FormToolkit unresolved at runtime [message #454441] |
Tue, 29 August 2006 22:44 |
Originally posted by: djheath1963.yahoo.com
I've *just* starting working through some of the examples in the
tutorials (brand new to RCP) so your forebearance is requested :)
I'm using FormToolkit to create a FormView and have added
org.eclipse.us.forms to the platform target (changed from SDK to RCP),
but when I attempt to run the app I get the following error:
Missing required bundle org.eclipse.ui.forms_0.0.0.
Anyone know what I'm doing wrong? Session data as follows:
eclipse.buildId=unknown
java.version=1.5.0_07
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product test1.product
Command-line arguments: -product test1.product -data
/home/dana/workspace/../runtime-EclipseApplication -dev
file:/home/dana/workspace/.metadata/.plugins/org.eclipse.pde .core/Eclipse
Application/dev.properties -os linux -ws gtk -arch x86
Thanks!
Re: FormToolkit unresolved at runtime [message #454524 is a reply to message #454510] |
Wed, 30 August 2006 15:11 |
I have yet to export the RCP, so it is via the launcher. Note that the
problem is that it's looking for org.eclipse.ui.forms_0.0.0, not the
packaged _v3.2.0.20060602 jar.
Interestingly enough, this happens only on linux (my main development
workstation) but not on Windows. hmmm.
> Dana Heath wrote:
>> Hello,
> Does that error occur, if you start the program via the run launcher
> or only in case of your exported RCP?
> If the first option applies you should open the launch configuration via
> Run>Run... choose the tab "Plug-ins" and verify that
> org.eclipse.ui.forms is selected (Generally: The button "Add Required
> Plug-ins" is your friend)
> If the second option applies you should ensure whether
> org.eclipse.ui.forms does exist in the exported product.
> Greetings from Bremen,
> Daniel Krügler
Re: FormToolkit unresolved at runtime [message #454525 is a reply to message #454441] |
Wed, 30 August 2006 15:15 |
Dana Heath wrote:
> Hello,
Any time it says _0.0.0 it means it cannot find the plugin at all.
1) go to your Run>Run... launch configuration, and make sure that the
Plug-ins tab includes org.eclipse.ui.forms in its list of plugins.
2) AFAIK, org.eclipse.ui.forms is not part of RCP but is part of the
IDE. You can still develop an RCP app with it, but would probably have
to use the SDK target or possibly update the RCP part with the extra
plugins that you need.
Later,
PW
Paul Webster
FUDForum. Page generated in 0.04245 seconds
