Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Is there a way to get the version from SWT
Is there a way to get the version from SWT [message #453330] Tue, 05 April 2005 13:17 Go to next message
Andy Arhelger is currently offline Andy ArhelgerFriend
Member
Is there a method or some easy way to get the version information from
SWT at runtime? I.E. 3.0.1 or 3.1? I know Spinner was introduced in 3.1
and I could check for that class but that seem rather crude.
Andy Arhelger
Re: Is there a way to get the version from SWT [message #453334 is a reply to message #453330] Tue, 05 April 2005 14:59 Go to previous messageGo to next message
Christian Hauser is currently offline Christian HauserFriend
SWT has another version numbering system. Not 3.0, 3.1. You can see the
version in the libraries:
On my WinXP box running Eclipse 3.1M6 I have:
swt-win32-3128.dll
SWT.getVersion() would thus return 3128 as the SWT version.
For more info look at SWT#getVersion() (though I don't know how much
info there is...)
HTH,
Christian
Re: Is there a way to get the version from SWT [message #453438 is a reply to message #453330] Tue, 05 April 2005 15:10 Go to previous messageGo to next message
To your Spinner problem:
The Spinner API was introduced in SWT Build 3.1 013 (2004-11-23) thus
the following should IMHO work (not tested, though):
if (SWT.getVersion() > 3113) {
// Spinner can be used
However, as there were some updates to Spinner for Eclipse 3.1M7 (Bug
86079 and new Spinner API) I would recommend a test like this:
if (SWT.getVersion() > 3128) { ... }
HTH,
Christian
Re: Is there a way to get the version from SWT [message #453439 is a reply to message #453438] Tue, 05 April 2005 15:11 Go to previous message
Updates to Spinner for Eclipse 3.1M6 of course...
Previous Topic:Content Assistant
Next Topic:Controls getting too much space with TableWrapLayout in WizardPage
Current Time: Sat Apr 17 16:48:11 GMT 2021
Powered by FUDForum. Page generated in 0.01555 seconds
