Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Composite update problem
Composite update problem [message #454776] |
Thu, 28 April 2005 13:04  |
Originally posted by: mek.mekistory.de
Hello everybody,
i have a composite_mother and inside that a toolbar (with two toolitems) and
another composite_child. When I press one of the toolitems, the
composite_child changes its content. But I can only see that when I resize
the window of the application.
What I've tried so far:
composite_child.layout()
composite_mother.layout()
shell.layout
shell.update
composite_mother.pack()
composite_child.pack()
But without success...
Thanks for any help!
Re: Composite update problem [message #454778 is a reply to message #454776] |
Thu, 28 April 2005 13:15   |
Originally posted by: elbucho.gmx.de
That's very close to my problem with tables in a rich client application.
Only minimizing/restoring or maximizing of my view causes the table to be
shown correctly after a change has happened. Seems like it is a problem with
all SWT widgets, or should I say feature ? I made the same
layout/update/pack try, but also without success.
Any hints would help me, too.
Roland
"Marco Kohns" <mek@mekistory.de> wrote in message
news:d4qn8p$5n2$1@news.eclipse.org...
> Hello everybody,
and
> shell.layout
> shell.update
Re: Composite update problem [message #454783 is a reply to message #454776] |
Thu, 28 April 2005 14:58   |
Veronika Irvine Messages: 1272 Registered: July 2009 |
If you are using 3.1, the following should work for you:
shell.layout(composite_child.getChildren());
If you know exactly which children have changed to can also do:
shell.layout(new Control[] {child1, child2, child5});
If you are not in 3.1, you need to know a bit about the parents between the
shell and composite_mother. If there is a parent that does not change size,
then the chain of layouts trigerred by shell.layout() will stop at the first
parent that does not resize. For example, if you have a parent that is in a
FillLayout, the only time that parent will change size is when its parent
gets bigger - it will not resize just because one of its children changed
its preferred size. If you have identified any parents like that in the
parent heirarchy of composite_child, then you must call layout() on that
parent.
For example:
public static void main (String [] args) {
Display display = new Display ();
final Shell shell = new Shell (display);
FillLayout layout = new FillLayout();
layout.marginWidth = layout.marginHeight = 5;
shell.setLayout(layout);
final Composite c1 = new Composite(shell, SWT.BORDER);
c1.setBackground(display.getSystemColor(SWT.COLOR_GREEN));
c1.setLayout(layout);
final Composite c2 = new Composite(c1, SWT.BORDER);
c2.setBackground(display.getSystemColor(SWT.COLOR_BLUE));
c2.setLayout(new GridLayout(2, false));
Composite c3 = new Composite(c2, SWT.BORDER);
c3.setBackground(display.getSystemColor(SWT.COLOR_CYAN));
c3.setLayout(new GridLayout(2, false));
for (int i = 0; i < 10; i++) {
Button b = new Button(c3, SWT.PUSH);
b.setText("c3 "+i);
final Composite c4 = new Composite(c2, SWT.BORDER);
c4.setBackground(display.getSystemColor(SWT.COLOR_RED));
c4.setLayout(new GridLayout(5, false));
Button b = new Button(c4, SWT.PUSH);
b.setText("CLICK HERE");
b.addListener(SWT.Selection, new Listener() {
int index = 0;
public void handleEvent(Event e) {
b.setText("c4 "+index++);
// In 3.1, you can do:
//shell.layout(new Control[] {b});
// In 3.0 you must do the following (also works in
3.1)
c2.layout();
c4.layout();
// both are needed
// c2.layout is required if red area needs to grow.
// c4.layout is needed because sometimes c4 does not
change size
// (add buttons to existing row) but the new button
still need to
// be displayed
// Note: calling shell.layout() or c1.layout() has
no effect
// here because the children in the FillLayout do
not change size.
shell.setSize(400, 400);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
> Hello everybody,
> and another composite_child. When I press one of the toolitems, the
> shell.layout
> shell.update
Re: Composite update problem [message #454795 is a reply to message #454783] |
Thu, 28 April 2005 23:49  |
Hey that works, I'm using 3.1 !!!
parent.layout(composite_child.getChildren());
You're brilliant !!!
Thank you very much !!!
This newsgroup is great and you're even greater !!!
"Veronika Irvine" <veronika_irvine@oti.com> schrieb im Newsbeitrag
news:d4qtug$fe9$1@news.eclipse.org...
> the shell and composite_mother. If there is a parent that does not change
> size, then the chain of layouts trigerred by shell.layout() will stop at
> the first parent that does not resize. For example, if you have a parent
> that is in a FillLayout, the only time that parent will change size is
> when its parent gets bigger - it will not resize just because one of its
> children changed its preferred size. If you have identified any parents
> like that in the parent heirarchy of composite_child, then you must call
> layout() on that parent.
> For example:
> b.setText("c3 "+i);
> int index = 0;
> 3.1)
> c2.layout();
> c4.layout();
> // both are needed
> not change size
> still need to
> // be displayed
> no effect
> not change size.
> shell.open ();
> display.dispose ();
>> Hello everybody,
>> resize the window of the application.
>> shell.layout
>> shell.update
Current Time: Sat Apr 17 06:41:58 GMT 2021
Powered by FUDForum. Page generated in 0.01678 seconds
