Re: [ATL] One more problem in running Main.java written by Dennis [message #45867 is a reply to message #45837] |
Wed, 13 June 2007 08:00 |
Dennis Wagelaar Messages: 147 Registered: July 2009 |
Stephen Yu schreef:
> Hi
Hi Stephen,
> I downloaded the Main.java which written by
> Dennis( http://ssel.vub.ac.be/viewcvs/viewcvs.py/UML1CaseStudies/uml 1cs-atlcommandline/src/org/atl/commandline/Main.java?view=ma rkup)
> to learn how to run ATL in stand-alone mode. However, I failed to run
> Main.java.
> I always get "java.lang.IllegalArgumentException: resolve against
> non-hierarchical or relative basejava.lang.IllegalArgumentException:
> resolve against non-hierarchical or relative base"
> After looking into the code, I found:
> private static URI cwd = URI.createURI("file:" + new
> File(".").getAbsolutePath()); This static statement will create a URI
> whose attribute 'abosolutePath' is false and 'hierarchical' is false too.
> However, in following method:
> public static ASMModel loadModel(AtlModelHandler amh, String modelId,
> ASMModel metaModel, String uri) ......
> URI absURI = URI.createURI(uri).resolve(cwd); .......
> //the resolve method call will throw
> "java.lang.IllegalArgumentException: resolve against non-hierarchical or
> relative basejava.lang.IllegalArgumentException: resolve against
> non-hierarchical or relative base" ,because the cwd passed in is neither
> abosolutePath nor hierarchical.
> That's why I always get IllegalArgumentException. I can not figure it
> out, do you have any idea about it?
> Thanks a lot.
> Stephen Yu
Sorry, but I cannot reproduce your problem. Can you provide some files
with which I can trigger this exception? I will also need the exact
command/method you used to invoke ATL.
I do use the command line interface with relative paths. An example of
how I use the command line interface can be found here:
http://ssel.vub.ac.be/viewcvs/viewcvs.py/UML1CaseStudies/uml 1cs-instantmessenger-model/outmodels/test2mm/build.xml?rev=5 387&view=markup
Dennis
FUDForum. Page generated in 0.01927 seconds
