Home » Archived » XML Schema Definition (XSD) » BaseType of a underived ComplexType
BaseType of a underived ComplexType [message #46119] Thu, 27 May 2004 00:24 Go to next message
Originally posted by: comfortably007numb-python.yahoo.com
I am trying to visit a schema as a tree. During the visit, the
following procedure is called to visit complex type definition.
visit(XSDComplexTypeDefinition type) {
visit(type.getBaseTypeDefinition());
However, the same method is called recursively again with the same
argument. In short, type.getBaseTypeDefinition() returned the object
referred to by variable type. Is this the intended behavior? Or a bug
in XSD? Or am I missing something?
According to XSD specs, it should return the extension/restriction
parent of the object bound to type and, if none exists, it should be
anyType (as it is the root of the Type Hierarchy). Is this so? Or am I
misreading the specs?
waiting for reply,
Venkatesh Prasad Ranganath,
Dept. Computing and Information Science,
Kansas State University, US.
web: http://www.cis.ksu.edu/~rvprasad
Re: BaseType of a underived ComplexType [message #46149 is a reply to message #46119] Thu, 27 May 2004 03:42 Go to previous messageGo to next message
Venkatesh Prasad Ranganath wrote:
> bug in XSD? Or am I missing something?
> I misreading the specs?
> waiting for reply,
Well, the object referred to by variable type represents anyType.
However, getBaseTypeDefinition() on it results in a reference to
itself. Now, is this the intended behavior as it violates the "root"
property of the Type Hierarchy? Shouldn't getBaseTypeDefinition() on an
object that represents anyType return null?
waiting for reply,
Re: BaseType of a underived ComplexType [message #46208 is a reply to message #46149] Thu, 27 May 2004 10:09 Go to previous messageGo to next message
--------------98A704D06138BE43607A49C9
Content-Type: text/plain; charset=us-ascii
Venkatesh,
No, the base type of the anyType is itself as defined in the spec:
http://www.w3.org/TR/xmlschema-1/#section-Built-in-Complex-T ype-Definition
> > Hi,
> > waiting for reply,
> waiting for reply,
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Venkatesh,
<p>No, the base type of the anyType is itself as defined in the spec:
<blockquote><a href=" http://www.w3.org/TR/xmlschema-1/#section-Built-in-Complex-T ype-Definition"> http://www.w3.org/TR/xmlschema-1/#section-Built-in-Complex-T ype-Definition</a></blockquote>
<p><br>Venkatesh Prasad Ranganath wrote:
<blockquote TYPE=CITE>Venkatesh Prasad Ranganath wrote:
<p>> Hi,
<br>>
<br>> I am trying to visit a schema as a tree.&nbsp; During the visit,&nbsp;
the
<br>> following procedure is called to visit complex type definition.
<br>> visit(XSDComplexTypeDefinition type) {
<br>>&nbsp;&nbsp;&nbsp; visit(type.getBaseTypeDefinition());
<br>>&nbsp;&nbsp;&nbsp; ......
<br>> }
<br>>
<br>> However, the same method is called recursively again with the same
<br>> argument.&nbsp; In short, type.getBaseTypeDefinition() returned the
object
<br>> referred to by variable type.&nbsp; Is this the intended behavior?&nbsp;
Or a
<br>> bug in XSD?&nbsp; Or am I missing something?
<br>>
<br>> According to XSD specs, it should return the extension/restriction
<br>> parent of the object bound to type and, if none exists, it should
be
<br>> anyType (as it is the root of the Type Hierarchy).&nbsp; Is this
so?&nbsp; Or am
<br>> I misreading the specs?
<br>>
<br>> waiting for reply,
<br>>
<br>Well, the object referred to by variable type represents anyType.
<br>However, getBaseTypeDefinition() on it results in a reference to
<br>itself.&nbsp; Now, is this the intended behavior as it violates the
"root"
<br>property of the Type Hierarchy?&nbsp; Shouldn't getBaseTypeDefinition()
on an
<br>object that represents anyType return null?
<p>waiting for reply,
<p>--
<p>Venkatesh Prasad Ranganath,
<br>Dept. Computing and Information Science,
<br>Kansas State University, US.
<br>web: <a href="http://www.cis.ksu.edu/~rvprasad">http://www.cis.ksu.edu/~rvprasad</a></blockquote>
</html>
--------------98A704D06138BE43607A49C9--
Re: BaseType of a underived ComplexType [message #46291 is a reply to message #46208] Thu, 27 May 2004 20:18 Go to previous messageGo to next message
Ed Merks wrote:
> Venkatesh,
Thanks for the clarification. I see that a default anyType is plugged
into the type definition hierarchy. Is this instance defined as a
constant in any of the XSD classes? If so, which one?
>> > Hi,
>> > waiting for reply,
>> waiting for reply,
>> <http://www.cis.ksu.edu/%7Ervprasad>
Re: BaseType of a underived ComplexType [message #46322 is a reply to message #46291] Thu, 27 May 2004 20:43 Go to previous message
--------------62E444AA84B7043313137BA2
Venkatesh,
No. Normally you'd get it like this:
xsdSchema.getSchemaForSchema().resolveComplexTypeDefinition( "anyType");
The schema for schema is a shared instance based on the schema for schema namespace
used by the schema. Note that there are recognizers like XSDUtil.isURType for
testing if you have one of these special any types...
> Ed Merks wrote:
> > Venkatesh,
> >> > Hi,
> >> > waiting for reply,
> >> waiting for reply,
<html>
Venkatesh,
<p>No.&nbsp; Normally you'd get it like this:
<blockquote> &nbsp;xsdSchema.getSchemaForSchema().resolveComplexTypeD efinition( "anyType");</blockquote>
namespace used by the schema.&nbsp; Note that there are recognizers like
XSDUtil.isURType for testing if you have one of these special any types...
<br>&nbsp;
<p>Venkatesh Prasad Ranganath wrote:
<blockquote TYPE=CITE>Ed Merks wrote:
<p>> Venkatesh,
<br>>
<br>> No, the base type of the anyType is itself as defined in the spec:
<br>>
<br>>&nbsp;&nbsp;&nbsp;&nbsp; <a href=" http://www.w3.org/TR/xmlschema-1/#section-Built-in-Complex-T ype-Definition"> http://www.w3.org/TR/xmlschema-1/#section-Built-in-Complex-T ype-Definition</a>
<br>>
<br>>
<br>Thanks for the clarification.&nbsp; I see that a default anyType is
plugged
<br>into the type definition hierarchy.&nbsp; Is this instance defined
as a
<br>constant in any of the XSD classes?&nbsp; If so, which one?
<p>> Venkatesh Prasad Ranganath wrote:
<br>>
<br>>> Venkatesh Prasad Ranganath wrote:
<br>>>
<br>>> > Hi,
<br>>> >
<br>>> > I am trying to visit a schema as a tree.&nbsp; During the visit,&nbsp;
the
<br>>> > following procedure is called to visit complex type definition.
<br>>> > visit(XSDComplexTypeDefinition type) {
<br>>> >&nbsp;&nbsp;&nbsp; visit(type.getBaseTypeDefinition());
<br>>> >&nbsp;&nbsp;&nbsp; ......
<br>>> > }
<br>>> >
<br>>> > However, the same method is called recursively again with the
same
<br>>> > argument.&nbsp; In short, type.getBaseTypeDefinition() returned
the object
<br>>> > referred to by variable type.&nbsp; Is this the intended behavior?&nbsp;
Or a
<br>>> > bug in XSD?&nbsp; Or am I missing something?
<br>>> >
<br>>> > According to XSD specs, it should return the extension/restriction
<br>>> > parent of the object bound to type and, if none exists, it should
be
<br>>> > anyType (as it is the root of the Type Hierarchy).&nbsp; Is this
so?&nbsp; Or am
<br>>> > I misreading the specs?
<br>>> >
<br>>> > waiting for reply,
<br>>> >
<br>>> Well, the object referred to by variable type represents anyType.
<br>>> However, getBaseTypeDefinition() on it results in a reference to
<br>>> itself.&nbsp; Now, is this the intended behavior as it violates
the "root"
<br>>> property of the Type Hierarchy?&nbsp; Shouldn't getBaseTypeDefinition()
on an
<br>>> object that represents anyType return null?
<br>>>
<br>>> waiting for reply,
<br>>>
<br>>> --
<br>>>
<br>>> Venkatesh Prasad Ranganath,
<br>>> Dept. Computing and Information Science,
<br>>> Kansas State University, US.
<br>>> web: <a href="http://www.cis.ksu.edu/~rvprasad">http://www.cis.ksu.edu/~rvprasad</a>
<br>>> &lt;<a href="http://www.cis.ksu.edu/%7Ervprasad">http://www.cis.ksu.edu/%7Ervprasad</a>>
<br>>>
<p>--
</html>
--------------62E444AA84B7043313137BA2--
Re: BaseType of a underived ComplexType [message #587732 is a reply to message #46119] Thu, 27 May 2004 03:42 Go to previous message
> waiting for reply,
waiting for reply,
Re: BaseType of a underived ComplexType [message #587752 is a reply to message #46149] Thu, 27 May 2004 10:09 Go to previous message
Venkatesh,
> > Hi,
> > waiting for reply,
> waiting for reply,
<html>
Venkatesh,
<p>> Hi,
<br>>
the
<br>> }
<br>>
object
Or a
<br>>
be
so?&nbsp; Or am
<br>>
<br>>
"root"
on an
<p>--
</html>
Ed Merks
Re: BaseType of a underived ComplexType [message #587788 is a reply to message #46208] Thu, 27 May 2004 20:18 Go to previous message
Ed Merks wrote:
> Venkatesh,
>> > Hi,
>> > waiting for reply,
>> waiting for reply,
Re: BaseType of a underived ComplexType [message #587804 is a reply to message #46291] Thu, 27 May 2004 20:43 Go to previous message
Venkatesh,
> Ed Merks wrote:
> > Venkatesh,
> >> > Hi,
> >> > waiting for reply,
> >> waiting for reply,
<html>
Venkatesh,
<br>&nbsp;
<p>> Venkatesh,
<br>>
<br>>
<br>>
<br>>
plugged
as a
<br>>
<br>>>
<br>>> > Hi,
<br>>> >
the
<br>>> > }
<br>>> >
same
the object
Or a
<br>>> >
be
so?&nbsp; Or am
<br>>> >
<br>>> >
the "root"
on an
<br>>>
<br>>>
<br>>> --
<br>>>
<br>>>
<p>--
</html>
Ed Merks
Previous Topic:Schema has not been resolved
Next Topic:eclipse ide and xsd plug-ins
Current Time: Tue Apr 16 20:33:27 GMT 2024
Powered by FUDForum. Page generated in 3.00599 seconds
