe, some ideas by the geniuses of IBM?
Thanks for your concern
Boris
Re: Fancy: Emulation of ghosted drag image in SWT [message #456830 is a reply to message #456825] Thu, 09 June 2005 23:49 Go to previous messageGo to next message
Emil Crumhorn is currently offline Emil CrumhornFriend
I believe this is in the works, although I don't know the extent of the
feature or if it'll make it into 3.1 final. You can find it here:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/R3_1/plan.html
"Improve Drag and Drop Under Effects" .. no bug has been associated with it,
but it's marked as in progress.
Emil
"Boris Munivrana" <bmunivrana@web.de> wrote in message
news:2b4f98eaff39c473f8a44faef97da060$1@www.eclipse.org...
> Hi there,
> Boris
Re: Fancy: Emulation of ghosted drag image in SWT [message #456842 is a reply to message #456830] Fri, 10 June 2005 16:59 Go to previous messageGo to next message
Hi Emil,
thanks for the hint. So you too don't believe emulating this feature with
org.eclipse.swt.graphics (in the meantime...)is possible, since the api
as-is won't let you overcome the problem of drawing on more than one
background component or better to say, drawing on the os shell itself, or
is it me again?
Boris
> Emil
>> Hi there,
>> Regards,
>> Boris
Re: Fancy: Emulation of ghosted drag image in SWT [message #456843 is a reply to message #456842] Fri, 10 June 2005 17:42 Go to previous message
I'm not sure if you can emulate it with the graphics package. It might be
doable, but it sounds like a lot of work, and on windows that stuff is
partially transparent, which sounds like an even harder issue. If you really
really need it now, then I'd say give it a shot. Otherwise I'd say wait
until it's implemented.
Emil
news:8bfba97c64aac423961581904d9f6e35$1@www.eclipse.org...
> Hi Emil,
> is it me again?
> Boris
>> it, but it's marked as in progress.
>> Emil
>>> Hi there,
>>> Regards,
>>> Boris
Previous Topic:Can I put more than one images in a jface table view's cell?
Next Topic:How to get the screen resolution?
Current Time: Tue Apr 16 19:31:32 GMT 2024
Powered by FUDForum. Page generated in 0.89149 seconds
