starting an RCP app in debug mode [message #453640] |
Fri, 04 August 2006 15:39 |
Originally posted by: x.maysonnave.gmail.com
In an RCP app I try to use the usual Eclipse debug framework.
1 - Start the application with a -debug option
2 - Define at the root of the application a .options file.
3 - Fill this file with our app debug keys.
Once deployed the application doesn't seem to read the .options file.
In the Eclipse IDE; the runned RCP app work like a charm.
Any experience ?
Regards.
Re: starting an RCP app in debug mode [message #453643 is a reply to message #453641] |
Fri, 04 August 2006 16:20 |
yes, in eclipse it's defined.
Once deployed the .options file are packaged inside my plugins.
I usually create a new .options file at the root of eclipse (rcp app) when
I want to turn on the debug mode of specific plugins (plus the -debug at
the command or at the.ini file level). I assumed an RCP apps works in the
same way. I am working with Eclipse 3.2 on Linux SuSE 10 with a JDK 1.5.0.
if someone have some feedacks on such platform it could be helpful before
I open a report on bugzilla.
Regards.
FUDForum. Page generated in 0.01756 seconds
