Home » Eclipse Projects » Standard Widget Toolkit (SWT) » FormLayout -- how do children request space?
FormLayout -- how do children request space? [message #452732] |
Thu, 24 March 2005 00:53 |
Originally posted by: doug-list.threepenny.net
I have a FormLayout that contains two windows. One is a vertical column
of buttons in a RowLayout(). The two are connected by:
rightData.left = new FormAttachment(buttons);
This creates a form with enough space for a single column of buttons.
The problem comes if I resize the display so that two columns are
required the space for the buttons doesn't increase.
Clearly there's some way to say "give me my computeSize()" amount of
space now that things have changed. I've tried calling layout(true) on
every window I can think of but no luck.
Can anyone put me straight on this? I'm sure it's pretty elementary.
Doug
Re: FormLayout -- how do children request space? [message #453290 is a reply to message #453027] |
Mon, 04 April 2005 19:23 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
You need to set the data.width hint as shown below. I thought in 3.1 this
would no longer be required but this seems to be a case were it still is. I
am investigating.
public static void main (String [] args) {
Display display = new Display ();
final Shell shell = new Shell (display);
shell.setLayout(new FormLayout());
final Composite c = new Composite(shell, SWT.BORDER);
c.setLayout(new RowLayout(SWT.VERTICAL));
for (int i = 0; i < 20; i++) {
Button b = new Button(c, SWT.PUSH);
b.setText("Button "+i);
Button b = new Button(shell, SWT.PUSH);
b.setText("Right");
FormData data = new FormData();
data.left = new FormAttachment(0, 5);
data.top = new FormAttachment(0, 5);
data.bottom = new FormAttachment(100, -5);
c.setLayoutData(data);
data.left = new FormAttachment(c, 5);
data.right = new FormAttachment(100, -5);
b.setLayoutData(data);
shell.addListener(SWT.Resize, new Listener() {
public void handleEvent(Event e) {
Rectangle area = shell.getClientArea();
FormData data = (FormData)c.getLayoutData();
data.width = c.computeSize(-1, area.height - 10).x;
shell.layout(true);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:d2cssi$4oo$1@news.eclipse.org...
> Do you need use FormAttachment (int, int) which allows an edge to be
> placed
> at a percentage of the parent?
> "Doug Pearson" <doug-list@threepenny.net> wrote in message
> news:d1t7s6$r3f$1@news.eclipse.org...
>> Thanks,
>> Doug
Re: FormLayout -- how do children request space? [message #453292 is a reply to message #453290] |
Mon, 04 April 2005 19:32 |
In 3.1, we handle the case where height = f(width). For example, a label
that wraps - the height varies as the width changes. This is also the case
of a RowLayout that is horizontal.
In your case you have width = f(height), the vertical RowLayout width varies
as the height changes. This case is not handled by the FormLayout (or
GridLayout) in 3.1.
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:d2s4eo$gi0$1@news.eclipse.org...
> I am investigating.
> b.setText("Right");
> shell.layout(true);
> shell.open ();
> display.dispose ();
>> placed
>>> Thanks,
>>> Doug
Re: FormLayout -- how do children request space? [message #453293 is a reply to message #453292] |
Mon, 04 April 2005 19:33 |
By "not handled", I mean you must set the data.width in the resize event of
the parent as shown in my previous example.
news:d2s4u4$h7q$1@news.eclipse.org...
> case of a RowLayout that is horizontal.
> varies as the height changes. This case is not handled by the FormLayout
> (or GridLayout) in 3.1.
>> this would no longer be required but this seems to be a case were it
>> still is. I am investigating.
>> b.setText("Right");
>> 10).x;
>> shell.layout(true);
>> shell.open ();
>> display.dispose ();
>>> placed
>>>> column
>>>> Thanks,
>>>> Doug
Current Time: Thu Apr 25 21:40:41 GMT 2024
Powered by FUDForum. Page generated in 0.03578 seconds
