Home » Eclipse Projects » Rich Client Platform (RCP) » Cant launch imported RCP project, "not in registry" error
Cant launch imported RCP project, "not in registry" error [message #453111] Fri, 21 July 2006 18:47 Go to next message
Bill Blalock is currently offline Bill BlalockFriend
This is Eclipse 3.2
I am having a problem importing RCP projects into the workspace. I
followed these instructions:
-Unzip formsArticle.zip into your workspace location in the file system.
-Import the extracted project (org.eclipse.ui.forms.article) into your
-workspace using 'File>Import>Existing Project into Workspace'
-When ready, launch another Eclipse using 'Run>Run As>Eclipse Application'
(source: http://www.eclipse.org/articles/Article-Forms/article.html)
When I try to launch the project I get this error
java.lang.RuntimeException: Application "WhatWasimported" could not be
found in the registry. The applications available are:
my_other_applications_which_show_up_in_Run>EclipseApplication.
This is the second time this has happened. The first time I figured it
was me. I tracked the problem down to an XML file in
.metadata/.plugins/org.eclipse.pde.code
Apparently 'File>Import>Existing Project into Workspace" is not updating
everything.
What am I doing wrong? Has anyone else run into this problem?
Bill Blalock
PS. This is the log if that helps
!SESSION 2006-07-21 13:17:59.061
eclipse.buildId=unknown
java.version=1.4.2_08
Framework arguments: -application org.eclipse.ui.ide.workbench
Command-line arguments: -application org.eclipse.ui.ide.workbench -data
C:\eclipse_32_JVM4_workspace/../runtime-EclipseApplication(1 ) -dev
file:C:/eclipse_32_JVM4_workspace/.metadata/.plugins/org.ecl ipse.pde.core/Eclipse
Application (1)/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2006-07-21 13:18:00.543
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench"
could not be found in the registry. The applications available are:
Interstice_Preferences_Experiments.application,
com.cprs.vuckdb_preferences.application, org.cprs.rcphello.application.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:68)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Cant launch imported RCP project, "not in registry" error [message #453114 is a reply to message #453111] Fri, 21 July 2006 22:51 Go to previous messageGo to next message
Wayne Beaton is currently offline Wayne BeatonFriend
Bill Blalock wrote:
> This is Eclipse 3.2
> -workspace using 'File>Import>Existing Project into Workspace' -When
> everything.
> Thanks
> Bill Blalock
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
It sounds to me like you have the wrong application selected in your
launch configuration. Go to the first page in the launch configuration
and make sure that your application is selected in the "Program to Run"
section.
Alternatively, you may not have the full set of required plug-in
selected. Click the "validate plug-in set" button on the "Plug-ins
page"; it'll tell you if anything is missing.
Wayne
Re: Cant launch imported RCP project, "not in registry" error [message #453125 is a reply to message #453114] Sat, 22 July 2006 13:37 Go to previous messageGo to next message
Wayne Beaton wrote:
> Bill Blalock wrote:
>> This is Eclipse 3.2
>> everything.
>> Thanks
>> Bill Blalock
>> C:eclipse_32_JVM4_workspace/../runtime-EclipseApplication(1) -dev
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
> section.
> Wayne
Thanks Wayne but the application does not appear in the "Program to Run"
section. When launched from PDE, PDE forces the program into this field
and the lauch fails with the message above.
When trying to manually launch from Run and editing or building a new
launch profile the program does not appear in the list of programs to run.
The list only contains the programs listed in the full log message in my
original e-mail. That is:
- Interstice_Preferences_Experiments.application,
- com.cprs.vuckdb_preferences.application,
- org.cprs.rcphello.application.
The log message indicates that there is a registry of valid programs
someone where. A PlugIn or RCP is not being added to that list when it is
created by File > Import > Existing Project Into Workspace (per the
instructions of the RCP forms example).
Re: Cant launch imported RCP project, "not in registry" error [message #453127 is a reply to message #453125] Sat, 22 July 2006 16:12 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Bill Blalock wrote:
> Wayne Beaton wrote:
>> Bill Blalock wrote:
>>> This is Eclipse 3.2
>>> everything.
>>> Thanks
>>> Bill Blalock
...snip
>> section.
>> Wayne
What is the target platform for your Workspace? The Forms example article
is a plugin not an application. You need an Eclipse runtime as the target
plarform in order to run the examples.
Re: Cant launch imported RCP project, "not in registry" error [message #453128 is a reply to message #453127] Sat, 22 July 2006 17:38 Go to previous messageGo to next message
Dave Wegener wrote:
> Bill Blalock wrote:
>> Wayne Beaton wrote:
>>> Bill Blalock wrote:
>>>> This is Eclipse 3.2
>>>> everything.
>>>> Thanks
>>>> Bill Blalock
> ...snip
>>> section.
>>> Wayne
I see and that makes sense. A lot to learn here. These are the
instructions given in the Forms example article.
Application'
You asked:
The target platform is the RCP Eclipse 3.2 download from eclipse.org. I
added the plugins which the Forms article sample code required in order to
compile. I have been using this to work through "eclipse Rich Client
Platform" book and my RCP experiments.
What do I need to change? What do I do to get ".. an Eclipse runtime as
the target plarform ..."
Sorry, these are newbe questions. A lot to unlearn, relearn and learn
here. I appreciate the help.
Re: Cant launch imported RCP project, "not in registry" error [message #453130 is a reply to message #453128] Sat, 22 July 2006 19:20 Go to previous messageGo to next message
Bill Blalock wrote:
> Dave Wegener wrote:
>> Bill Blalock wrote:
>>> Wayne Beaton wrote:
>>>> Bill Blalock wrote:
>>>>> This is Eclipse 3.2
>>>>> system. -Import the extracted project
>>>>> (org.eclipse.ui.forms.article) into your -workspace using
>>>>> 'File>Import>Existing Project into Workspace' -When ready, launch
>>>>> another Eclipse using 'Run>Run As>Eclipse Application' (source:
>>>>> figured it was me. I tracked the problem down to an XML file in
>>>>> updating everything.
>>>>> Thanks
>>>>> Bill Blalock
>> ...snip
>>>> configuration and make sure that your application is selected in the
>>>> "Program to Run" section.
>>>> Wayne
>>> Run" section. When launched from PDE, PDE forces the program into
>>> this field and the lauch fails with the message above.
>>> run. The list only contains the programs listed in the full log
>>> message in my original e-mail. That is:
>>> - Interstice_Preferences_Experiments.application, -
>>> com.cprs.vuckdb_preferences.application, -
>>> it is created by File > Import > Existing Project Into Workspace (per
>>> the instructions of the RCP forms example).
>> article is a plugin not an application. You need an Eclipse runtime
>> as the target plarform in order to run the examples.
> Application'
> You asked:
> to compile. I have been using this to work through "eclipse Rich Client
The easiest way is to use the Reset button on the Plug-in
Development->Target Platform page. This will point the target platform
back at the Eclipse installation directory.
Re: Cant launch imported RCP project, "not in registry" error [message #453180 is a reply to message #453130] Mon, 24 July 2006 14:56 Go to previous message
Thanks Dave!
That is where I was going wrong. My development workspace was set up for
an RCP target.
I have set up multiple workspaces for my different projects. Thinking
about it I have been working out of one workspace for too long.
I got the example to run under Eclipse 3.2 w/ Java 1.5.0.07. At least
until it failed with a null pointer exception. It started to load but
failed. At least it displayed the message and made the log available.
Have you seen this before? If so, any suggestions? Otherwise I'll run it
under debug and try to figure out what has changed. Failing that I'll
post a new request.
Again, thanks for your help.
Previous Topic:How to get perspective reference from MultiPageEditorPart or ViewPart
Next Topic:Eclipse Run Menu and Coolbar contributions
Current Time: Mon Nov 04 22:15:35 GMT 2024
Powered by FUDForum. Page generated in 0.02949 seconds
