Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Strange Shell behaviour
Strange Shell behaviour [message #453939] Thu, 14 April 2005 12:59 Go to next message
hortiz Mising name is currently offline hortiz Mising nameFriend
Member
I used in my application a Shell with ALWAYS_ON_TOP style, to allow users
to always see some important information (server alarms, ...).
I work on Linux with SuSE 8.2.
But if the user clickes on the clock in the task bar while this shell is
displayed, it disappears.
Here is a sample code (two classes: Main.java and SpyContainer.java)
/*** Main.java ******************************/
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
public class Main {
private static Display display;
display = new Display ();
Shell shell = new Shell (display);
shell.setLayout(new GridLayout());
Button openSpyButton = new Button(shell, SWT.PUSH);
openSpyButton.setText("Open Spy");
openSpyButton.setLayoutData(new GridData());
openSpyButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent event) {
SpyContainer spyContainer = new SpyContainer(display);
spyContainer.getSpyComposite().layout();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
/*** SpyContainer.java **********************/
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
public class SpyContainer {
private Shell spyShell;
private Composite spyComposite;
public SpyContainer(Display display) {
spyShell = new Shell(display, SWT.NO_TRIM | SWT.ON_TOP);
// spyShell = new Shell(display, SWT.NO_TRIM | SWT.ON_TOP |
SWT.PRIMARY_MODAL);
SWT.APPLICATION_MODAL);
SWT.SYSTEM_MODAL);
SWT.MODELESS);
spyShell.setLayout(new FillLayout(SWT.VERTICAL));
spyComposite = new Composite(spyShell, SWT.NONE);
spyComposite.setLayout(new GridLayout());
spyComposite.setBackground(display.getSystemColor(SWT.COLOR_ DARK_RED));
Label spyLabel = new Label(spyComposite, SWT.NONE);
spyLabel.setText("Spy Label");
spyLabel.setLayoutData(new GridData());
spyShell.setSize(300, 300);
spyShell.open();
public Composite getSpyComposite() {
return spyComposite;
Re: Strange Shell behaviour [message #453942 is a reply to message #453939] Thu, 14 April 2005 13:55 Go to previous messageGo to next message
Member
For information, I have test my code on Debian and there is no problem...
Re: Strange Shell behaviour [message #453946 is a reply to message #453939] Thu, 14 April 2005 14:45 Go to previous messageGo to next message
Steve Northover is currently offline Steve NorthoverFriend
No idea why this would happen. ON_TOP shells override the window manager so
it should not be hiding it. Try creating the spy as a child of the other
shell?
"hortiz" <hortiz@xxxxx.com> wrote in message
news:3cb48cd36c1972c97b862078d7e23aee$1@www.eclipse.org...
> import org.eclipse.swt.widgets.Display;
> public class Main {
> public static void main(String[] args) {
> shell.open();
> display.sleep();
> display.dispose();
> SWT.PRIMARY_MODAL);
> SWT.SYSTEM_MODAL);
> SWT.MODELESS);
> spyShell.open();
Re: Strange Shell behaviour [message #453947 is a reply to message #453946] Thu, 14 April 2005 15:20 Go to previous messageGo to next message
Member
Hi Steve,
>>> Try creating the spy as a child of the other shell ?
I still have the same problem...
Did you manage to reproduce it ?
Helene
Re: Strange Shell behaviour [message #454179 is a reply to message #453947] Mon, 18 April 2005 20:11 Go to previous message
Nope.
news:328f778bec36593db9170c31bb4ff4ac$1@www.eclipse.org...
> Hi Steve,
> Helene
Previous Topic:Text validation and setting focus
Next Topic:Hide a coolbar
Current Time: Sat Apr 17 00:11:52 GMT 2021
Powered by FUDForum. Page generated in 0.02175 seconds
