Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to freeze first col,umn of Tree
How to freeze first col,umn of Tree [message #452736] Thu, 24 March 2005 07:50 Go to next message
Nicole is currently offline NicoleFriend
Is it possible to freeze the first column of a Tree so that when I slide
the horizontal scrollbar, the first column can always be seen? Thanks.
Re: How to freeze first col,umn of Tree [message #452741 is a reply to message #452736] Thu, 24 March 2005 09:41 Go to previous messageGo to next message
Roland Tepp is currently offline Roland TeppFriend
Nope, as far as I know its impossible with standard table widget
Nicole kirjutas mulle ühel talvisel päeval midagi seesugust:
> Regards
Roland Tepp
Re: How to freeze first col,umn of Tree [message #453042 is a reply to message #452741] Wed, 30 March 2005 04:58 Go to previous messageGo to next message
Thanks for the reply. So is there any recommendations on how to achieve
this effect, maybe by writing a custom widget or using some listener to
control the way the scrollbars behave etc? Thanks. Will be grateful for
any suggestions.
Nicole
Re: How to freeze first col,umn of Tree [message #453088 is a reply to message #453042] Wed, 30 March 2005 13:44 Go to previous message
> any suggestions.
Maybe, it could be done in a way similar to spreadshhet programs (EXCEL,
OO): Split the window, use a sach form, display the tree in both parts
of the sash form. Then you can scroll the right part horizontally
without affecting the left part. If you synchronize vertical scrolling,
you might have the desired behaviour.
(I haven't tried it. It's just an idea.)
Klaus Wulff
Previous Topic:Data field validation is one character behind.
Next Topic:eclipse 3.1M5 OSGi ?
Current Time: Thu Aug 22 09:49:21 GMT 2019
Powered by FUDForum. Page generated in 0.02066 seconds
